03-06-2018, 12:25 PM | #1 |
Rep 297
HRE FF04 19" in Tarmac Black
just got my wheels put on, was running OEM wheels with a 12mm front and 10mm rear spacer, which are now up for sale, lowered on Eibach Pro-Kits, zero rubbing with spacers. Effective offset on OEM wheels were +17 front and +30 rear. HRE's are +20 front and +35 rear. OEM PSS 245 and 265 tires in both photos
Before photo(lowered, no spacers +29 front +40 rear) After photo(lowered, no spacers +20 front and +35 rear)
2017 F87 M2 BSM DCT, Executive, IND Cosmetic package (painted front reflectors, black grills, black badge, accexxon rear reflectors), IND floor mats, Mode Carbon Rear Spoiler, Dinan Resonator Delete, CTS Intake, Eibach Pro kit
03-07-2018, 08:05 AM | #3 |
Rep 1,339
Off set of stock 437M are ET29 front, ET40 rear.
Anyways, I am getting mine with same color. I will be fitting 255/35/19 and 275/35/19 MPS4S. Color goes better with BSM IMO than my LBB. Wish to do IPA but I decided to go with different powder coat later at local wheel refinish shop later if I want soem refresh. Edit: Well guess I did not read your post carefully. Did not see you have spaces front and rear haha. |
chrispraeger761.00 |
03-13-2018, 12:30 AM | #4 |
Rep 220
Looks really really good !!
The FF04 in 19" are definetly the best suitable and affordable tires for the M2 in my opinion.
alscks0414690.00 |
03-26-2018, 08:04 AM | #6 |
Space Force - 4 Star General
11466
Rep 3,264
Looks great!
I just took delivery of my FF04s in IPA. What are you using for mounting hardware? My FF04s shipped with zinc plated, silver, hardware. Yours appears black in the photo above. Are you simply using the OEM BMW wheel bolts? |
03-26-2018, 08:43 AM | #7 |
Rep 297
yes just using the OEM wheel bolts
DETRoadster11465.50 |
03-26-2018, 04:45 PM | #9 |
Rep 865
Drives: OG M2
Jesus that looks too good! Can you take some more shots from the rear three quarter profile? I assume you could probably fit some 275/295/30/R19s on these... Any HRE reps know?
03-27-2018, 11:08 AM | #10 | |
Rep 1,339
FF04 comes with different offset front and rear compared to 437M stock wheels. But they are same in width 9' front and 10' rear. 9 inch can fit maximum of 265 width tires. 10 inch can fit maximum of 285. However recommended tires are 245-255 front and 265-275 rear. I went with 255F and 275R as i do not want to risk going over the limit of the width. Wheel width is not designed to support over 265F and 285R especially when u r pushing the car to the limit at track sessions. If u r not much concerned abt driving characteristic (and probably safety), then u could fit wider tires like 275F 295R with 30 profile at 19's. Choice is urs i guess. |
03-28-2018, 07:59 AM | #11 |
Rep 297
i'm pretty confident that the 255/275 combo will fit without issues. i'll try and get some better pictures tonight.
