M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Not feeling MPE. What am I missing?
      02-10-2018, 09:44 AM   #45
Damage Inc
Damage Inc's Avatar
790
Drives: 2017 M2
I decide to sell my MPE is anybody is interested. Titanium Tips.
Has fantastic sound, fits the character of the car. Send me a PM.
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS
      02-16-2018, 04:31 PM   #46
seis-speed
#savethemanuals
seis-speed's Avatar
Drives: 1M | GT3 | J392 | GRc
Originally Posted by Damage Inc View Post
So picked up my second hand M2 yesterday came w MPE.
MPE sounds fantastic from the outside. Has a nice growling rumble at parking lot speeds - watching the tech take my car for a test drive around the dealer.
But... from the inside it sounds blah. I thought it was the ASD, so I coded it off. This is windows up of course.
1. You dont really hear any good sounds. Just a loud tone, almost "drony". Its like trying to listen to a movie in another room with the doors closed. Just muffled exhaust noise.
2. Around 2500 to 3200 RPM its kinda drony. Gives me a headache. I thought it was the ASD but its actually the MPE! In previous cars, getting on the gas from 2k to 4k RPM would always produce some fun sounds.... not the case here just kinda bland.
My test drive was a 18 w no MPE. There was nothing w MPE to drive.
I had the install checked by a BMW tech, he said it looked correct. Although he knew nothing about the M2 or MPE, so he was pretty useless.
On a positive note, the cold start was not as loud as I thought it was going to be.
Anyways... is there an adjustment? Bad install? Something I'm missing? Any tricks to getting the MPE to sound good INSIDE the cabin? Or atleast get ride of the drony noises, especially on the highway.
I'm sure i"m missing something. Hopefully it better than this... thanks guys
OP, I agree, exhausts are very subjective, but inside the cabin windows rolled up not the best sound. I think more people will like the MPE than not, in fact passengers comment on the sound, but reading your post, I feel the same way. I thought it was just me.... haha.
In a parking lot windows down it is glorious. The loud drone noise ~ 3000 rpm is not something I like, but again other people love it.
      02-16-2018, 04:37 PM   #47
seis-speed
#savethemanuals
seis-speed's Avatar
Originally Posted by SeanWRT View Post
It's critical where resonator is mounted. From your picture it's a little upper than original place. How does that serve you?
Does using the stock resonator work? I have mine. Does a dealer put it on or a shop? I had my MPE installed at dealer. TIA!
      03-03-2018, 12:32 PM   #48
NellyRod
I have the MPE, and coded ASD off. I prefer the ASD off. I do hear slight droning at highway speeds. I ordered the Akrapovic catted DP, so hopefully that adds a better in-cabin sound. If it doesn't help with the droning, then I'll go with the full Akra exhaust instead. I'm also going Dinan stage 4 in two weeks, so that might also affect engine sound slightly.
      03-15-2018, 08:06 AM   #49
gtaM2
Driver
gtaM2's Avatar
391
Drives: 2016 M2 BSM 6MT
Originally Posted by AGM2 View Post
But is there any way to reduce the 3k drone? Or "it is what it is". I think I read in another thread the MPE removes the resonator? If so maybe that's the issue.
You need to add the stock resonator to the MPE
has anyone with MPE tried to add their stock resonator? does it remove the drone? hopefully someone has tried this, i don't have my stock exhaust
      03-15-2018, 09:03 AM   #50
voyagergab
voyagergab's Avatar
633
Drives: G82 M4 6MT, G01/F97 X3M
But is there any way to reduce the 3k drone? Or "it is what it is". [COLOR="Red"]I think I read in another thread the MPE removes the resonator? If so maybe that's the issue.[/COLOR]
I would like to know as well.
Also can the stock resonator be purchased separately?
      03-15-2018, 01:52 PM   #51
F87_LCI
F87_LCI's Avatar
1787
Drives: 2018 LBB F87
I am quite disappointed in the MPE - Fabspeed SporCat combo. The car is almost undriveable between 2800-3200rpm...at least for me anyway. I find myself having to be in gears higher than I usually would be (i.e. 4th instead of 3rd) just to keep the rpms below 2500 to avoid the horrible drone. I am waiting for the weather to break so that hopefully there will be a local meet where I can listen to what other guys have done -
different systems/combos/etc. There must be something out there that sounds better...maybe once I get past break in it will be better?? Hindsight tells me I should have stuck with stock exhaust and just purchased a different aftermarket system.
      03-15-2018, 02:24 PM   #52
voyagergab
voyagergab's Avatar
633
Real oem shows the part number for the resonator.
http://www.realoem.com/bmw/enUS/part...;q=18307854718
It can be found for around $350 USD
Question is who's going to be the first to try.
Location of the resonator is likely important.
      03-15-2018, 02:42 PM   #53
voyagergab
voyagergab's Avatar
633
Just spoke to a knowledgeable gentleman by the name of Aron from Vibrant Performance in Ontario. Was told that adding a resonator would likely be helpful as the drone at a certain engine speed is due to the vibration frequency of this long exhaust tube.
As for positioning he did say that if the drone is at lower frequency like we see 2800-3000 RPM, then the resonator is placed closer to the front (the cat).
Which corresponds to where the stock resonator lives.
Do we know the tubing diameter of the MPE?
      03-15-2018, 03:04 PM   #54
gtaM2
Driver
gtaM2's Avatar
391
hmm thats an interesting take that the drone is caused by vibration, looking at the oem diagram of the stock exhaust from that link you posted the stock exhaust comes with a "vibration absorber" piece, i wonder if the MPE utilizes this, or if the MPE exhaust can be further stabilized to prevent vibration and reduce drone
      03-15-2018, 03:10 PM   #55
sh_kross
Puerto Rico
92
Drives: Long Beach Blue M2
2018 BMW M2  [10.00]
Question
Genuine question... Why would you be in 4th at that RPM for an extended amount of time (that the drone would get annoying)? I ask, since the M2 is the first car I drive with a manual transmission, I've been sticking to the recommendations of the computer, which keeps the revs down around 1.5k.
Of course, if I'm driving aggressively, I don't pay attention to that, but then the drone wouldn't be an issue and I wouldn't need to keep there for long.
      03-15-2018, 03:10 PM   #56
Philb65
Drives: LBB M2
Why does choosing comfort make the drone so bad, at 3k rpm it's terrible? In sport or sport+ I don't think there's much drone at the 3k rpm point. Certainly doesn't bother me. Is it something to do with ASD? I drive in sport+ and it's fine, whether it would be with a sports cat I can't say.
      03-15-2018, 03:10 PM   #57
voyagergab
voyagergab's Avatar
633
I don't recall much of my physics but AFAIK drone is caused by resonance. The longer your unobstructed tube is the higher the likelihood that the sound waves travelling back and forth that tube will resonate at some frequency.
All the resonator is doing is breaking up the wave so to speak. The resonator is basically a perforated tube with some fibreglass packing around it. That's my understanding anyway
      03-15-2018, 03:13 PM   #58
AGM2
AGM2's Avatar
Drives: M2 LBB 17
Very good so that maybe is the missing LINK
To fix this issues
After zoom my pic I can see the Rubber Mounting
Is there so no that is not he FIX
      03-15-2018, 03:22 PM   #59
gtaM2
Driver
gtaM2's Avatar
391
hmm so stabilizing the pipe might not do anything since its more of a sound wave on the inside...makes sense to me.. im sold on the idea ill probably end up trying to add a resonator in a month or so, be nice if someone tried it sooner
      03-15-2018, 03:23 PM   #60
gtaM2
Driver
gtaM2's Avatar
391
To fix this issues
hmm i wonder if the MPE uses that vibration piece
      03-15-2018, 03:54 PM   #61
AGM2
AGM2's Avatar
Drives: M2 LBB 17
Yes!! see my last 2 pic the never took out that piece
gtaM2390.50
      03-15-2018, 04:13 PM   #62
AGM2
AGM2's Avatar
Drives: M2 LBB 17
Guys, I drive my car with the flappers close
And the sport On & sport + the drone is minimum
And sound more that the stock with flapper Open..
you try that?
      03-15-2018, 04:32 PM   #63
F87_LCI
F87_LCI's Avatar
1787
I actually like to keep the RPM between 2500-3000 when "cruising" (i.e. not shifting from gear to gear) so that the car is always ready to go as it is at the start of the power band...if I was to cruise with it down at 1500, I would need to downshift (possibly twice) to get the car to GO! I believe the manufacturer recommends driving at these low rpms as this is the only way the car will make the advertised MPG km/100L numbers. Correct me if I'm wrong.
Interested to see if the resonator will help the situation.
      03-15-2018, 05:08 PM   #64
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
lol you do realize if you want it THAT loud inside you'll have actual drone.
clearly from the outside it sounds good so who cares what it sounds like on the inside? you're not driving a v8/10/12 soooooooo roll down the windows or listen to some good tunes.
#firstworldproblems
      03-15-2018, 06:36 PM   #65
F87_LCI
F87_LCI's Avatar
1787
Says the guy who lives in San Diego, lol.
Some of us have temp of -2C/30F degrees bud. Like today. ...and it's March 15th!
      03-15-2018, 08:15 PM   #66
voyagergab
voyagergab's Avatar
633
This is the best video I've seen on YouTube today LOL
///Mē282.50
