01-18-2018, 06:56 PM | #23 | |
Rep 1,124
M3 Adjuster7905.50 ORIGIN M.3160.50 |
01-18-2018, 07:06 PM | #24 | ||
Rep 1,124
01-18-2018, 09:55 PM | #25 | |
Rep 1,016
rich8566608.50 |
01-18-2018, 11:37 PM | #26 | ||
7906
Rep 11,785
As far as the brakes. I've only been screaming it for about 2 years. If you have more than a beginners level talent... if you are driving in a " solo" run group in most US HPDE , please recognize that the M2 is the first bmw in *35 years* to have pads that SUCK SO BAD AT THE TRACK THAT YOU HAVE TO BUY TRACK PADS. It's true. So deal with it. |
ORIGIN M.3160.50 |
01-18-2018, 11:41 PM | #27 | |||
Rep 1,124
01-18-2018, 11:43 PM | #28 | ||||
7906
Rep 11,785
Square helps yes, but the issue is still there it will just take a little longer to show. The RS3 is a better tire all around of course. The stock stagger causes understeer, just as it's been on every bimmer since the E36. |
01-19-2018, 12:14 AM | #29 | |||||
3161
Rep 9,134
01-19-2018, 12:24 AM | #30 |
Rep 1,153
The break-in diff oil is indeed different from the oil that replaces it forever on. I second all the recommendations here--get break-in service first, and don't use stock pads for more than a casual scouting run, if your track lets you do that (although it makes a bunch more sense just to swap them out from the beginning).
Also, personally, it is hard for me to imagine going to the track and staying south of 5500 rpm for the day. What is the point of that? Sounds frustrating. It surely was frustrating to do that on the street, so on the track it would be pure torture! |
01-19-2018, 12:45 AM | #31 | ||||||
Rep 155
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
01-19-2018, 01:12 AM | #32 | |
Rep 74
01-19-2018, 05:43 AM | #33 |
Rep 26
I have been to Bedford a couple of times with the M2 its a long track assuming you are doing the GT layout with 2 pretty long straits which will require heavy braking. The M2 is not the lightest sports car out there so it can be hard on its brakes especially when braking from 120 to 60. That being said Bedford also has plenty of nice S style corners so even if you don't want to push the car hard you can still enjoy the balance and torque. My advise don't floor it on the long straits change short stay at 90 m/h and go easy on the brakes meaning don't brake last minute, do 3-4 laps per outing then 1 full lap cool down etc. At least that's what i did on my first outing in the M2 in Bedford and nothing happened to the brakes they where and still are fine. Of course it all depends on your driving style and going easy on the brakes its way harder than it sounds on a track day as buffed up minis and old e46s m3 will be flying over you. Other than that enjoy the day and wish for some rain , you wont go fast but you will go sideways which is way more fun in my book just don't over do it as stewards get annoyed.
01-19-2018, 06:39 AM | #34 |
Rep 29
Go to the track, stick to your plan and have Fun! I have done what you are describing with my stock M2 with no issues.
Maximoosh49.50 chief1richard381.00 |
01-19-2018, 06:56 AM | #35 | |
Rep 390
Why but why a track day before break in service, it's like walking on the head... sorry. |
rich8566608.50 |
01-19-2018, 10:47 AM | #36 | |
Rep 190
Track pads are designed with higher coefficients of friction and designed to operate continuously at high temperature ranges - ranges generated by repeated threshold breaking from high speeds. In fact, they don't work very well at low temperatures. They can be a bit unsafe on the street especially just getting going on a cool/cold day. They also squeak like shit. How high the engine revs won't make much difference w/the pads. Its how fast the car goes down the straight, how late you break, and what speed you break to. Shifting at 5500 might make your terminal speed 130 mph rather than 140. However, if there a several long high speed straights on the track where you take off a lot of speed before the turn, then the temperatures are going to get petty high. It's only of you break way early and/or have short sessions that might keep the temps down. In beginner groups, folks typically are not consistently threshold breaking and it makes sense to use OEM pads with a fluid upgrade to start understanding the dynamics of the car. The same reason to use street tires. But once your braking technique improves, it's time for the track pads. Weight also makes a difference in how much heat will be generated and the M2 is not light. There are intermediate pads out there, but I think they're more like aggressive street pads than track pads once you're running in the intermediate group+ on fast tracks. Anyway, I wish I was at the track, too. Let is know how it goes. |
01-19-2018, 11:08 AM | #37 |
Rep 379
Just show with the expectation of having fun with stock pressures and all fluids (engine and diff) recently changed. Check tire temps after your sessions to keep the pressures under 40 psi all-around.
You will be fine on stock pads unless you are completely riding on the brakes or over-braking - your instructor should keep you in check. Do not get caught up in all kinds of feedback at this point, but keep the points in mind, you will learn as you go. Just go have fun and learn! |
01-19-2018, 11:33 AM | #38 | |
Rep 74
01-19-2018, 03:13 PM | #39 | ||||
Rep 29
Maximoosh49.50 |
01-19-2018, 05:57 PM | #40 | ||||||
Rep 1,124
ORIGIN M.3160.50 |
01-19-2018, 06:01 PM | #41 | |||
Rep 1,124
01-19-2018, 06:26 PM | #42 | |||||||
3161
Rep 9,134
01-20-2018, 11:46 AM | #43 |
Rep 74
So here's how it went.... car was fantastic, weather was not.... rain sleet and snow. Lots of slidey fun but easy to stay within the run in limits! Basically first run I went out with an instructor to get an idea of what the car could do. He assured me that they run BMW M4s from 200 miles full time on the track in the "M4 master experience" (basically a track experience run at most tracks in the UK) and then they get sold through the "approved used" programme so if you are after a used M4.... just dont get a white one, theyre all white! Second run was really wet. Lots of standing water. third run was pretty fun but was starting to get really dangerous. An e92 m3 which was being drifted ran out of talent and into the mud needing to be dragged out. Decided it was a good time to end the track time! Just left the car in sport and used the paddles throughout, it was too wet for anything else.
AndrewC198910931.00 AESZ4187.50 |
01-20-2018, 01:11 PM | #44 | ||
Rep 29
AndrewC198910931.00 Maximoosh49.50 |
