M2 Technical Topics > Track / Autocross / Dragstrip > M2 - Track Times
      03-20-2018, 08:45 PM   #199
arudeone
Originally Posted by ZM2 View Post
Nice times, guys. And, finally, we’ve got some competition at Summit!
isjoey and I were running 1:25s on 4S’s and RE-71Rs on Main last year. This year will include bigger and stickier rubber, AP fronts for me, maybe some aero from isjoey, and who knows, maybe a big turbo before the end of the year...
It’ll be a while before I can get back out there, but isjoey will be at PCA and NCC events. Looking forward to running with you all sometime.
Nice. Yeah, we might fill up a run group with all M2s...
M2joey299.50
      03-22-2018, 12:06 PM   #200
Paddy
Paddy's Avatar
73
Drives: 18' M2, AW
Chuckwalla Valley Raceway CW 2:04
      03-23-2018, 07:23 AM   #201
M2joey
M2joey's Avatar
300
Drives: M2, 335is, X5 M50i
Originally Posted by arudeone View Post
Summit Point Circuit
1:26.6
Stock Contis
1:23.4
Pirelli Slicks
ds1.11 pads
camber plates
Very nice!
      03-23-2018, 07:40 AM   #202
M2joey
M2joey's Avatar
300
Originally Posted by haiduk View Post
Nice to meet arudeone and iceboss23 this weekend!
Best of the weekend at Summit Point Main was 1:21.45
- MCS 2-way remotes
- GC camber plates -3 deg
- Hoosier R7s
- AP calipers front, stock rear
- PFC 11s
- Fabspeed downpipe w/MPE
Can't help but think how quick these cars could be with some weight removed and aero
Wow! Great time.
How much louder has the Fabspeed made your MPE? Also, what size R7s are you running?
      03-24-2018, 12:39 PM   #203
haiduk
Drives: 328xd touring
Originally Posted by isjoey View Post
Wow! Great time.
Thanks isjoey! I only had ~40 min or so in dry conditions last Sunday.. I think the car is capable of sub 1:20s as it's set up now, and I'm looking forward to exploring that
I'd say that it's marginally louder but a mellower and overall more pleasing sound with the Fabspeed DP. The R7s are 275/35 18 square.
Would like to try the Pirelli's that arudeone is running next.
M2joey299.50
      03-25-2018, 08:31 PM   #204
Fatbaker
Drives: 2017 BMW M2
M2 brake cooling
I have taken my 2017 M2 to Chin Track Days at Sebring 14 times since I bought it in Jan 2017. That is about 35 track hours or so. Somewhere between 1500 and 1700 track milea out of 8000 total on the odemeter.
I have been through three sets of OEM front rotors and two sets of OEM pads and one now have Hawk Street/Track pads on third set of OEM rotors up frint.
I have just replaced the rear pads but the rotors are still 8n spec (barely).
This weekend I again roasted the front rotors after only 3 1/2 track days. Prognosis is Hawk Pads overheated OEM rotors. Brake lines have Castrol React SRF and ECS steel braided brake lines so heat tolerable.
BMW in Tampa recommends more airflow as M2 brake cooling ducts are mostly cosmetic.
I have found Pegasas but not many other brake cooling duct kit vendors for M2.
Any suggestions?
      03-25-2018, 08:33 PM   #205
Fatbaker
Drives: 2017 BMW M2
M2 Brake Cooling
M2 brake cooling
Any suggestions?
      03-25-2018, 08:56 PM   #206
Twt
Twt's Avatar
634
Drives: 2017 M2
DIY brake ducts
If you look up my post about DIY ducts ( I am tech slow so I didn't post the link), you will see my home made solution. I have tracked my car at Road Atlanta, Sebring, Barber, AMP, NCM, etc using PFC08 pads and Motul 660. I also use temp strips on the calipers and flush/bleed after every weekend. After 50+ track days (lost count) I am ready for my third front rotor set and the second set of rears look great. I often run slicks and brake hard, but caliper temps stay below 450, on the outside. The brakes are amazing and the wear rate for pads and rotors is excellent for a car this fast and heavy. I think my low tech ducts really make a huge difference.
      03-26-2018, 01:09 PM   #207
M2joey
M2joey's Avatar
300
Any suggestions?
My initial thought is it is related to the Hawk pads. Although, there are a number of members who run them. Killing the rotors in three days - you are the first I have heard doing this. Which Hawk pad model? It must be a conflict in materials between the rotors and pads. You might want to give PFC 08 or 11 a try.
I when though my front rotors in 15 track days, some not full days. The rears were still fine although I replaced all of them as I am trying PFC 11s from 08s to start the year off.
      03-26-2018, 01:51 PM   #208
Fatbaker
Drives: 2017 BMW M2
Wow, thanks. Sounds like that does the trick. I will look for that post on homemade ducts.
      03-26-2018, 02:24 PM   #209
Fatbaker
Drives: 2017 BMW M2
On the Hawk pads they are the Street/Track compound
      04-01-2018, 10:36 AM   #210
Twt
Twt's Avatar
634
Drives: 2017 M2
Went back to Road Atlanta last month with BFG G - Force R1 285/35/18 square and PFC 08 pads to improve my times:
Attachment 1796956
      04-03-2018, 09:45 AM   #211
M2joey
M2joey's Avatar
300
2:11.7s at VIR this weekend. Both in traffic with points, I definitely had faster laps but they were blocked. After reviewing the video it appears I am over driving the car a bit as well. The car certainly has much more!
Camber plates
PFC 11s
RE-71Rs
      04-11-2018, 07:20 AM   #212
arudeone
VIR Full
2:09.13
ds1.11 pads
camber plates
Pirelli DH Slicks
Best time for day 1 and was looking at 2:08.5 predictive when I blew my left rear tire to start day 2. Did some juggling with a friends mostly toasted 305/660/18's and got them mounted during lunch and salvaged the day...but they were a little to fried (or maybe I was) to better my time. Next trip.
M2joey299.50
      04-11-2018, 01:29 PM   #213
M2joey
M2joey's Avatar
300
VIR Full
2:09.13
ds1.11 pads
camber plates
Pirelli DH Slicks
I dropped my Summit Point best to 1:24.3 this past weekend. With new RE-71Rs I feel 1:22s is possible, we will see.
      04-11-2018, 01:51 PM   #214
arudeone
Very Nice. The new pavement is really great. I'm signed up for NCC on the 11th so I'll see you there. Friday is set and Saturday waitlisted...
M2joey299.50
      04-11-2018, 05:04 PM   #215
iceboss23
Drives: 2016 M2
Yeah I need to register for this if I still can. Was a great time at VIR. Bettered my previous PB by 2 sec to 2:11.62 still just RS-4s and PFC 08 pads.
M2joey299.50
      04-15-2018, 07:03 PM   #216
dvas
dvas's Avatar
518
First track day of the year yesterday with BMWCCA at Lime Rock Park. Trying a new setup with Apex wheels 18x10 and Nitto NT01 275/35 square. Running 3.2 degrees of camber, makes it look pretty mean.
The temps were very accommodating hovering in the 60s for most of the day. Car felt good and the tires have more in them than what I pushed. Happy to be in the 1:01s at the first track day of the year.
      04-15-2018, 09:38 PM   #217
just blaze
Drives: 2018 M2 Alpine White
Nice. Just wondering what size spacers you are running with the wheels? Also, What kind of mic are you running with the I'm assuming GoPro setup?
instagram: @ sf87_m2
      04-15-2018, 10:29 PM   #218
dvas
dvas's Avatar
518
Thanks. Running 12mm spacers in the front. Good clearance of the coilovers and just enough for the fender liners and top of the wheel well.
I was disappointed with the video in terms of perspective and exposure as I just assumed that my last settings were going to be carried over and didn't check. The GoPro is a Hero 3. Microphone is a basic lavalier microphone that I have wire out back through the trunk and taped to my license plate. Helps get the exhaust sounds rather than the interior wind noise.
      04-21-2018, 05:13 PM   #219
skiparock
skiparock's Avatar
Drives: 2018 M2 lbb manual
18 Manual m2, fabspeed catted dp
Harris hill
Wet surface
18 M2 lbb manual exec (Euro Delivery) and PDC
11 e92 335i xdrive BSM/PE (Sold)
09 335i xdrive Monaco Blue (Traded)
02 330xi (Sold)
      05-06-2018, 11:05 PM   #220
recycledAlva
Drives: MY17 BSM M2
2017 BMW M2  [0.00]
DCT
Mods: catless dp, MPE, afe lowering springs, MHD stage 2
Running Michelin ps4s: 255/35r19 and 275/35r19
Autoclub speedway Roval config: 1:58.2
