07-09-2018, 08:24 PM | #155 |
Wheelsucker
200
Rep 1,280
didn’t reuse the funky gasket in the stock DP, didn’t freak out over torque specs and you know what, no leaks and it works perfect. Lighten up guys it’s exhaust, it will be fine.
07-09-2018, 10:44 PM | #156 |
Rep 68
07-10-2018, 09:13 AM | #157 |
Rep 1,466
Neither did I the first time, and I didn't have any problems either. I'm not sure I'd replace the down pipe to exhaust clamp if I did it again either, even if it does have a crush section; I'm just not sure that it's necessary to get a seal. It probably helps, but getting a seal is easy without it as well.
I was asked for all the torque settings, so that's why I posted them; not because I thought they were all critical. IMHO, the critical torque setting is the one for the stiffening plate, particularly as they're torque to yield. You could probably get away with these just being "nice and tight" but they're actually part of the front suspension, and I'd rather not mess with that, but to each his own.
2018 ///M2 LCI, LBB, 6MT...
07-10-2018, 09:32 AM | #158 |
Rep 699
07-10-2018, 09:49 AM | #159 |
Rep 1,466
I know you're not specifically asking me, but I'll answer anyway.
The first time I fitted my down pipe, I reused both the V Clamps. The lower, down pipe to exhaust clamp has a crush section in it the effectively conforms to the shape of the down pipe outlet flange. When I reused the lower clamp, I didn't have the crush section at all, because it was stuck on the stock down pipe. It sealed fine. This time I used a new clamp and it conformed the new crush section to my new down pipe. In theory it probably seals better, but in practice, the crush section wasn't essential to get a good seal. |
07-10-2018, 09:57 AM | #160 | |
Rep 699
Thanks. So the lower clamp has a seal built into it? I ask because I'll be changing mine out soon and want to have everything necessary when I do it. I'm definitely replacing the shield bolts. |
07-10-2018, 01:17 PM | #161 |
Rep 1,466
07-10-2018, 01:45 PM | #162 |
Rep 699
07-10-2018, 02:50 PM | #163 | |
Rep 929
07-10-2018, 02:59 PM | #164 | |
Rep 929
Just thought of another question. I'm planning on jacking up the car and placing it on jack stands so passenger side is up. Do you think it would be okay to remove the stiffening bolts and placing them back with that sort of geometry of the car? Just wondering if the car should be on a lift instead so the front suspension doesn't have an uneven load if those bolts are part of the suspension. |
07-10-2018, 04:53 PM | #165 | |
Rep 1,466
07-10-2018, 05:06 PM | #166 |
Rep 699
And how exactly do you do that? If you use your floor jack on the jack points, there's no where to put the stands. I was playing with mine this weekend and cut a bunch of 2x10's up into 10x12 inch pads. I would jack each side and stack them under the tires. By going side to side I could stack them 8 high which put each wheel 12" off the ground. There will be plenty of room like that to swap cats once they come in. Park brake was on and rear wheels were chocked.
07-10-2018, 05:25 PM | #167 |
Rep 391
Don’t go that high with the blocking the wheels. I had the best height at an 8 inch block under wheels and jack and lower car onto them. If you go higher than 8 inches then you’ll have to reach higher up to the top clamp, I prefer to be lying flat and be able to reach it. Otherwise you have to do a partial crunch/sit up to reach it and it’s harder to do. Probably will depend on your belly size and length if arms though.
07-10-2018, 05:27 PM | #169 | |
Rep 699
Great info, thanks. |
07-10-2018, 05:40 PM | #170 |
Rep 1,466
There is a central Jack point in the middle of the stiffening plate that you can reach from the front of the car. My jack, although low profile, isn't low enough to get under the front of the bumper, so I put a couple of pieces of wood under one wheel first just to give me an extra half inch to get the jack under.
Once you can jack from the central point it's easy to put two jack stands under the sides at the same time. The car stays remarkably balanced when jacked in the center point, though I guess it should. |
07-10-2018, 06:33 PM | #171 | |
Rep 699
07-10-2018, 06:47 PM | #172 |
Rep 112
Drives: 2017 BMW M2 - Mineral Gray
I bought a pair of of the HD rhino ramps from autozone, work well with jack stands added in for extra safety.
07-10-2018, 08:19 PM | #173 | |
Rep 929
07-10-2018, 09:46 PM | #174 |
Rep 2,197
Sorry for asking so many (silly) questions, first time doing a downpipe
Did you guys use antiseizes and threadlockers? Going through the akra manual, they state it in the symbols, but doesnt seem to be used in the guide itself |
07-10-2018, 10:17 PM | #175 | |
Rep 1,466
I had to switch back to the stock down pipe temporarily, and then back to the Fabspeed, in all three times I had to remove the O2 sensors, the lower one was seized in place. I ended up using a Map gas plumbers torch to heat the threads of the O2 sensor and then un-did it while it was still hot. Using this approach, they un-did pretty easily.
Who?484.50 |
07-11-2018, 01:18 PM | #176 |
Rep 699
Update on the bolts. I ordered 8 bolts today for a delivered price of $29.15. That's about $3.64 a bolt. I found them on E-Bay and they are OEM bolts. Ebay has a sale today for 15% off if you enter "PRIMOSALE" when you check out. For that price I feel it's silly not to replace them.
KevM2724.50 |
