02-21-2018, 01:59 AM | #1 |
Rep 599
Drives: M2, C63s, 718 Cayman GT4
Bad alignment or?
Was the alignment done incorrectly? On center it pulls slightly right, and I'm guessing it has to do with the actual values here.
Either that or they didn't center the steering wheel on alignment. Speaking of which can someone chime in on what are good values to have for track/street set up? I'd like to not have to adjust it Everytime I switch between the two. Thanks
2018 MG M2 - Ohlins R
02-28-2018, 02:16 PM | #2 | |
Rep 379
Looks like you have camber plates based on what I am seeing for front camber. Depending on where you are in regards to track driving a little more camber would be good. Say from -2.4 to -2.7 to start. A little more in the rear, to -1.8 or -2.0. I would leave everything else the way it is until you learn why you need to change it. Looks good though. |
