M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > Window streaking or smearing
      02-07-2018, 11:31 AM   #1
Tryboz
Drives: 2020 330
My 18 M2 gets window streaking or smearing from the electric motors i believe. I used to have on my M4 as well but not my x5, assume has to do with coupe's frameless??
Has anyone fixed it or added window tint and it has gone away? I'd like to tint but not sure if streaking or smearing changes or ruins tint. Dont see any posts so assume issue remains...
      02-07-2018, 12:38 PM   #2
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
My e46 and e92 had this issue as well so i suspect you're right about it being related to frameless windows. Tint didn't help, if anything it made it worse since the film adds thickness and black shows the streaks much more than clear glass.
I just wipe it away with a micro fiber cloth. Nothing else you can really do about it.
      02-07-2018, 03:43 PM   #3
MZWIE
Means there some goo stuck on the seal. Take some alcohol and clean it thoroughly. May times it's from bird stuff or bug juice.
      02-07-2018, 08:02 PM   #4
sh_kross
Puerto Rico
92
Drives: Long Beach Blue M2
2018 BMW M2  [10.00]
Hmm, I've gotten the streaking from day one. Haven't had anything but water on the windows.
I was going to mention it to at the service center when I went for the first service. It seems worse on the driver's side for me, the windows even stay all wet after pulling them up after a wash.
      02-07-2018, 09:33 PM   #5
AndrewC1989
Only problem with that theory is that the smears happen on the INSIDE of the glass. Whatever causes it is in the door panel from the factory. Probably some sort of grease or lubricant on the window lift motor. I've had it happen regularly on my last 3 bmw's. It's not bird shit, trust me.
      02-08-2018, 09:01 AM   #6
MZWIE
Junk gets on the inside as well. Including water after a wash. As soon as you take the window down it drags junk in there.
      02-08-2018, 11:17 AM   #7
mjsaville
101
Drives: M2 LLB - Arrived 4th Mar 2017
I've seen this on VW Polo's + Golfs. Usually passes after a couple of months of normal use. MJ
      02-09-2018, 01:06 PM   #8
David1
David1's Avatar
Drives: 09 E92 09 X5
It is not junk getting in. It is track lubricant. All of my newer BMWs have done this from day one. Each one I have had to wipe the extra lube away from BMWs sloppy application. Easy to do when getting the windows tinted since my installer pulls the panel back to get the tint down lower on the window.
AndrewC198910931.00
