02-03-2018, 06:10 PM | #1 |
Rep 6
Clanking sound when pulling e-brake, normal?
When I am going about 25mph in my M2, and pulling the e-brake lever, it makes a clanking sound. And I asked the tech during my break-in service, he said it is normal. and that the brake pad inside the rear brake drum is shifting. anyone else have this sound?
02-09-2018, 03:56 PM | #2 |
3843
Rep 54,376
Drives: F80 M3
The parking brake shoes sit against the backplate and it's all metal to metal contact. If they are stuck, have rust or have not been used in a while it is completely normal to get a clanking sound when they finally shift away from their static position. Some high-quality high temp grease or anti-seize compound between the shoes and backplate should help.
There are springs in the parking brake system as well so those are another source for noise. |
02-10-2018, 10:58 AM | #3 |
Rep 960
Why are you pulling the hand brake at 25 mph? Are we engaging in a drift? Probably easier pop the clutch....
Lol |
AndrewC198910931.00 |
02-17-2018, 02:08 PM | #4 |
Rep 6
Thanks guys. I understand that they shifts and will make a noise. Just want to see if others are getting the same noise. Anyhow, I don’t pull on it often.. I do it when I don’t feel like using my brake foot.
