01-21-2018, 10:57 PM | #1 |
3837
Rep 54,342
Drives: F80 M3
Swift Spec-R Springs For F87 M2 - Show your interest
How many here are looking for a linear rate sport spring? Swift Springs may have a set in the near future but needs to see how many are interested to move forward.
01-22-2018, 10:11 AM | #3 |
3837
Rep 54,342
Drives: F80 M3
01-23-2018, 12:10 AM | #4 |
Public Last Class
97
Rep 244
Drives: 2018 M2 DCT LBB
01-23-2018, 12:52 PM | #5 |
3837
Rep 54,342
Drives: F80 M3
01-24-2018, 10:03 AM | #9 |
Da Baus
283
Rep 259
What benefit is this over progressive springs?
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
01-24-2018, 07:01 PM | #10 |
Public Last Class
97
Rep 244
01-24-2018, 11:52 PM | #11 | |
Rep 4,551
Drives: 2015 328d xDrive
The idea is that they would be suited for both track and street use since they start off soft and then get stiff under heavier force. That would be the theoretical pro. The con is that while they are suited for two purposes, it comes at the cost of performance. At the track or under heavy turning they require more force/time to fully compress/stiffen and this will add some body roll as a result. Linear on the other hand compress evenly and while this may be harsher for daily use the performance benefits are better. It does one thing well and one thing poorly vs having the kind of decent all around ability progressive springs would have. In summation, linear are more performance oriented, and progressive would be more comfort oriented. That's how i understand it. Feel free to correct me. |
NYC Bimmer259.50 bollinm25.00 |
01-25-2018, 12:25 PM | #12 |
Rep 105
^ this is true.
I would describe linear as being more predictable as well. you know exactly how the suspension is going to react, because it does the same way during all situations, assuming everything else is equal. Linear is less supple, more predictable. Progressive is more comfort and compromise. It's all about what you want out of the car. |
bollinm25.00 |
01-30-2018, 04:22 PM | #14 | |
Public Last Class
97
Rep 244
AndrewC198910929.50 |
02-01-2018, 09:30 PM | #15 |
3837
Rep 54,342
Drives: F80 M3
show your hand if you are interested in the Spec-R for the M2
02-02-2018, 11:44 AM | #17 |
3837
Rep 54,342
Drives: F80 M3
02-05-2018, 10:14 AM | #20 |
3837
Rep 54,342
Drives: F80 M3
