03-14-2018, 03:53 AM | #23 |
Rep 4,204
After dropping it whether springs, HAS kit or coil overs an alignment is a must to bring the numbers back in close to factory spec and feel. From there you dial it for what your trying to get out of it
03-14-2018, 04:11 AM | #24 |
Rep 844
Almost a year since I got my alignment after I lowered with eibach springs. So glad this solved the issue. Car is now back to how confidence inspiring it is. It's safe to say it's back on rails.
03-14-2018, 07:38 AM | #25 | |
Rep 4,204
08-26-2019, 01:55 PM | #27 |
Food Critic
1084
Rep 1,015
At first I thought it was my suspension but it seems like it's not - it's more of a steering thing. Now that I think about it the noise I hear is when I'm turning especially at low speeds.
09-17-2020, 09:58 PM | #28 |
Rep 208
So I took my car into the dealer and mentioned the wheel shim TSB. They reproduced the clicking noise while turning, but they stated it is "normal for Michelin Pilot Super Sport Tires. Referened SIB: 36 02 19 which describes normal operation of sticky summer tires at high steering angle". Anyone have access to this other TSB to provide the full context? This seems like a BS diagnosis to me.
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9" |
09-18-2020, 04:48 PM | #29 |
Rep 438
I have this same problem , i get a "ping" when turning at low speeds...surprised so many people have this issue and not much info on what it could be... i have read about it being bearings , upper suspension mounts , even loose sway bars...but nothing definitive.
09-14-2021, 11:29 AM | #30 |
Rep 406
Drives: BMW 328xi BMW X5 F15 BMW M2
This fixed it. I did it today.
Even bmw dealership couldn't fix
09-17-2021, 09:06 AM | #32 |
Rep 1,376
Is this the noise any of you were experiencing?
I have done the new pinch bolt method with grease, bent the clip back and also tried friction plates inbetween the hub and brake disc. It always comes back within a few days, it's almost like every time I lift the car in the air it relaxes something until it settles a few days later
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
10-06-2021, 07:19 PM | #34 |
6626
Rep 4,145
Drives: '18 M2 6MT
It's my understanding that the clicks sound the same, but there are different actions that produce them, and different sources of the click, which makes things very weird.
My car, for example, doesn't produce the sound unless I'm cornering hard to the right, or entering a driveway. It's always on the driver's side as well. |
10-13-2021, 03:50 PM | #35 |
Rep 180
Drives: 2017 BMW M3 Competition (LCII)
I note that he torqued the pinch bolt down to 55 ft lbs. Two things I would like to discuss: 1. As the pinch bolt is now fully wet because of the anti-seize, shouldn't a different torque value apply, as the factory torque value is based on a dry bolt thread? 2. Shouldn't the pinch bolt and fastener be replaced when removed (as I understand they're a one-time use set)? |
10-13-2021, 04:03 PM | #36 | |
6626
Rep 4,145
Drives: '18 M2 6MT
The YouTuber in this video is a super cool guy, but not known for being a stickler with such things. |
TheHunterHofman225.50 H20neun112.50 |
10-13-2021, 04:21 PM | #37 | |
Rep 180
Finally, shouldn't the pinch bolt and fasteners be torqued under load, and if so, how would you be able to do that, as you can't really get a torque wrench in there with the wheel on I presume? |
10-13-2021, 06:12 PM | #38 | |
6626
Rep 4,145
Drives: '18 M2 6MT
10-14-2021, 02:01 AM | #39 |
Rep 180
10-14-2021, 07:27 AM | #40 |
6626
Rep 4,145
Drives: '18 M2 6MT
It's the rear suspension that has to be torqued under load. I've not seen a single video of anyone doing the front suspension under load. This is a simple TTY bolt.
TheHunterHofman225.50 |
10-14-2021, 07:36 AM | #41 |
Rep 180
I have checked with 2 separate BMW dealers in my area and both told me the torque value (dry) for the pinch bolts should be 56NM (i.e. 41 ft-lbs). The guy in the video seems to be adamant that it is 75NM (i.e. 55 ft-lbs). I wonder what I should then torque the pinch bolts with, considering I'll put anti-seize on it.
10-14-2021, 07:37 AM | #42 |
Rep 180
10-14-2021, 10:52 AM | #43 | |
6626
Rep 4,145
Drives: '18 M2 6MT
Did a quick google search, looks like the new torque spec should be 42NM. |
10-14-2021, 11:40 AM | #44 |
Rep 180
Interesting stuff, I have found the same in the meantime. I wonder if anti-seize would be the best way to lube up these pinchbolts, would silicon grease or ceramic grease work too, you think?
