12-11-2023, 12:11 PM | #89 |
Rep 3,548
Unless it was coded off.
12-11-2023, 01:05 PM | #90 |
The Seeker
14143
Rep 3,412
12-11-2023, 02:10 PM | #91 |
Rep 7,337
I have a glass coating on my windshield so I rarely use the wipers. So that could be why, but I never had this issue with the OEM Pagid pads.
Still, what I experienced was just like what MPhatic mentioned about his CCBs. I had to basically pump the brakes a few times to get anything. I also got some pulling to the right. |
12-11-2023, 02:19 PM | #92 | |
Rep 7,337
12-11-2023, 05:30 PM | #93 |
Rep 3,548
It does have that function by default. It's one of the things I see get coded off when people have "improved track braking" coding done.
chris7197381.50 |
12-11-2023, 05:57 PM | #94 |
Rep 211
Drives: 2021 F87 M2 Competition
I get the same issue with the OEM setup (2NH) when driving in the rain at highway speeds. I can go hours without touching the brakes in some cases and the first application of the brakes after that can be very sketchy; i.e. applying moderate pressure does nothing for about 2-3 seconds before the brakes actually function. Should probably make it a habit to lightly apply the brakes after about 15 mins or so in case an emergency situation arises
2021 F87 M2 Competition, Sunset Orange, 6-speed
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family) |
chris7197381.50 |
12-11-2023, 06:27 PM | #95 | |
Rep 7,337
12-11-2023, 07:11 PM | #96 | |
The Seeker
14143
Rep 3,412
Meh, I never drive the car in the rain so it doesn't really matter much, but it's good info. |
chris7197381.50 |
12-11-2023, 07:27 PM | #97 |
Rep 7,337
Yeah, I don't have any of that stuff coded at the moment. I had my wipers set to off, so maybe it wouldn't work for me, but I can't say I noticed it even when I was using them all the time.
12-12-2023, 02:30 AM | #98 | |
Rep 8,972
I also personally wouldn't code it out for "track" braking as I don't drive hard on the brakes when its raining... |
01-08-2024, 02:19 PM | #99 |
Rep 7,337
So, it rained hard again and same thing. The car pulls to the right until the brakes are dry, and it takes more than just a tap. They are fine once dry but the rotors quickly get wet again in heavy rain. I don't think the brake drying really is enough to make a difference. Should I remove the caliper and re-seat or inspect them? Not sure if there is a possible problem or not.
I may go back to OEM pads or try Endless MX72 / MX72 Plus because it's bad when it's pouring. It's a shame because I love the feel, quietness, and lower dust in general. |
01-29-2024, 06:51 PM | #100 | |
Rep 216
I've coded in euro MDM to the diff myself using e-sys, but I don't think I've coded any braking settings explicitly. (I do not track) I've been interested in these carbotech 1521 pads for a while. Their factory/shop is right down the road from where I live, I'll probably pick up a set myself in a year once I wear down the stock pads/rotors. Your pulling to the right issue - something's not balanced there. Perhaps an installation issue (misalignment, shim problem, etc.), or a brake bleed is needed, or some other inconsistency between the left axle and the right axle where the right axle is more effective under those conditions? |
chris7197381.50 |
01-29-2024, 07:56 PM | #101 | |
Rep 7,337
01-29-2024, 08:23 PM | #102 |
Rep 3,548
Strange you guys are having such issues. I had a wet track weekend and total downpour long drive home and didn't have any issues like you guys are experiencing even with my track pads in the whole time.
chris7197381.50 |
01-29-2024, 08:31 PM | #103 |
Rep 7,337
It could be temperature related. This is the first winter I am daily driving the car. It's been below 45 F so far every time I have noticed this. Getting the brakes warm seems to keep it at bay for some amount of time, the problem is on the highway they cool off. It's definitely water related though because I actually drove the car during a snowstorm 2 weeks ago and I had zero issues.
Fred Conoway365.00 |
01-29-2024, 11:59 PM | #104 | |
Rep 7,510
01-30-2024, 12:05 AM | #105 |
Rep 7,337
01-30-2024, 12:24 AM | #106 |
Rep 7,510
Interesting, I didn't expect that from a carbotech pad.
I'm trying out the Paragon p2's in the summer, maybe that'll be a good low dust alternative for you (I don't think Paragon stocks it for the 6 pot calipers so you'll have to place an order and wait). It's also got a pretty good bite so it won't be on the less aggressive side like the akebonos on the blue brakes.
01-30-2024, 04:28 PM | #107 | |
Rep 211
chris7197381.50 |
02-05-2024, 12:28 PM | #108 |
Rep 71
I went back to the same BMW dealer today they did another “health check”
The same mechanic said “I advise changing the rotors when you next change the pads” Wish they’d said that the first time round I’d guess I’d got at least another 20k miles And I don’t have to spend £4.4k at only 27000 miles |
