04-17-2018, 08:43 PM | #45 | |
7906
Rep 11,785
removing 100 lbs doesn't even get back to M2 base.. Which basically means.. forget about calling it a " proper" CSL. I guess they could dredge up the " Lightweight " (LTW) moniker that they used for the US E36 M3... I can hear it now.. " it's the first ever... M2 LIGHTWEIGHT.. " Let's see how BMW did save weight on the M4 GTS... https://www.torquenews.com/1084/15-w...-weight-m4-gts How did BMW M reduce weight in the M4 GTS? Outside, the high-performance coupe gets a newly designed hood, roof, adjustable front splitter and adjustable rear wing which are all made from carbon-fiber-reinforced plastic (CFRP). It sits on CNC-machined aluminum mounts fixed to the CFRP boot lid to also minimize weight. The rear diffuser, made from carbon fiber along with the rear wing, optimizes the flow of air and reducing lift at the rear axle. M4 GTS also is fitted with a titanium muffler, which allows a weight saving of 20 percent according to BMW M. Cabin weight-saving optimization BMW M’s rigorous weight-saving measures continue through the interior of the car. Inside, M4 GTS gets carbon-fiber bucket seats, a lightweight center console, lightweight rear seat panelling and boot area partition, and special lightweight door and side panel trim. The sports car even comes with door pull loops in place of solid door handles to save additional weight. Underneath the dash, the instrument panel bracing tube is made from lightweight carbon fiber. Last edited by M3 Adjuster; 04-17-2018 at 08:57 PM.. |
04-17-2018, 09:00 PM | #46 | ||
Rep 13,097
///M is art ↔ Artemis
04-17-2018, 09:37 PM | #47 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
I've yet to find anything definitive that says one way or the other if they are actually die-forged wheels. some materials have said they are forged, and other materials completely omit that phrase (without actually saying cast explicitly).
04-17-2018, 10:32 PM | #48 | |
Rep 9
I'm assuming there should be no problem ordering a set of 763 Ms from the dealer, even if you don't own an M3 CS, right? |
04-18-2018, 12:28 PM | #50 | |
Rep 13,097
Hm, BMW could have used that blank button on the center console to toggle rev-match on/off for the 6MT. Like the "SPORT" button in the Cayman GT4.
04-18-2018, 12:37 PM | #51 | |
Rep 339
instagram: @ sf87_m2
Danne_48516.50 |
04-18-2018, 12:40 PM | #52 | |
this is the way
18142
Rep 8,520
I found more info on this in the document 20180413_The_new_BMW_M2_Competition_Longversion.pd f The new BMW M2 Competition comes as standard with a six-speed manual gearbox, which stands out with its compact design and low weight. The use of a new type of carbon-fibre friction lining enhances shift comfort. An engagement speed control function, which blips the throttle on downshifts and lowers the engine’s revs on upshifts, makes gear changes even smoother. This also lends the car additional stability during hard driving on the track. Switching off the DSC deactivates the engagement speed control function. Wet-sump lubrication prevents any sloshing of the transmission oil and ensures all components benefit from an efficient supply of oil. |
M3 Adjuster7905.50 Danne_48516.50 |
04-18-2018, 12:43 PM | #53 | |
Rep 7,594
Drives: '19 M2C
This just blows my mind. Give me control over Rev-match and ASD via a button or idrive. The simple fact I cant turn off Rev-match will push me into another DCT. Last edited by ChrisK; 04-18-2018 at 01:08 PM.. |
04-18-2018, 12:58 PM | #54 |
Rep 3,659
Drives: 981 Cayman GTS
The fact that you have to turn the DSC off in order to disable rev-match in M2 is just crazy. I just learned about this. In M3/M4, Sport+ will do it without forcing you to turn off DSC. I always drive in Sport+ with DSC off so not a big deal for me but I don' think this is a clever solution to disabling rev-match for people who don't feel comfortable turning the traction control off.
04-18-2018, 01:08 PM | #55 |
Rep 13,097
Thanks for your efforts, MR.
Though beware of that title when tackling the topic of weight and 'body mass index'. And about your video: nicely done (there are only a few minor inaccuracies).
04-18-2018, 01:09 PM | #56 | |
this is the way
18142
Rep 8,520
04-18-2018, 01:09 PM | #57 | |
Rep 7,594
Drives: '19 M2C
04-18-2018, 02:51 PM | #61 | |
Rep 60
04-18-2018, 03:24 PM | #62 | |
Rep 13,097
"MR: If you would spec a M2 Competition what would you include in the specification? Which color would you go for? DCT vs manual?And back in 2015 he singled out the manual only BMW 1M as his "favorite M car from the past" (see here).
M3 Adjuster7905.50 |
04-18-2018, 05:02 PM | #64 | ||
Rep 2,856
MR |
04-18-2018, 05:35 PM | #65 | |
Rep 794
