BMW M2 Forum > M2 Photos, Videos and Builds > >>> 2PUTT M2C Thread <<<
      09-13-2019, 02:29 PM   #45
2PUTT
Drives: F87
Originally Posted by AZ-Wildcat View Post
Did you lower the rear compared to earlier posts?
Wheels look sick!
no, height settings have not been touched since the car was lowered. the rear is at the lowest setting (without the perch).
thanks!
      09-14-2019, 03:06 PM   #46
M3 Alex
M3 Alex's Avatar
Drives: 2018 ZCP M3 - Avus Blue
More pics of the new wheels! What size/offsets did you get?
      09-14-2019, 03:13 PM   #47
2PUTT
Drives: F87
19x9.5 ET28
19x10.5 ET45
all the information you need is in the first and second post over here >> https://f87.bimmerpost.com/forums/sh....php?t=1600430
M3 Alex122.50
      09-16-2019, 08:58 PM   #48
2PUTT
Drives: F87
Post Alignment Pics
a few people have asked for detailed pics of the car with the new wheels and the clearance with it being lowered.
apologies in advance for the cell phone pics.
some notes:
- car was not parked on level surface
- alignment specs roughly -1.6 fronts and -1.9 rears
- no spacers (5mm fronts made the tires rub the liner)
Rear Passenger
Front Passenger
Front Driver
Rear Driver
Whole Car Side Shots
Appreciate 7
FreeDarko217.00
speedsnice1206.00
CrazyK104.50
JTO245276.00
DARKMTTR229.00
M3 Alex122.50
      09-27-2019, 10:00 PM   #49
rideontwo
Drives: VaNOs
O/T but didn't you own a Audi TT at some point?
      10-01-2019, 07:43 PM   #50
2PUTT
Drives: F87
i've owned a bunch of Audis but never a TT. i did own 3 S4 Avants with TT. =)
      10-02-2019, 05:27 PM   #51
Advanced
82
Drives: M2 Competition
some notes:
nice wheels! are they in anthracite? i'm having a hard time deciding on that or race silver...
totally changed my mind of these wheels after seeing them on your car!
question about the -1.6 camber in the front, camber kit required or you can achieve this just by alignment only?
      10-02-2019, 11:33 PM   #52
2PUTT
Drives: F87
thank you.
- Yes. They are anthracite.
- -1.6 degrees was done without any camber kits. it was from the alignment shop (i originally asked for -2).
      10-04-2019, 02:10 PM   #53
Advanced
82
thank you.
so i assume you didn't run into the problem that some other people ran into with needing a 5mm spacer to clear the suspension or something? i read it in some other threads... or even in the Apex wheel thread i believe it was
i'm on kwv3 and my car is pretty slammed... if i went with your same size wheels and tires is it safe to say that i'm not going to need any spacers either?
      10-04-2019, 09:46 PM   #54
2PUTT
Drives: F87
i guess it all depends on where your front coilover perches are sitting. from what i have read, the perches and/or the progressive springs can sometimes be wide and cause some rubbing with the inner part of the wheel/tire. i had 5mm spacers on my initial install with the wheels and the front tires were rubbing the front fender liner. i suggest that you call Apex directly. they have great support and can offer you guidelines with your personal setup. best of luck and share your pics once you have it all setup.
      10-22-2019, 07:43 PM   #55
2PUTT
Drives: F87
trees are starting to tell me its Autumn...
      11-18-2019, 09:08 AM   #56
2PUTT
Drives: F87
Well, life took over once again and pressed on fast forward. Picture below was taken after a quick powerwash to clean up the car to get rid of the road grime after 1000 miles driven this weekend. No hands touched the car. Just pressured water/soap and rinsed...then drive.
Xpel and Nanolex Ceramic coating were done by DetailersDomain back in Jan 2019. It is still doing its job VERY WELL!!
she tends to be thirsty (aka small tank)...
      11-27-2019, 03:05 PM   #57
2PUTT
Drives: F87
so, we went ahead with the AA midpipe and Remus Race exhaust. my first choice for the axle back were the Remus Sport but i was informed that they were sold out and that Remus did not plan on shipping any new items to the US until 2020. i went with the cheapest tips and had them powdercoated.
      11-28-2019, 01:47 PM   #58
TUNEDM3
Stay Ripping
60
Drives: 1M
Nice...any pics of it installed?
THE GOBBLER- S.O.H
      11-28-2019, 08:25 PM   #59
2PUTT
Drives: F87
sadly, i was not able to take after pics. below is a pic posted by mike@x-ph.com. hope this helps.
prompt292.00
      12-02-2019, 07:41 PM   #60
2PUTT
Drives: F87
Thumbs up Apex Cleanup
It was time to put the summer wheels/tires away for the winter and mount the winter set. Before storing the summers, I decided to clean them with some detail spray and a MF towel. It was close to being effortless. The brake dust and road grime just wiped right off!!
Some history...I ceramic coated these wheels with Nanolex purchased from DetailersDomain before they were ever mounted to the car. Click this LINK for the post that shows this coating process.
Here are the pictures...
BEFORE
DURING
AFTER
mcvaughan704.00
      12-05-2019, 11:22 AM   #61
jessetaylor1
Drives: 2018 AW LCI
Loving all these updates. Car looks great.
      12-06-2019, 06:55 AM   #62
2PUTT
Drives: F87
Thank you!! Appreciate the feedback.
      12-13-2019, 03:17 PM   #63
2PUTT
Drives: F87
Winter mode
Well, winter mode is on! Decided to go wider with the rears.
History:
When I purchased the car in Jan 2019, there was not much information available as far as winter tire fitment. I spoke to TireRack and opted for a square 255 setup with Pirelli SottoZero3 tires. This left the rear wheel edges to be very exposed.
Now that I switched to 275 rears, they sit much better.
Anyone interested in buying slightly used 255/35/19 Pirelli Sottozero3? Let me know.
      12-13-2019, 03:28 PM   #64
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
How does the ride compare once you removed the perches? I wouldnt mind going a little lower but taking out the perch seems a bit extreme for me.
And i assume you only removed the rear perches, is that right?
      12-13-2019, 04:18 PM   #65
2PUTT
Drives: F87
correct. i never drove them with the perches. my guess would be that they would ride the same way. the perches act like a spacer and doesn't really assist in any bump absorption.
      12-13-2019, 04:32 PM   #66
infinitekidM2C
true, it doesn't add any travel in the compression
