10-26-2023, 02:59 PM | #1 |
Rep 203
Turbo Wastegate Actuator Malfunction ??
A few days back my car went into limp mode for the first time in my 3 years of ownership…currently at 75,000km.
The next day there was a check engine light as well and a very rough start up. I took the car to fill the gas tank as it was just into the reserve and I read that can get you into limp mode. Later that day the car went out of limp mode but check engine light remained. The following day, the cel was gone and the car was still out of limp mode….running like normal but I drove it very gently and very minimal distance. Today I had my mechanic take a look at it. Said it was a waste gate actuator malfunction. Possibly caused by an electrical short, advised to leave alone unless a cel or limp mode returns….since it was running fine now. My question is this, is there a decent chance this is a one time thing and doesn’t return? Or is it likely I will continue to have problems? I drive out of town frequently and am worried about going into limp mode while far from home, or any possible damage caused to the engine or turbo. On the other hand, it’s a fairly costly repair I’d rather not do if I don’t have to. Thanks in advance. Last edited by Sundinisagod; 10-26-2023 at 03:07 PM.. |
11-02-2023, 12:30 AM | #2 |
Rep 48
I had this same thing happen to me last week. I’m at 105,000 miles, 2018 M2.
Saturday night. Drivetrain malfunction going 80mph on the highway. Pulled over at a gas station. Restarted the car with the same error code and CEL. Had about 1/4 tank of gas. Drove home super conservatively. Didn’t drive it again until Monday morning, filled the gas tank to half…drivetrain malfunction went away…but CEL remained. Drove to work with the CEL on. 8 hours later started my car up no CEL. My shop ran the errors on Tuesday morning. Wastegate malfunction. Been ok since. But no real solution. |
Sundinisagod113.50 Downunder9955.50 |
11-18-2023, 11:55 AM | #3 |
Rep 88
Drives: 2018 BMW M2 | LBB | MT
After getting the infamous "Drivetrain Malfunction ... reduced power" message in my 2018 M2 while on the highway yesterday, I nurtered it home carefully and then to the dealership this morning. Needs a new wastegate actuator (actuator short circuit code). Estimate is $700 for the actuator and $1,300 for labor. Car has 48,000 miles. Mid 2022 I had the charge pipe issue, at that time I heard it pop and at least immediately knew what it is. This time no popping sound, just the malfunction message after a downshift and subsequent acceleration during overtaking. Engine kept running silkily smooth, idled normally, just no turbo boost.
Will report on final dealership bill |
11-19-2023, 09:50 AM | #5 |
Rep 606
11-19-2023, 12:08 PM | #6 | |
Rep 88
That is what I'll pay for the convenience to get an immediate appointment next morning with a nice loaner until it will have been fixed, the fact that the dealership is just 3 min away from my place and having to swap my summer wheels/tires swapped to winter wheels/tires anyway this week. Steep upcharge, I know too well ... They actually have the waste gate actuator in stock at the dealership (11-65-8-659-883, seems they don't need them just once every few months), but their master technician who usually is assigned to my car, did not get to it Saturday (other than the diagnosis). Will have to wait until EOD Tuesday, when he will be back at work, which is ok, as I have a comfotable ride until then. As mentioned, will report on the final bill, probably can help others with the same issue making the call on dealership vs reputable IAM shop at probably half the price. |
11-19-2023, 02:49 PM | #7 |
Rep 606
Man you’re lucky. My dealership charges those prices while making you wait weeks with no loaner and then gives you the car back with more problems than it rolled in with.
11-21-2023, 10:02 PM | #8 |
Rep 88
Allright, final bill for the wastegate actuator replacement was $1,859.40.
Error CODE 123601 - ELECTRIC WASTEGATE, ACTIVATION: SHORT CIRCUIT. |
Sundinisagod113.50 ///MPhatic14170.00 |
11-23-2023, 04:08 PM | #9 |
Rep 203
11-23-2023, 05:35 PM | #10 |
The Seeker
14170
Rep 3,420
The way to do this would be to buy the part from getbmwparts.com and have someone else with a cheaper labor rate replace it.
Turbocharger Wastegate Actuator - BMW (11-65-8-659-883) |
Sundinisagod113.50 |
11-24-2023, 03:49 AM | #11 |
Rep 48
Thanks for the update. I’ll save this. Luckily no repeat error for me.
Downunder9955.50 |
