06-11-2018, 10:13 AM | #243 |
Rep 350
06-11-2018, 01:00 PM | #244 |
Rep 134
Drives: BMW M2 Coupé (BSM)
so.. after a couple of weeks here's my final thought:
Don't get this or any other spring kit to go over the oem shock absorbers. Went for a spirited mountain driving and the car is "jumping" over every road bump when turning uphill... the reduced travel of the shock absorber is causing this. Same goes when on the highway, at high speed the car is really uncomfortable and jumps without any dampening. In addition to all of this, when turning the wheel I can feel a squeaking noise coming from the front suspension. At first I thought it was the strut nut, but after re-torquing it nothing changed. I suspect is the bump stop which is touching somewhere due to the strut being more compressed than usual (this problem has been encountered between several other users). The oem shocks are meant to be working at a very specific height and putting this (or other brand) springs just messes all up. It has been reported that the oem shocks start to leak after few months with lowering springs, not my case but I'm not willing to risk it. Sure the car looks cool but if you're looking for a proper solution to live with a lowered car my suggestion is to go with a full coilover kit rather than only springs. Going back to stock this week. Money wasted and lesson learned. |
4
06-11-2018, 01:07 PM | #245 | |
Rep 350
06-20-2018, 06:51 PM | #246 |
Rep 46
I feel the same as what was said above. I have Macht Schnell springs which are very similar and they definitely do not feel perfectly dampened. Daily driving is fine but you can notice it during very spirited driving.
Not to mention, I have a knocking noise on the driver side front wheel which might be a bad strut... |
06-20-2018, 11:33 PM | #247 | |
Rep 112
Drives: 2017 BMW M2 - Mineral Gray
06-21-2018, 04:19 AM | #248 | |
Rep 134
Beware of install mistakes cause they are known to be causing lots of weird noises.. lots of material on this on the m3/m4 forums but also here. Main mistakes are: - rubber booth not installed properly, - spring not seated properly against its stop - bolts not torqued to the proper specs or not torqued at all - bolts not torqued with the suspension under load. If you're planning to do this, check (or have your shop to check) the bmw tis for proper installation technique and torque values. My advice: leave the car as it is, drives just fine PS: I had the shop to put back stock springs but still experience all these weird noises bad installation is the cause. Now I'm DIY to find a fix using the points above Last edited by Alby_416; 06-21-2018 at 04:35 AM.. |
06-21-2018, 08:16 AM | #249 |
Rep 312
Does anyone have any post install feedback on the Dinan adjustable spring kit? I believe they use linear springs (don't quote me on this). Wonder if it makes a difference.
I'm about to have it installed. Above feedback makes me think I should have either left it alone or gotten the full M Perf suspension. |
06-21-2018, 09:47 AM | #250 | |
Former P-Car Owner
272
Rep 237
2018 BMW M2, Orange wrapped!, Journal
1999 BMW M3, Cosmos Black, S54 swapped |
06-21-2018, 12:58 PM | #251 |
Rep 46
You can normally only feel it during spirited driving. I think a big cause of this is non-linear springs as we as not being dampened properly. On the street they work and feel great. I think this will happen with most springs that are not set up properly for the strut. Coilovers are always the best route.
07-19-2018, 05:48 PM | #253 | |
434
Rep 884
Coils would be the way to go! |
07-20-2018, 07:09 AM | #254 | ||
Rep 4,529
FWIW, I test drove an Eibach sprung M2 during my search for a used/2nd hand M2. I'd driven a number of cars before/after and Eibach car felt to me as you describe. I put it down to stock setup being already very competent as opposed to the Eibach springs per se. I was fortunate enough to test drive a dealer demo car with BMW M Perf coilovers. Noticeable improvement over stock and night & day difference to the good compared to Eibach car. I bought a year old M2 and drove it for 6 months. 4 months ago I fitted oem M Perf c/overs and -30min camber correction hubs - no regrets as DD and 3 off TD's todate.
Current '22 X3M LCI.. |
Yellowflash21369.50 |
07-21-2018, 01:05 PM | #255 | |
Rep 354
Don't get me wrong, but I just went through your previous post and you were clearly "SUPER" happy about them and how everything is in harmony then you through in this response which sounds to me like someone had just a bad day. Personally, I pulled the trigger on these a week ago after months and months of research and reading other peoples opinion how M performance coilover are stiffer than these springs, how people with M4 on HAS kit had issues. Thanks for your review! |
07-22-2018, 03:34 PM | #256 | |
Rep 134
I simply changed my opinion cause at first I didn't encounter any of the issues I described, which started appearing only later hence why I edited my messages. The initial impressions were really good! Perfect drop (and it still is), a bit more stiffness during daily use and I felt the car a bit more planted during turns. No rubbing and very aggressive look overall. However, after few days, issues started to arise: 1) Weird creaking noises started to develop but this was then attributed to a bad install by the shop I used. They said at first: "springs needs to settle in, the noise will disappear after few days". I though "what the hell it kinda makes sense" so I kept on driving. Long story short, the top mounts bearings are damaged and need replacing. I can only speculate on the reason but I suspect that the springs were not seated properly plus an improper use of a impact wrench which is a no-no on some suspensions components. 2) I went for a long drive around some mountain roads and really explored the new setup; when you drive fast, the car is not in balance anymore and you can definitely feel it "skipping" going through the hairpins due to the reduced shock travel - I didn't notice this at the beginning cause I only drove around town for the first couple of weeks - I had the 1M coupé before and I drove it hard many times around the same twisty roads; did the same with the M2 before going with these springs so I know how a car should behave in these scenarios. Anyhow I would still go back to the stock setup even if I hadn't experience any weird noises. Why? Because the car is not damped correctly and I simply think this springs setups ruin the already great handling of the car. You want more control over (the already amazing) stock suspension setup? My advice is to go for a full coilover kit. "Cheaping out" on a car like this was a big mistake for me. Are you looking just for a "stance look" and don't care about how the car handles? These spring kits are a risk, but they might be the right choice for you... Hope this helps |
07-22-2018, 05:01 PM | #257 |
Rep 312
Hmm. It may be too early to tell yet as I just had them installed last week, but so far I've had the opposite impression of Dinan HAS. The car actually seems noticeably more compliant.
Softest lowering springs/coilovers https://f87.bimmerpost.com/forums/sh....php?t=1331360 |
07-24-2018, 04:30 AM | #258 | |
Rep 354
The "skipping" part that you mentioned I'm experiencing it a lot on the curvy roads with uneven surface. Personally, that's why I was looking to build a confidence a little bit by going with progressive Eibach springs which are bit stiffer at the back. I will share my experience in 2-3 weeks time when I get the springs, do alignment and do couple of runs. Honestly, I always drive the car at 80% of it's limit and never near 90% on the public road, and my primary goal was to build mid corner speed and confidence. |
07-26-2018, 05:48 AM | #259 |
Rep 134
Minute 2:14
This confirms my experience with these lowering springs... wish I'd seen this video before installing them |
07-26-2018, 01:41 PM | #260 |
Rep 14
I mean, what do people expect? installing lowering springs on shocks designed for longer travel will definitely reduce ride quality especially when pushed to the limit.
Like some others have said, if your main priority is to lower the car and drive it around town, then maybe this is for you. For anything more, go with a coilovers or at least a spring and shock combo. |
JeremyDFW458.00 |
08-04-2018, 04:10 PM | #261 |
Rep 354
Just my first two cents about eibach prokit.
The drop is perfect. The ride comfort which was my biggest concern when regular driving in town, and on bit potty roads with normal speed of 30-60 miles is better than stock spring. As there is less travel, and the car is more planted when going straight forward. On the highways and when changing directing when speed is above 70+ miles on hours there is indeed more responsiveness and car is way more planted which gives a lot of confidence compared to stock. Personally, I never pushed my M2 beyond lets say 70% of its handling abilities, and I was looking for bit more confidence in that segment. When I go 100%, it's only on the local track which is very leveled. You folks who are against these spring upgrades, you might be right that these shocks might not like these spring on uneven roads and pushing car really hard in the corners. But personally for someone who never had a "balls" to go all out crazy on the public roads, this springs are great upgrade over stock in look and handling! |
JeremyDFW458.00 |
08-07-2018, 10:58 PM | #263 |
Rep 128
Here's mine, 12mm front 10mm back, eibach. Quite happy so far.
Yellowflash21369.50 m2rs4_official95.50 |
08-28-2018, 10:41 AM | #264 |
Rep 117
Sweet Baby Jesus... That looks really gorgeous and I can't wait to fit the Pro-kit on my 3.5 month old 2018 M2 after deciding not to sell it and not to slap on some KW V3s for the time being.
Instagram: m2rs4_official
Proud owner of Amelia & Rae. Yes, I named my vehicles 2018 BMW M2 LCI (Wedge Performance Tuned + Pure Turbo Stg 2 Upgrade) 2019 Audi RS4 Advant |
