M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Permanently turn off Rev Match via coding
      04-09-2018, 07:10 PM   #45
ORIGIN M.
3161
Drives: ///M
Originally Posted by tehboost View Post
Originally Posted by ORIGIN M. View Post
Not like BMW can't tell you coded it out because they can.
Can they?
And what reason would they have to look at that...
Wait for it...
Any tranny problem that ever happens to be a potential warranty claim.
      04-09-2018, 07:44 PM   #46
NO_USER_
Drives: .
Wait for it...
But you can turn it off within the stock coding of the car as well (no coding required), no big deal.
      04-16-2018, 06:31 AM   #47
Leon007
Leon007's Avatar
Drives: 2017 M6 + 2018 M2
Hi there ^^ I also want to permanently turn off that annoying auto-rev..... because it just changed my driving style which I don’t like. I drove brz, sti, miata before, I really enjoyed doing rev-match & heel-toe by myself. I heard someone said if u switch to sport mode, the auto-rev will not interfere u while u rev-matching on your own. I’ve tried this method before, I can say that the auto-rev is just a little less intrusive because it still sometimes interferes me while I rev-match or heel toe by myself..... so that’s why I want to turn auto rev off permanently!!!
      04-16-2018, 06:55 PM   #48
NO_USER_
Drives: .
Interesting, what do you mean less intrusive by switching to sport mode? It's the same in Sport/Sport+...in comfort it's still there but it's slower lol.
With the DSC COMPLETELY off, Rev Match is completely disabled.
Or you code it out.
Nothing in between, as far as I know.
      04-17-2018, 02:34 AM   #49
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
All BMWs and BMW made MINIs made after 1996 have the "Anti-stall" feature you are referring to; it's tied into the ECU and clutch pedal sensor.
If you code out Rev-matching or "Start Car without pressing clutch" you inadvertently disable the clutch pedal sensor and EVERY feature that it feeds data to i.e Hill Hold, Anti-Stall, Auto-Start Stop, ect. Your car will become "old school" but to me, it made take offs from a dead stop a real chore.. Maybe I'm spoiled..
      04-17-2018, 07:42 PM   #50
NO_USER_
Drives: .
Hill start is still active! Unfortunately LOL
      04-17-2018, 08:04 PM   #51
Poochie
Poochie's Avatar
Drives: 2016 M2
I meant unlocking the Hill Hold grab when you clutch in, is disable. It still works but it does not respond to clutch pedal like usual, with the sensor disable. I am pretty sure of it.
      04-17-2018, 08:10 PM   #52
NO_USER_
Drives: .
Hmm, you tried yourself? because for me the car still holds haha no big deal but wish it didn't
      04-17-2018, 08:16 PM   #53
Poochie
Poochie's Avatar
Drives: 2016 M2
Yes, I did the "No clutch pedal to start" didn't expect much but after I starting driving the car, it took off like crap, I had to constantly slip the clutch to get it going. On a hill, I had to really slip the clutch to get moving and to stop rolling back. I was confused and thought I screwed up the coding. Afterwards, I read on a F30 forum coding that feature disables the sensor...
      04-21-2018, 02:16 AM   #54
cookiesowns
cookiesowns's Avatar
587
You gota relearn how to drive stick then! The engine modulates torque to help starts. You need to be way more gentle and precise with your throttle inputs in order to start smoothly without this.
If you can nail balancing the clutch and gas preventing the "nanny" from kicking in you should be able to drive this car with the dead clutch sensor deactivated. The main clutch switch is still intact however.
      04-21-2018, 03:58 AM   #55
Poochie
Poochie's Avatar
Drives: 2016 M2
I had two prior older manual Honda/Acura without this feature, I know you have to slip the clutch pedal and throttle to get the car going. But ever since I had gotten a BMW with this anti-stall feature; I've become spoiled and has been use to computer helping modulate the throttle.
I was just pointing out that coding the features indicated causes the vehicle to have a different driving dynamic.
      04-21-2018, 07:21 AM   #56
doug_999
doug_999's Avatar
2543
Drives: 2011 1M/2021 992/2023 X3
I don’t think my wife’s 2010 Clubman has it based on my attempt to teach my daughter how to drive stick. #fail
      04-21-2018, 07:32 AM   #57
Poochie
Poochie's Avatar
Drives: 2016 M2
I don't think my wife's 2010 Clubman has it based on my attempt to teach my daughter how to drive stick. #fail
I had a 2009 Mini Cooper S with the "anti-stall," feature but no rev-matching. And all the newer manual loaners they gave me also had it, including a brand new manual Clubman I once had.
https://amp.reddit.com/r/BMW/comment..._of_antistall/
http://www.1addicts.com/forums/showthread.php?t=217916
      04-21-2018, 05:54 PM   #58
asciimike
Drives: 2017 M2
2017 M2  [0.00]
Anyone else get a check engine light after coding this away?
      04-21-2018, 06:27 PM   #59
NO_USER_
Drives: .
There will not be a CEL, but there will be a code like "clutch line disconnected" something along those lines lol not NO CEL.
      04-22-2018, 01:46 PM   #60
asciimike
Drives: 2017 M2
2017 M2  [0.00]
Hah, turns out the issue was that the OBD port cover was off (thus illuminating the CEL) without anything plugged in to it (had given my friend the iCar pro back). Given that my last car ('94 318i) didn't even had OBD II, I feel a little better about this.
Much more fun to drive the car without the nannies
NO_USER_537.50
      04-22-2018, 03:23 PM   #61
nomade30
Drives: 18 M2, 91 325, 05 DMAX
OBD port cover? I do not has such thing.
      07-05-2018, 07:24 PM   #62
GT6Racer
Thanks for the post guys. I got my 2018 car back in March, and have been giving the revmatch a shot to see if it gets better with time. It doesn’t. I know some like it, but I hate it - to the point I was considering selling the car. The technology isn’t a bad idea, but the execution is not there. It’s not smart enough to understand how fast I am going to change gears, and release the clutch. It’s too aggressive for around town and too slow for really spirited use. I find myself having to time my actions to match what the car expects - as someone on another forum accurately described I feel like “ a monkey pulling levers”.
I have tried driving all the time with traction full off, but I like some nannies for everyday driving, and also that mode loses the sport plus throttle that I like.
I turned off the rev match today by coding and the car is hugely improved. Now I can actually drive the car. Confidence to come into a turn on a downshift is back, and the car is now fun to drive. I know what it is going to do. ( am I the only one who has come in hot, banged it down a gear only to have the engine still be revving up as the clutch goes out - it’s scary. )
I like the sport plus throttle ( I know some find it too aggressive ), and now I can drive through town without the embarrassingly huge blip when I go down to second. To me it also feels like the car has stopped playing with the throttle on upshifts too - I find it much easier to drive with smooth changes that I control. Taking off is no issue.
Maybe it’s just me. I’m used to racing vintage where I have to be fast/smooth with the controls to avoid blowing the old gearboxes, so I toe/heel without even thinking. However, for me, This car is much, much better under “manual” throttle control.
Thanks again.
( BTW everything went as expected with the coding. I do now have to hit the start twice, but otherwise no negative impact. I have noticed the clutch needs to held down for a second or two on start, otherwise it will cut out - I assume that’s because it cannot “see” the second clutch switch any more)
akkando5864.50
      07-14-2018, 08:29 AM   #63
GT6Racer
Quick update. Still loving the car. Some observations :
Not only is two presses of the start needed, but it also necessary to hold down the clutch for a second or two. No big deal just need to get used to it.
I can see why some find takeoff harder with rev match off. It’s to do with the various throttle maps of the modes, I think the base mode response is so slow, the car normally fills in the revs for you, so you miss it when rev match is off. In sport, just a touch of throttle has the car moving. So with rev match off, you need to drive a little differently in the various modes..
For me, the absence of the revmatch is a vast improvement to the car.
      11-28-2018, 11:56 PM   #64
raymondlo84
Drives: BMW M2 2017 6MT, M4 2016 6MT
Does it mess up the traction control? Just got the adapter and gonna code my BMW M2 2017!
      11-29-2018, 05:18 PM   #65
Randomdude
Drives: F87 M2, E46 ZHP
Thank God someone found this and linked it to me! We were pretty close to selling the car because of this.
The quote below pretty much sums up our feelings about it. Hopefully we'll feel the same way when we code it out.
My wife replaced her highly modded 135 with the M2 and she has been pretty disappointed so far. I hope this makes her like the car now.
Just gotta buy the stuff to code it out... all of my BMW software is for the older cars.
Thanks again.
      12-05-2018, 05:38 PM   #66
Randomdude
Ran into a glitch with the 2018 F87. Seems that "start engine without clutch" in regular mode shows not active as the default value that is turned on.
Had to go into expert mode in FEM_01, go to Group 3020. TCM_STARTLOCK_CLUTCH and change there from "aktiv" to "nicht_aktiv" and complete the coding.
I didn't read every post in this thread to see if someone else had this issue and IDK if it was just my car or all 2018s or something with Bimmercode but if anyone has this issue, that's how to get around it...
It's very nice to have this turned off. The car behaves like a normal car now. The wife will like it too.
