09-23-2020, 08:25 PM | #1 |
Rep 108
245 Fronts 275 Rears
Hi Guys
I am hoping someone with a bit more knowledge and experience might be able to answer this question ... A bit about my set up... i recently got a BMW M2C. I've got the BMW 763M wheels on my car with the 6 Piston M performance BBK .. Wheels - 19x9 Fronts and 19x9.5 rears. Tires - 245x35 Front and 265x35 rears Currently running the Micheling Pilot Cup2 I track my pervious cars a lot however my knowledge is based on an AWD car and its inherent nature and tuning accordingly. The challenge I have is choices of 19" Semi Slicks are a bit limited here in Australia. I have found a semi slick compound I like but I can only get either one of the following set ups Option 1 Rims - Same as above (19inches) Tires - 265x35 (F) and 275x35 (R) an almost square set up Option 2 Rims - Same as above (19inches) Tires - 245x35 (F) and 275x35 (R) an almost square set up Now my question is ... should i go the Option 1 set up... or Option 2... The car as most of you know has a tendency to over steer and spin up the rear wheels. My Car is still stock except for stage 1 Tune. I intend to do modifications bit by bit to get some reference time laps per mod to see the effect of each modification and improvements I am leaning towards option 2 as I suspect that will help me dial out some of the over steer tendency (will do suspension mods later) Can anyone shed any light on whether they think option 1 or 2 is better and why looking for people who have this set up or have experience in this type of set up for an RWD Car as my experience is in AWD Cars thanks |
09-23-2020, 10:03 PM | #2 |
Rep 427
All my track experience is in RWD cars, but I drive with the local Audi Club quite a bit and have watched several friends adjust from AWD to RWD over the last few years.
You can’t get on the throttle as eagerly and early in RWD as you’ve been able to get away with in your AWD cars. It feels slow to be patient with throttle until you have the steering wheel pointed more or less straight ahead, but that’s part of the learning curve as you transition to RWD, regardless of what tires you’re running. Are these tires for your 763m wheelset, or is the 9/9.5 wheelset something else you plan to use on track? 763m should be 9/10. In any case, 265/35 will probably require some massaging of your wheel liners, and is also a bit wider than ideal on a 9" wide wheel, so I’d probably go 245/275 for minimal fuss and better steering response. From a handling perspective on stock suspension though, I enjoyed square wheels and tires for the improved turn in and mid-corner balance, so could see a good argument for 265/275 getting closer to a more balanced feel. All that said, semi-slicks only last a few days, so maybe give them both a try and report back. |
09-24-2020, 02:18 AM | #3 |
Rep 108
hey bentom sorry are correct yes 10inchs at the back wheel not 9.5 my bad.
and yes agree with you on a more square set up hence my line of thinking around the 265 and 275 rears curious to see if anyone on this forum has run 265 at the front before thats all |
bentom2335.50 |
09-24-2020, 03:51 AM | #4 |
Rep 1,823
Car will certainly transition a bit towards understeer with 245/275 setup, so I think I’d depends on your feeling with stock tire sizes. If you feel the car is too tail happy. Extra rubber in the back will help keep the tail planted just a bit more.
If you like a “loose” feeling car then closer to square will tend towards that feeling more. This setup will likely require using throttle the transfer the weight to the back on corner entry oversteer, and you’ll need to be ready to correct steering on corner exit under partial throttle. The active diff helps out a lot in this situation already though. |
09-24-2020, 06:19 AM | #5 |
Rep 108
thanks for the input thats what i suspected.. im use to dealing with understeer and trail braking into corners...and the M2 is very tail happy ... and i want to dial it out a little bit ... so it seems the 245/275 might be suitable
09-24-2020, 09:01 AM | #6 | |
Rep 744
Tires wouldn't hapen to be Federal 595 Pro whatevers? I came from a MK3 Focus RS and it took me a while to adapt my driving style. M2C is more of a slow in fast out car than an AWD car. The extra power wont be doing you any favours in learning how to modulate the power. If you have boot mode I would adjust the TQ by gear to a point where you dont overload the rear tires. Another option is 265/35 all around, then you can have your tires rotated to extend their life a bit and it should have a more neutral atitude. Also I would get an alignment if its never had one. Rear toe seems to affect oversteer a lot on these cars.
09-24-2020, 11:37 AM | #7 | ||
Rep 684
09-24-2020, 12:10 PM | #8 | |
Rep 744
Also the Federals are very very wide for their indicated size, so ymmv.
Kankles1485.50 |
09-24-2020, 04:43 PM | #9 | |
Rep 1,263
* Corner Entry to Apex * Apex * Apex to track out I suspect your talking about TTO (trailing throttle oversteer) which of course is apex to track out. Our cars have lots of TTO :-) Especially if your experience is coming from a AWD platform. One of the common topics is putting as much tire on the rear rims as you can. This helps with TTO and taking additional advantage of the M Diff. Its a fine balancing act with rim width, suspension setup, tire selection and driver style. What are your tire options for DOT R Compounds? Hoosiers, Toyo's, Federal's, Nitto's, BFG R1's, Michelin Cups, Nanking? Hankook, Pirelli?
09-24-2020, 08:37 PM | #10 |
Rep 108
thanks all for your input and Seat Time Rules yeh pretty much what you described. I'm used to relying on all wheel drive to scrabble out of corners so i can get on the throttle earlier...its just reprogramming my brain to how RWD Biased cars drive.. having said that.... i was able to reprogram my brain pretty quickly and ended up posting the 4th fastest time of the day in the sprint formats out of 50 cars and my car is bone stock and a whole bunch of other modified cars.....so i did come to grips with the car pretty quickly
its just i feel with more power rear wheel traction will be an issue. In australia our choices of R Compound Semi Slicks is pretty limited right now... and in the tire sizes i want.. I can either stay with the Michelin Cup 2s 245/265 combo... and up it to a 255/275 combo....... or go another brand which i have used before and i rate quite well which is the nanking AR-1 which I really like more the cup 2s are great... but just a personal preference i like the AR1 more. So i have decided on option 2 which is 245 Fronts and 275 Rears to get a slightly bit more understeer Bias and then will use coil overs and suspension tuning to dial in the bias to my personal preference i also did some further research and interestingly enough ... the tyre reviewer guy in the UK addressed this very question and concluded the combo he has recommended (255F & 285R) is pretty much the same combo ratio i am going for which is 245F & 275R .. i know its not quite that simple but yeh roughly there abouts for those interested in the video here it is |
09-26-2020, 01:26 PM | #11 |
Rep 1,263
If you want maximum mechanical grip form the Nanking's you will need at least 3 degrees of Neg camber up front. IMHO probably closer to 3.25. Buy some camber plates you can run with the stock struts.
It will balance the car, turn in will be much crisper, and the biggest bonus will be even tire wear. Which on a staggered setup is a huge advantage. My $.02
09-26-2020, 10:15 PM | #12 |
Rep 1,678
Personally I'd go as wide as you can up front. More front end grip - better turn in - better rotation - you can get back on the power earlier. I found 275 with 200TW to be plenty of grip on the rear of a stock power M2C.
09-27-2020, 09:07 AM | #13 |
Rep 1,759
I don't quite understand the logic of running 245/275 will net you more rear traction considering the 265/275 setup has the same rear rubber!
265/275 will be faster than 245/275, period. Shorter braking distance and less understeer is the pros of running 265 front. You have a stage 1 tune so that really doesn't help with the corner exit oversteer on track. On the street that power level is pretty much useless you have at least 305 rear. IMHO you better off selling those 763 wheels and get wider Apex wheels 9.5/10.5 and run 275/30 & 305/30 19. If you don't have the optional BBK than go back to 18 and run 275/295. R tyres have a lot more sizes in 275 & 305 19 Last edited by Karmic Man; 09-27-2020 at 09:13 AM.. |
09-28-2020, 12:49 AM | #14 | |
Rep 108
im more worried about rubbing if i stick 265 at the front |
01-27-2021, 06:52 PM | #15 |
Rep 916
Bump, I'm looking for feedback on running 245 front and 275 rear
245/35/19 and 275/35/19 rear I have a m2c with the oem big brakes and finding a good street /track tire is not easy A race shop recommended the hankook rs4 for how long they last, good grip, ok in the street and wet The rs4 are only available in 245/275 in 19 Any review on how the car react to these size, i mean understeer cant be that bad since some people run 255/285 and 265/295, all of these have 30 mm difference |
01-28-2021, 09:09 AM | #16 | |
Rep 1,263
The Hankook RS4's are a decent all around tire. I liked the old RS3's much more than the 4's. W/O more Neg camber the tire choice is not going to make much difference in wear. Any tire on the track driven hard will wear very quickly on the outside shoulders w/o added Neg camber. So other than cost I don't have enough info from you to really give you a spot on answer. How many track days pr yr? Expectations on ride, tire life, performance, etc??? Increasing the front tire size will help some with understeer, but only a little. As I stated before the way to properly dial out understeer is the use of camber plates. I've been setting up cars for Track and Auto X for 30+ yrs now. BMW's love and need Neg camber up front. If your worried about inside tire wear on the street have the plates setup and marked for street and track camber settings. Its easy to change between the two. Most plates have 3-4 nuts that have to be loosened after you get that tire off the ground. Grab the tire and push in until the plate slides to the track setting. Retighten the nuts and that's it. At the end of the day put the plates back to the street settings. Or, like many on the boards do they compromise with a single setup at around 2.4-2.7 Neg. Whatever you do make sure your Toe is zero on the street setting. Why? Because any toe added to a more aggressive Neg camber setting will eat the insides of your tires very, very fast. Whatever you do make sure to post to the boards so others can see your thoughts. Best of luck HAZMAT
01-28-2021, 10:17 AM | #17 |
Rep 916
I will install mcs coilover with ground control camber plates
I will set the front camber at around -2.6 front. I want to do around 4-6 track days per summer, i want to drive the tires on the street but i dont drive a lot... so maybe 7000 km and 4-6 track days ( 7 x 20 minutes session per day) I'm looking for a good dual duty tires that will last the complete season Looking for 245/265 setup Maybe 255/275 Can do 245/275 if other size are not available From reading ( I'm completely lost, can't decide) Re71r: amazing grip, do not like heat on track, super fast wear, price is good Hankook rs4: last long and good grip, more expensive than re71r Advan ad08r: some people like them a lot, last long but some people tell me they out cycle in 10 sessions and become hockey puck Falken azenis rt660: same wear character as the re71r, good grip, wear fast Goodyear eagle super car 3: review look good, expensive tire, good grip, wear is fast for some not so bad for others. Nankang ar1: maybe too harcore for street and rain In the past i tracked federal 596 rs-r for their low cost, was happy except for the crazy road noise in the street. Can't decide..... |
01-28-2021, 11:16 AM | #18 |
Rep 1,263
With that info your spot on getting the RS4.
Which brake pkg do you have on the m2C? If their the 2NH then you won't be able to run an 18" rim up front. If you have the standard brakes then you could go with a set of 18" rims like the APEX's and then you have a ton of tire choices to work with..
01-28-2021, 11:17 AM | #19 | |
382
Rep 731
At a Point above 7,000 RPM.
01-28-2021, 11:20 AM | #20 | |
Rep 1,263
I've never had an issue with performance at the track doing this and it sure helps your tires in dual use
chief1richard382.00 |
01-28-2021, 08:07 PM | #21 | |
Rep 916
