M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Lug bolt torque now 140 Nm
      10-30-2019, 08:50 PM   #23
paradocs98
paradocs98's Avatar
Drives: M2C
Thanks for the replies, all. I honestly don’t know if 120 vs 140 Nm makes a critical difference. Essentially, you don’t want to overtighten with an unrestricted impact gun and stress the threads, and you don’t want to undertighten and have this happen:
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3
      07-02-2022, 10:50 AM   #24
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2017 Audi Q7 3.0  [0.00]
2020 M2C  [0.00]
Just a side note on this as I was swapping the wheels just now. 101 lb. ft. / 140 Nm is not a lot of force at all. Kinda surprising
blkonblk195.00
      07-02-2022, 02:25 PM   #25
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
Since getting my FI-R's and BBS lugs I've been wondering about this. Is it the OEM lug that requires 101? The OEM wheel? The fact that BMW expects guys to track the car? The heavy weight of the stock combo? I don't have stock lugs or wheels, and I don't track my car. And my set up is super light. I wonder if it matters at all for me. Our Acura SUV is heavier by a long shot and has heavier wheels and the OEM specs are 80 ft lbs.
      07-03-2022, 03:00 PM   #26
to_riffic
to_riffic's Avatar
Drives: rwd
Don't overthink it....
~loud noises~
      07-03-2022, 03:34 PM   #27
///MPhatic
The Seeker
///MPhatic's Avatar
13863
I wouldn't, other than the fact that it was one torque for many years and they changed it. It's natural for me to want to know why. It's a sickness I have.
chris7197334.00
      07-03-2022, 05:19 PM   #28
chris719
Drives: '08 M Roadster
Larger fastener, higher torque spec. I'd torque to 140. But honestly, for wheels, anything works as long as it's not loose and not stripping the threads and able to be removed. I go 10% higher because I don't know if my wrench is accurate and there's probably not going to be an issue with a bit more torque. Most shops use an impact gun and put them on so tight they are nearly impossible to take off and you rarely hear of issues.
///MPhatic13862.50
      07-03-2022, 07:25 PM   #29
F87source
F87source's Avatar
Drives: Bmw M2
I personally always do 140 nm, 10% higher in torque should be fine as well.
///MPhatic13862.50
      07-03-2022, 09:44 PM   #30
///MPhatic
The Seeker
///MPhatic's Avatar
13863
If a shop uses an impact on my car I don't go back.
I think for my purposes 80 ft/lb would be just fine, so going 101 is really over-torqued a bit.
      07-03-2022, 10:49 PM   #31
F87source
F87source's Avatar
Drives: Bmw M2
I would do what BMW specifies, because these are wheel bolts not just lug nuts, this means they have to support the weight of the car as well as hold the wheel on. So if it's too loose vibrations over time could cause the bolts to back out and this can lead to very terrible consequences.
chris7197334.00
      07-03-2022, 11:00 PM   #32
chris719
As F87source mentioned, you don't really have "your purposes". There is a spec for the bolt and that's it, really. There is no advantage to undertightening it. It's not like an aluminum drain pan bolt or something easily damaged. Most dealers probably hit it with an absolute ton of torque.
F87source7251.50
      07-03-2022, 11:32 PM   #33
F87source
F87source's Avatar
Drives: Bmw M2
Yeah I'd rather not have the wheel fall off.
Also this change in torque spec occurred when bmw went to the stronger m14 bolt on the F series, so follow what bmw specs no need to make up any random torque values.
Also this post from earlier has a table showing the appliciable torque specs for bolt sizes and grades, it shows that even on a grade 8.8 bolt over 100 ft lbs of torque is acceptable: https://f87.bimmerpost.com/forums/sh...2&postcount=17
chris7197334.00
      07-04-2022, 02:34 PM   #34
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Well, you know I'll do what you tell me, I'm just being a bit cautious because I'm not sure my torque wrench is spot on, and I don't use BMW lugs, I use BBS 2-piece.
Yeah, respectfully I don't agree with that. Many things are tweakable taking usage into account. The 70 mph speed limit is for mini-vans and Ferrari's? I don't believe that for a second, and I certainly believe that if you're driving a car normally things are different than racing it, and BMW absolutely considered this car a weekend racer.
I'll use the 101, but I'd need hard data to support that it's better for a light wheel/tire combo with BBS lugs and no track days vs the stock heavy combo, stock lugs and the probability of track days.
      07-04-2022, 03:49 PM   #35
chris719
It’s got nothing to do with the wheel and tire combo or how you drive. It’s determined by required clamp load and bolt diameter. BMW uses the same spec for this hardware on every car it’s used on. They changed the spec when they changed the bolts. There’s always margin so I’m guessing your wheels won’t fall off at 80, but you never explained what you hope to gain by undertightening them.
I understand what you mean when it comes some other specs where we understand the design intent well and have other goals, but I truly don’t see what less torque does here other than increase the risk of a catastrophic issue. Consider also that my Mazda 3 had a higher recommended lug torque than my Z4M. Surely no one expects a Mazda 3 to be driven harder than a Z4M.
https://www.machinedesign.com/archiv...astener-torque
If BBS doesn’t specify anything then I’d use the BMW number, but you could always reach out to them.
      07-04-2022, 05:07 PM   #36
///MPhatic
The Seeker
///MPhatic's Avatar
13863
So every bolt made in that same diameter would require 101?
I think I'll do that, just to see what they say.
      07-04-2022, 05:24 PM   #37
chris719
The clamp force would be decided on usually when choosing the fastener I think, so it's sort of implicit. Image taken from an earlier post. This is on the high end, not minimum.
///MPhatic13862.50
F87source7251.50
      07-05-2022, 12:34 AM   #38
F87source
F87source's Avatar
Drives: Bmw M2
Haha thanks for the flattery - but I don't know everything, I know stuff but not everything.
If the BBS wheels are designed to fit bmw's bolt pattern the torque will be fine. You also have to remember that the wheel hub area is designed to take immense forces from cornering loads and acceleration loads, 101 ft/lbs of torque is literally nothing to the wheel compared to pulling 1 G in a 3500 lbs car.
You could get your wrench recalibrated, but for things like wheel bolts you should be fine, the bolt diameter and material is so strong you don't really risk stripping it easily. The wheel itself should also be fine, and capable of taking more torque than the thread can actually handle.
Exactly! The clamping load is critical to keep the fastener tight and help secure the bolt, you must stretch the bolt within its range of elastic deformation to load up the threads enough to hold the item securely without failing. If you do it too loose there is not enough load on the threads making it easier for the bolt to vibrate lose (along with other factors), and this is a really bad thing on a wheel.
This is a general range, but it depends on material grade, size, thread pattern (coarse vs fine threads), female and male thread material (i.e. a harder metal going into a softer metal like a steel bolt going into aluminium) etc. Generally go with the engineering recommendation for your product - in this case bmw, and if you cannot find it then go with the general recommendations.
+1
///MPhatic13862.50
      03-31-2024, 03:23 PM   #39
GaryGK
Drives: 1987 5.7l IROC-Z, 2021 M440i
Originally Posted by KevM2 View Post
I've never torqued a lug nut in my life! Always gone by feel. Why is a number different by a few Nm so important?
One reason is to have the lug nuts torqued at the same value so that you do not warp your rotors. Another one would be if there is insufficient torque on the bolts you could lose a tire and wheel. Having said that, this might not apply to the 2 piece rotors that I have on my car.
      04-01-2024, 02:18 AM   #40
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
BMWs torque specs are, and always have been, the following:
M12 = 120 Nm +/- 10 Nm
M14 = 140 Nm +/- 10 Nm
https://www.newtis.info/tisv2/a/en/e...unting/5Tp9xUw
On the newer cars with M14 they have removed the +/- 10 Nm though, F87:
https://www.newtis.info/tisv2/a/en/f...els/1VnXy9B75W
The same goes for M12 from E9X:
https://www.newtis.info/tisv2/a/en/e...wheels/5HLATDw
So the conclusion is that if you stay with 120 Nm for M12 and 140 Nm for M14 you'll be just fine.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
F87source7251.50
CSBM52722.50
chris7197334.00
