M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > APEX | NEW 19” EC-7 & SM-10 M2 & M2 Competition Wheels
      04-18-2019, 12:12 AM   #45
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
Originally Posted by wanofakind01 View Post
Originally Posted by cntzl View Post
Apex wheels quickly became my favorite too when I started tracking my M4. I used to run satin black EC-7 18x10" and 18x11" staggered setup on the M4 and now I'm running satun black EC-7 18x9.5" square setup with 275/35/18 NT01s on the M2C. I'm pretty happy with the setup so far
Any suspension work to fit that square setup? and what ET did you choose?
They are ET35 so front requires 12mm or bigger spacers. I run -3 front and -2 rear camber. Also, the car is slightly lowered on Ohlins.
Any photos of your setup? And which 12mm spacer did you end up going with? Have a similar setup with 265/35/18 with toyo r888r and a 5mm spacer is not enough.
I posted couple pics on the first page of this thread. I'm running 15mm spacers from Turner but their 12.5mm would work fine too (I checked the clearance with 10mm spacers and Ohlins but there was maybe 2-3mm gap at most with -3degree camber). I chose 15mm spacers because I like more flush look since I have significant negative front camber.
      04-19-2019, 04:16 AM   #46
mcgarnigle
Drives: M2C
Is the color choice guaranteed, or is the group buy for only the most popular selected color?
      04-19-2019, 04:11 PM   #47
Expert@ApexWheels
Expert@ApexWheels's Avatar
3525
Drives: M3
Thanks for the post! Production will be based on demand, but there is still a possibility that all 3 colors will be produced. At a minimum, the two most popular colors will be produced.
--Dylan
      04-20-2019, 11:32 AM   #48
Phantom_9192
Phantom_9192's Avatar
105
Drives: 2019 M2C
2019 BMW M2C  [0.00]
So if I purchase these wheels, does the stock suspension have the required adjustment for negative camber to account for that requirement (listed above)? I want some track wheels but I really don’t want to modify the suspension if I can avoid it (e.g. camber plates). Please advise ASAP!
<edit> Apologies...I hadn't read the entire post when I typed this via phone. I see now that there is some discussion around this topic but if I went 265 front on stock ride height, would pulling the camber pins be enough for me to daily drive and track the car on EC-7's withouth rubbing/interference?
      04-22-2019, 12:58 PM   #49
Expert@ApexWheels
3525
Drives: M3
Edit:
Front camber is not adjustable unfortunately like it is on previous BMW models with removable camber pins, so you'd may get some rubbing on full-lock turns or during hard cornering. Using a smaller tire may help in the short run, but is not recommended as it would result in a sidewall that is either too short or too tall.
With that said, I strongly recommend adding camber plates if you plan to track the car even a handful of times per year. It's a one-time cost that will drastically reduce recurring costs due to reduced tire wear. Camber plates distribute the cornering load evenly across the tread's surface, rather than putting it on the outer shoulder of the tire. In addition, you'll appreciate the increased grip in cornering knowing your tires aren't wearing prematurely.
--Dylan
      04-25-2019, 03:49 PM   #50
Expert@ApexWheels
3525
Drives: M3
Major Update in post #2
The first production sample wheels are here, along with a full fitment test and proper photoshoot.
Read post #2 to find out how a staggered fitment is very close to a direct fit, even with aggressive R888R tires
      04-26-2019, 05:25 AM   #51
Bruuuce
the me
342
Drives: 01ZCoupe, 08M3Coupe, 21M2C
Great update
01 Z Coupe, 5MT, SB, not much else
08 M3 Coupe, 6MT, JB, not much else
21 M2c Coupe ,DCT, SOM, not much else
      04-26-2019, 10:08 AM   #52
Proctor750
Drives: E30 M3
Did you guys get to test out the extra rubber in anger? How did it feel with the added rubber?
I wonder if BMW warranty covers the giant grooves carved out of my 788 wheel drum and the destroyed caliper paint... Surprising that made it passed QA
      04-30-2019, 12:29 PM   #53
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Proctor750,
This was simply a test fitment and small photoshoot. We did not have a chance to take the car out and give it the beans. However, we do have some photos showing the improved barrel clearances that I have dropped below.
First, you can see the clearances with the OEM wheels:
Here are some EC-7 pictures, showing improved barrel and spoke side clearances:
This added clearance will prevent rocks and other road debris getting jammed in the wheel and damaging the barrels or the paint on the calipers.
- Max
      04-30-2019, 12:35 PM   #54
AlpsRider
AlpsRider's Avatar
2865
Originally Posted by ApexRaceParts View Post
Proctor750,
- Max
Good job. My front 788Ms both have grooves from rocks. BMW gets a "fail" on that one.
      05-03-2019, 08:16 AM   #55
2PUTT
Drives: F87
glad i made it with 5 hours left. =)
      05-03-2019, 04:57 PM   #56
DanteM2c
DanteM2c's Avatar
Drives: Bmw M2 G87
I like the black M2 . what tire set up is that? I see the 295 toyos shoulders too much.
285?
      05-06-2019, 12:11 PM   #57
Expert@ApexWheels
3525
Drives: M3
285?
The Black M2 is using the OEM tires on 19x9.5" ET22 front and 19x10" ET25 rear wheels. Some negative camber is dialed in as well and likely required in order to prevent rubbing.
--Dylan
      05-07-2019, 08:08 PM   #58
GasBurnlife(landapanda)
Expert@ApexRaceParts - can you please provide an estimated date when these wheels will be ready to ship? Interested in a set in the following order: Anthracite, Black, Silver. Thanks!
      05-07-2019, 09:09 PM   #59
somberlaine
somberlaine's Avatar
Drives: 2020 M2C (ED 6/6/19)
Do these wheel locks fit M2C stock wheels?
https://www.apexraceparts.com/access...-lock-set.html
      05-09-2019, 06:52 PM   #60
Expert@ApexWheels
3525
Drives: M3
Thanks for the post! All colors will be shipping in July. Although the group buy has ended, you can still pre-order them at a discount directly on our website:
Front wheels: https://www.apexraceparts.com/wheels...c-7-wheel.html
Rear wheels: https://www.apexraceparts.com/wheels...c-7-wheel.html
They sure will.
--Dylan
      05-14-2019, 04:07 PM   #61
Fenerbahce
Drives: '19 M2C
Hi Apex, would 255/35 in front and 275/35 in rear work with these wheels and avoid the need for any camber work (assuming Pilot Sport 4S)? I'm sure a lot of us are looking for plug n' play and would rather not have to adjust the suspension to ensure there is no rub. Would appreciate your thoughts!
2019 M2 Competition 6MT - ED October 5, 2018
2018 Honda Accord Sport 1.5T 6MT (daily driver / family hauler)
      05-14-2019, 06:34 PM   #62
Expert@ApexWheels
3525
Drives: M3
Hey there!
While the 255/275 stagger can fit, please keep in mind that these tire sizes will be quite stretched. To prevent this, we would recommend sticking with the 265/285 tire stagger.
We did test our 19x9.5 ET28 up front on a standard M2 Competition and even with a 265mm R888R, the tire sat flush with the fender. We would recommend a small amount of camber up front if planning to run an R compound tire similar to this.
There is a good chance that with a standard and less aggressive 265mm street tire, would provide a much easier fit. This would be ideal as it would still provide proper sidewall support and will likely not need any camber adjustment.
- Max
      05-17-2019, 07:56 PM   #63
O Haiii
Drives: Toyota Tercel
Please please make the Arc 8 wheels in 18" that will clear OG M2 brakes. From what I'm reading in multiple threads that is what everyone is interested in, not the 19" versions, myself included. 18" Arc 8s with beefy tires is straight porn.
      05-20-2019, 12:19 PM   #64
Expert@ApexWheels
3525
Drives: M3
We certainly agree that the 18" ARC-8 would look great on the M2 and all other F8x chassis cars. Unfortunately due to the concave spoke design and the natural design of the barrel, the ARC-8 is not quite as "Big Brake" friendly as the other 18" wheels that we have on offer. Brake clearance is something that we take very seriously so thank you for the feedback!
The 19" wheels we have developed here are intended for those with the M2 Competition with the larger 400mm OEM brake system. This kit is VERY large and requires a minimum of 19" wheels to clear, regardless of design or manufacturer.
- Max
      05-21-2019, 06:27 PM   #65
I run this setup (255/275) on PS4s with no issues on OEM wheels and suspension.
I recently installed M Performance Suspension and camber Plates and plan to wait for the new 19" Apex wheels (9.5"/10.5") and go to 265/285 setup.
      05-23-2019, 11:29 AM   #66
Proctor750
Drives: E30 M3
So the new EC7's in 19x9.5 et28 and 19x10.5 et45 changes things a bit (I have some on order).
I am determined to get RS4's on this thing. With the above EC7's on stock suspension with camber plates (~-2.5 camber atm) will 275/35/19 front and 305/30/19 rear work? I know the tire height is 1.5% change which is just outside of the green zone but..
Thoughts?
