M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 275/295/30-19's fit fine
      03-31-2018, 06:40 AM   #45
Daleb
Originally Posted by Stage IV View Post
Just got my 295/30 installed. Holy shit are these beefy and intimidating. Gotta remove the spacers as it bulges out too much.
Stock suspension or lowered?
      03-31-2018, 08:49 AM   #46
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
Originally Posted by GreatWhiteM2 View Post
Which brand did you go for mate?
Michelin PS4S on stock suspension. I need to remove the 12mm spacers though. It's currently overhanging about 1/2 inch
OP, thanks for being one of the early adopters of 295s and posting pics. Otherwise, I would have gone with 275 or 285.
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
M2C_PLUS1774.00
M-Supra394.50
DaFish157.50
      03-31-2018, 03:09 PM   #47
Aronis
Aronis's Avatar
2272
Drives: 2018 M5
Nice wide tires!!!!!!!!!!
How is the ride? Road noise? Handling?
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      03-31-2018, 05:48 PM   #48
Dirtboy
Dirtboy's Avatar
Drives: F87, F97
No kidding. I'm gonna be going this route pretty soon as well.
No Boost4021.00
      04-01-2018, 08:38 AM   #49
bi0hazard
bi0hazard's Avatar
133
Drives: '17 m2
I like . What do ya'll think about 295/35 (non-lowered)? The 30 sidewall increases the gap between fender. 35 will decrease the gap, though it may rub?
      04-02-2018, 01:36 PM   #50
dcmac
dcmac's Avatar
442
Drives: '18 LCI M2
Loving this thread.. keep the pics coming!
      06-10-2018, 10:51 AM   #51
ZM2
Drives: 2017 LBB M2
Michelin PS4S. Still have the stock 245 up front as there's still significant meat on them. The rears lasted one "season" because of the car's ridiculous torque.
How’s the rear grip with the 295/30 4S and all the extra power? Is the wider 4S grippy enough to put the power down?
Also, how much harsher is the ride with the 30 vs 35 4S?
      06-10-2018, 11:16 AM   #52
No Boost
No Boost's Avatar
Originally Posted by ZM2 View Post
How’s the rear grip with the 295/30 and all the extra power? Is the wider 4S grippy enough to put the power down?
Also, how much harsher is the ride with the 30 vs 35?
The extra ~30mm certainly do help but the rubber itself is a huge step up. Going from Contis to Michelin's best all-around street tire is night and day. I can actually hook up in the wet now. The only time the TC light flashes (dry road conditions) is when cornering on uneven pavement (blame that on suspension and damping) and WOT from a standstill (plus a chirp from 1st to 2nd). Power gets down in all other situations.
I haven't noticed a change in ride quality. It's a lower profile tire but better rubber compound so it's a wash in the comfort department.
ZM22810.50
      06-10-2018, 11:44 AM   #53
ZM2
Drives: 2017 LBB M2
Sounds good. I’d be coming from a 285/35 4S, which doesn’t seem enough for Stage 4 power (which I’ll be going to soon).
I don’t want to compromise daily noise and comfort with an Extreme Summer tire, so the 30 series 4S may be the best choice.
      06-10-2018, 12:03 PM   #54
No Boost
No Boost's Avatar
It's enough tire for sure. I was actually thinking about going Sport Cup2 rears but wet traction is horrible.
      06-10-2018, 12:28 PM   #55
ZM2
Drives: 2017 LBB M2
Traction below 45F is also terrible with the Cup 2s...
No Boost4021.00
      06-11-2018, 03:10 AM   #56
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Current '22 X3M LCI..
      06-12-2018, 12:14 AM   #57
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Who can comment on PS4S 295mm vs RE71R 265mm, grip wise?
I'm on RE71R and am trying to decide on my next set of tire. But 295 30 19 will force me to either AD08R or PS4S.
Stock PSS 265mm is completely junk BTW, compared to RE71R.
I used to think anything from max performance category is junk, including 295 PS4S. But had a second thought because recently BM3 flashed my friend's M2 and had fun with his car on 285mm P Zero. Surprised his grip was way better than when I was one year ago with 265PSS. I think tire width really makes a difference.
Lemania 2320
      06-12-2018, 12:43 AM   #58
ZM2
Drives: 2017 LBB M2
Too many variables here.
A 265 4S will smoke a 265 71R in the rain and cold. Assuming you mean dry, warm weather (and having driven many miles on both tires), I doubt a 265 71R could match a 295 4S. I ran similar times on track with a 265 71R and a 285 4S.
If I’m going easy fitment, warm weather, and don’t care about comfort, I’d run 255/285/35 F/R 71R. Colder temps & rain, same sizes in 4S.
Extreme fitment, 265/35 305/30 71R or 265/30 295/30 4S. The 71R is loud and uncomfortable for a street tire.
      06-12-2018, 01:14 AM   #59
SeanWRT
SeanWRT's Avatar
3179
@ZM2 thanks for your first hand experience.
71R has been the king of extreme and even beats most of streetable competition including cup2. I know how day and night difference it makes over PSS.
How much better is 4S than PSS? Not much according to tests.
The way you made 4S sound like, it's touching 71R performance. Which with all due respective, I seriously doubt.
Lemania 2320
      06-12-2018, 09:04 AM   #60
ZM2
Drives: 2017 LBB M2
In your post you mention 265 71R vs 295 4S. These will be close in grip depending on what you’re doing with the car, but the wider 4S is likely the winner.
I’ve run 265/35 71R and 285/35 4S on track and times are very similar. I was able to get the power down earlier with the wider 4S, but the 71R had higher lateral grip in the corners (1.1g vs 1.03g). A 295/30 4S is quite a bit wider than even the 285/35, so I’d suspect it to be the winner on track vs a 265/35 71R.
If you have the same amount of 71R and 4S rubber under the car, the 71R will smoke the 4S, unless it’s raining or cold. That’s why I’m going to try 265/35F and 305/30R 71R on a 9.5 ET33 and 10.5 ET45 track wheelset.
One of my track buddies (and forum member) runs 255/35 & 285/35 71R on his OEM wheels all the time. It’s a very quick setup and is likely quicker than a 295/30 4S setup, but again, loud on the street and can be sketchy in the cold & wet.
SeanWRT3179.00
      06-13-2018, 07:57 AM   #61
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Your friend who runs the 255/35 & 285/35 71R, is his M2 all stock suspension?
      06-13-2018, 10:58 AM   #62
ZM2
Drives: 2017 LBB M2
Stock suspension, camber plates up front at -3.0, rears at -2.0.
I’ve run similar sizes with similar camber and 15mm lower.
      06-13-2018, 08:32 PM   #63
chief1richard
2018 M2  [0.00]
I'm trying to get maximum tire on OEM suspension with no camber plates. Do you know if that set-up would work without camber plates?
ZPrime611.50
mjsaville101.00
      06-13-2018, 10:32 PM   #64
ZM2
Drives: 2017 LBB M2
I think it would, but there’s a 265/285 thread floating around somewhere that may have more info.
The 71R is wider than typical in its size, which is why I mention the 265 thread. You won’t have any issues in the rear with 285.
      06-16-2018, 08:34 AM   #65
No Boost
No Boost's Avatar
Editing my initial reply. I did a quick WOT in 3rd at 3000 rpm and TC light did a quick flash (felt slight slippage) then hooked up until throttle liftoff at 4000. This was on a sunny 80 degree day. The point is, when running higher boost, some slippage is going to occur no matter how much rubber we have. It is a front engine car after all.
ZM22810.50
      06-16-2018, 08:43 AM   #66
SeanWRT
SeanWRT's Avatar
3179
How's the rear grip with the 295/30 4S and all the extra power? Is the wider 4S grippy enough to put the power down?
On 3rd gear, for STG4 power it would only happen (though barely happen with good road and temp) on downshift where torque ramp up. Mechanic of material dictates that it requires much greater force, or traction in our case, within certain distance in the moving direction to handle the increasing acceleration than a constant one.
Starting from low rpm, STG4 power would be far too weak to lose traction even on stock tire on 3rd. I know that because I log full 3rd and 4th gear all the time. Try that to let m2 disappoint - turbo lag, no torque, feel numb all the way to redline etc. Use M4 instead, even stock, to understand the difference.
BTW, that not losing traction, is a big part of why linear power delivery is preferred as OEM approach.
If 295 PS4s is anywhere near 265 RE71R. When warmed up, you'd feel there is too much traction for 400hp/420wtq even on 2nd.
Lemania 2320
