M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Wheel Stud Length?
      06-06-2021, 07:26 AM   #1
Midtown2020
Drives: 2020 M2C (6MT) & X3MC
Wheel Stud Length?
Does anyone know What length wheel studs would be ideal to use for:
10mm spacers front and rear
Swapping between using both a set of 788m wheels and 763m wheels
I’d like full nut engagement of course, but don’t want the studs too long so they don’t look weird on a daily driver.
Thanks!
Last edited by Midtown2020; 06-06-2021 at 10:44 AM.. Reason: Want to post in different forum
      06-06-2021, 02:25 PM   #2
H20neun
H20neun's Avatar
Germany
114
Drives: M2 LCI
75mm total length of wheel stud is enough, everything else will poke out
10mm spacers in the front
5mm spacer in the rear
      06-06-2021, 03:19 PM   #3
Midtown2020
Thank you!
      06-06-2021, 04:17 PM   #4
M Fifty
844
Drives: M2 & 330CI
Pedant moment: The M2 doesn't have studs - but bolts.
You can retrofit studs if you want though and then use lug nuts to suit.
