12-06-2020, 02:20 PM | #23 |
Rep 8,970
Clearance is very tight on M2C.
Different makes of the same size have different shoulder profiles and may rub even near standard size. I recall this with my old 335i, lowering with one tyre size ok, then a different make tyre of the same size would rub.. Winters in my experience have "broad" shoulders with tread extension further over onto the sidewall edge. Perhaps staying at OE size or even going down to 235 would have been better? |
12-06-2020, 02:27 PM | #24 | |
2530
Rep 1,908
I am here to support your post, even though I openly admit no special insight on my part. The basis of my support lies with the 'broad shoulder' statement you made. The PSS is very round compared to the tires BigKutta purchased. . . . suggesting to me it is the tires and not the wheels. ///AVM |
12-06-2020, 02:28 PM | #25 | |
Rep 4,048
///AVM2529.50 |
12-06-2020, 02:31 PM | #26 | ||
Rep 4,048
///AVM2529.50 |
12-06-2020, 02:37 PM | #27 | ||
Rep 4,048
A lot of posts here are pointing to a fender liner in the comp that leaves a lot less room, I just never imagined that one size up on winters would cause an issue. |
///AVM2529.50 |
12-06-2020, 02:54 PM | #28 | |
6637
Rep 4,145
Drives: '18 M2 6MT
Stock 245/35 MPSS: 8.8 TW, 25.8 OD Sottozero 255/35/19: 8.3 TW, 26 OD So the SHOULDER is .5 (12.7mm, 6.35 on each side) narrower, but .1 (2.54mm on the top side) taller. This tire should fit EASIER than the stock tire. So either tirerack's specs are wrong, or something else is off. If both are correct, and the rub exists over 2.5mm, the vehicle should come with a damn warning tag stating that you can't even change tires without the possibility of rubbing. Which is, well, stupid. |
12-06-2020, 03:10 PM | #29 | |
2530
Rep 1,908
One thing I have learned is that when you and Poochie start getting technical about things it is time for me to listen . . . so, am I hearing you correctly in thinking the tires are not the problem and we are back to square one in trying to solve this mystery? ///AVM |
12-06-2020, 03:52 PM | #31 | |
6637
Rep 4,145
Drives: '18 M2 6MT
12-06-2020, 03:56 PM | #32 |
Rep 4,048
12-06-2020, 04:53 PM | #33 |
Rep 4,551
Drives: 2015 328d xDrive
+1
NYC Bimmer259.50 |
12-06-2020, 05:16 PM | #34 |
Rep 4,048
So any issues with mild rubbing, either on the liner or the tire? I know it's not desirable, but just wondering if it'll cause any issues if I keep the tires on for 3 months.
12-06-2020, 05:39 PM | #35 | |
Rep 4,551
Rubbing in the rear is a whole nother can of worms as there is some metal back there you have to watch out for: https://f87.bimmerpost.com/forums/sh....php?t=1780655 |
NYC Bimmer259.50 |
12-06-2020, 05:42 PM | #36 | ||
Rep 4,048
12-06-2020, 05:52 PM | #38 |
Rep 4,048
Thanks please do. Assume you have a Comp, not OG?
12-06-2020, 06:10 PM | #39 | |
Rep 81
I noticed it the first time I backed out while turning the wheel. These are the same sizes as the stock tires. I did notice the edges of the stock tires have a bit of a radius on the outer edges as compared to the winter performance tire which is much more angular and square. I suspect that change in profile is the cause. It does not happen often enough to irritate me but it’s there. I should note the tires were mounted on my stock wheels. |
BigKutta3906.50 |
12-06-2020, 06:22 PM | #40 | ||
Rep 4,048
12-06-2020, 06:35 PM | #41 |
Rep 160
Huh that’s suboptimal clearance especially after snow and slush buildup. Guess I’m glad I went for narrower 235 winters...
Did see the guys post on bending the wheel arch plastic away, really smart. |
12-06-2020, 06:41 PM | #42 | |||
Rep 339
Drives: 2020 M2, 6MT
(PA4s in stock size with stock suspension) |
12-06-2020, 07:10 PM | #44 |
Rep 4,048
I did, but I shouldn't have to take a blow torch to my M2 to put in a 10mm wider tire... Knowing my luck, I'll fry/melt something on the other side
