11-02-2017, 05:19 PM | #133 | ||
Rep 4,254
In the end I am done discussing the speculation of one single members experience and your subjective interpretation of that. I'll wait for literally any evidence whatsoever.
///M Power
11-02-2017, 09:01 PM | #134 | |
Rep 399
Drives: 2017 BMW M2 6MT
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold |
M3 Adjuster7905.50 BAN_M2C4180.00 |
11-03-2017, 04:31 PM | #135 | ||
Rep 3,077
Follow me on IG
///M²282.50 |
11-04-2017, 09:48 AM | #136 |
Rep 791
L17193I flashed on pre lci 6mt
Collected my 6mt pre lci. Now with L17193I flashed.
Idrive and CarPlay much better. Reverse camera when switching back to 1st gear immediately switches off. No more annoying beeps. Car in comfort mode is lot more responsive. Use to have an annoying 1st to 2nd gear jolt. No longer occurs. Terms of exhaust noise... I think it has toned down a bit. I have the mpe & fabspeed dp, on track mode it's not as burbly as before...
YMB F80 M3 DCT (Gone but never forgotten)
AW F87 M2 6MT (Current whip) |
blackholescion272.50 Bosozoku693.50 |
11-09-2017, 04:23 AM | #137 |
Rep 483
This might be a stupid question, i have an early 17' one of the last PRE LCI's
the weather app in my car has stopped working so they are suggesting a reset or an update but only to the idrive not to the engine so i was told it won't affect the sound of the exhaust only the sound of the interior speakers and idrive. my car is loud af with M performance exhaust i get all sorts of pops and bangs and crackles, so i am scared that i will lose all this if i update this? can anyone clarify if the Idrive update affects the engine and exhaust? because i was told you have to do a seperate engine update for this to affect the noise of the car which i really really really don't want. |
11-09-2017, 09:44 AM | #138 | |
Rep 4,551
Drives: 2015 328d xDrive
Worth doing if you can get it done free but i don't see what all the hype is about, in my experience it's the exact same car. No noise or performance changes. It's identical. Also, to everyone complaining about the PDC beeping, just know that there are multiple solutions to this problem already, neither of which require you to leave your car overnight at the dealer: http://www.bimmercodeapp.com/ https://www.ecstuning.com/b-genuine-...t/61319252912/ |
11-09-2017, 09:57 AM | #139 | |
Rep 1,153
11-10-2017, 12:40 AM | #140 | |
7906
Rep 11,785
11-10-2017, 07:56 PM | #141 |
Rep 4,254
Oh I suspect he's good to go.
///M Power
11-10-2017, 09:07 PM | #142 | |
Rep 752
What does the bimmercode solution do, completely turn off PDC? Thanks.
11-10-2017, 09:14 PM | #143 |
Rep 4,551
4
11-10-2017, 09:16 PM | #144 |
Rep 752
11-11-2017, 03:05 PM | #145 | |
Rep 259
Hi andrewc89,
I'd already purchased both the Bimmercode app, and the switch to manually deactivate the beeping ... but as my car is an LCI with newer firmware, BMW have changed the behaviour (as others have documented). This new behaviour - halting the reverse camera view when the car is taken out of reverse - doesn't suit me: I would rather the camera stay on ... or at least be controllable view the switch up to a certain speed (say 5mph/kmh). This is so I can pull forward into a parking spot and see when the back-end correctly in etc. So the PDC Shutdown Distance Threshold seems to indicate that I can now reinstate this behaviour (e.g. set it to any particular distance) and then control the camera on/off via the switch...? Have you used both (the switch and Bimmercode) on the later car firmware to see what it does..? Cheers, Last edited by V.Smurf; 11-11-2017 at 03:24 PM.. |
11-11-2017, 05:11 PM | #146 | |
Rep 4,551
I have not touched the PDC the setting on bimmercode as i like it as is (shutting off when taken out of reverse). |
V.Smurf163.00 NYC Bimmer259.50 |
11-11-2017, 06:54 PM | #147 | |
Rep 719
11-11-2017, 10:26 PM | #148 |
Rep 752
Coded this, and when I leave reverse it still beeps. Double checked to see if it coded and it did. 17 M2, 6MT...is yours manual too? Thanks.
11-11-2017, 11:24 PM | #149 |
Rep 4,551
Yeah mines 6MT as well. That's odd it didn't work. I could have sworn that was the setting i changed to get it to stop beeping. This was like a year ago so it's possible i had to change something in expert mode that i'm forgetting about. i'll have to play with it and figure it out again. Sorry for getting your hopes up.
BAN_M2C4180.00 NYC Bimmer259.50 |
11-11-2017, 11:29 PM | #150 | |
Rep 259
Thanks again andrewc89,
Does it:
I've shot through a few of the questions to the Bimmercode folks, but would you mind sharing the path/breadcrumb as to where the distance options you displayed sit within Bimmercode..? Cheers! |
11-11-2017, 11:37 PM | #151 | |
Rep 752
11-11-2017, 11:50 PM | #152 | ||
Rep 4,551
It appears as though my last post with the screen shot of the displayed distance options didn't work for someone. It's possible i was mistaken that this was the setting that needed to be changed. There are more PDC settings if you hit expert mode and go down to 3200-3205 but I would email the developer and ask for more info before you start adjusting anything in there. Last edited by AndrewC1989; 11-11-2017 at 11:58 PM.. |
NYC Bimmer259.50 |
11-28-2017, 03:01 AM | #153 |
587
Rep 898
Can anyone post their ISTEP versions after getting their dealer flash? I’m about to flash F020-17-11-520 v3.63.0 PSDZ. I was on v61.4 before which wasn’t as refined and then I updated to v62.4 which had the best refinement and retained the burbles. V62.5 did not have any noticeable changes other than FEM_GW and ASD?
V63.0 flashes the DME again and is a relatively recent PSDZ Turns out DME wasn’t flashed. Just CAF/NCD changes flashed via cdDeploy Soooooo Can’t tell this time what the differences are. Maybe just changes for 2018 LCI cars Last edited by cookiesowns; 11-30-2017 at 01:47 AM.. |
11-28-2017, 05:25 PM | #154 | |
Rep 124
