04-12-2022, 12:49 PM | #1 |
Rep 126
Went to a track day, what happened to my tires?
So I took the M2 comp to a track day over the weekend.
Cool day, 45F, track was Autobahn South. At the end of the day, I inspected teh tires, and this is how my fronts looked Both fronts looked like this, rears were fine. My alignment is also in the pics |
04-12-2022, 01:04 PM | #2 |
Rep 3,412
What's the question? Street tires on track under a heavy car with non neutral toe alignment = dragged rubber and wear.
Is it the little tears that are troubling you?
04-12-2022, 02:29 PM | #3 |
Rep 126
My Toe-in is fairly neutral.
The concern is the tears on the inside. I tracked plenty of cars in my life time, some heavier than the M2 and never saw this type of wear. |
04-12-2022, 03:01 PM | #4 | |
Rep 3,412
Good resource: https://suspensionsecrets.co.uk/tyre...g-and-wearing/ "Inside Edge If tearing is occurring on the inside edge of the tyre then there is likely to be too much toe present on the tearing wheel. Reduce toe angle to reduce tearing."
04-12-2022, 05:08 PM | #5 | |
The Seeker
14034
Rep 3,369
04-12-2022, 05:11 PM | #6 | ||
Rep 3,412
///MPhatic14034.00 |
04-12-2022, 07:25 PM | #7 |
Rep 584
Brake less and take corners faster
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
04-12-2022, 09:18 PM | #9 | |
Rep 3,412
Ditch that toe or if you're going to accept the accelerated wear, at least get the benefit of turn-in with Toe Out.
04-13-2022, 10:45 AM | #10 |
Rep 296
That's not a toe issue. Your toe settings are benign.
Too much neg camber or tire pressures too high in front. Did you take tire temps? I'd bet they were toasty on the inner edge. |
04-13-2022, 03:10 PM | #11 |
Rep 126
That's my guess now as well.
My pressure monitor was showing 41PSI at end of session, so yeah, I think I was too high. What do you guys usually run your super sports at on track days? |
04-20-2022, 10:57 PM | #13 |
Rep 584
High tire pressures would most likely, all else remaining equal, result in higher wear in the middle of the tire rather than higher wear on either of the edges. The higher wear on the inside of your tires suggest that you are running too much toe or too much camber for a given speed. I agree that the toe in is rather benign so likely not the cause, though I would adjust to slight toe out at your next alignment. The only other thing I can think of that would result in higher wear on the insides is if you were occasionally locking up your tires under braking.
04-22-2022, 09:32 AM | #14 |
Rep 379
I think your settings look good, great starting point for the track. Less toe is also better for inside tire wear.
It appears to me that you overheated the tires a bit. Not all that hard to do, when you feel the tires getting "greasy" back off a lap or two to let them cool down a bit. If you keep pushing, they will only get hotter. Michelin like between 34-38 psi hot.
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 |
Noel91190.00 |
04-23-2022, 10:20 AM | #17 |
Rep 1,263
There are a ton of factors that probably contributed to this wear pattern on his fronts.
Hot TP's way to high. There is almost no wear on the outside 3rd of the tires. Which is: Front Neg Camber excessive for conditions (track temp) and pavement type, tires mechanical traction, suspension, or even driver skill or some combo of these. I'd shoot for 33-34 Hot and run about 2.5 Neg camber with that tire on a track surface that cold. I'd be curious to see how they look after your next track day with adjustments... My $.02
04-26-2022, 03:48 PM | #18 | |
Rep 126
My goal is to change one thing at a time, so next track day Ill control the pressures better, shoot for 36psi max and see what happens, next will be camber decrease if things still look bad.
