M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > "black stuff" from the right 2 exhaust pipes
      04-28-2021, 02:42 PM   #1
ThatBlueM2
ThatBlueM2's Avatar
Drives: BMW F87 M2 DCT
Hi everyone,
new here. Recently purchased a 2018 M2 with 26kkm on it. I'm not too savvy when it comes to cars, so bear with me please. Today I've noticed this:
As you can see, that black stuff, whatever it is, is only coming out of the right two pipes. Is this normal / what is it?
Thanks
      04-28-2021, 02:54 PM   #2
CTSean
Drives: LCI BSM MT M2
Carbon deposits from running while everything is cold. The exhaust valve closes off the left side so you only get the buildup on the right. Completely normal. If it's really stuck you might need a metal polish to remove it.
      04-28-2021, 02:59 PM   #3
ThatBlueM2
ThatBlueM2's Avatar
Thanks a lot for the explanation!
      04-30-2021, 12:30 PM   #4
CalAcacian
Totally normal. If you want to get rid of it I suggest a device like the Mother's powercone on a drill with a polishing compound. But it will only ever be a temporary fix.
      04-30-2021, 04:26 PM   #5
M Fifty
844
Drives: M2 & 330CI
If you see some stainless steel tips you like the look of, fit them instead. They will clean up better.
