View Poll Results: Have your M2C rear indicator units failed? | |||
Yes | 137 | 64.02% | |
No | 77 | 35.98% | |
Voters: 214. You may not vote on this poll |
01-08-2022, 12:14 PM | #243 |
Rep 163
I've had this issue with my right rear turn signal on and off for the past year, but recently it has been occurring more often. I was going to use bimmercode to disable the warm check, but it sounds like that is not the solution? Is replacement by the dealership the only option?
This is on a '19 M2C. |
01-08-2022, 03:12 PM | #244 | |
Rep 8,972
Not worth it for me. I'm getting used newer darkline tailights off ebay. |
01-08-2022, 07:54 PM | #245 | |
Rep 140
I've had this problem for about a 2 years but recently it has gotten more frequent so took it to the dealership and they replaced the tail light assembly. My DME was not updated. |
01-08-2022, 08:26 PM | #246 |
Rep 392
Drives: 2019 BSM M2C
I had both tail lights fast blink a few times over the last year and let the dealer know when I took it in for an oil change. They hooked it up and read that the left had errored 3 times and the right 4 times so they replaced both tail lights. Happy I didn’t have to do anything.
01-09-2022, 10:59 AM | #247 |
Rep 163
Nice, thanks all. I've setup an appointment for next week to take the car in. I'm not tuned so not worried if they do end up updating the car either, as I plan to keep the car stock anyways.
01-25-2022, 08:49 PM | #248 | |
Rep 7,336
01-26-2022, 02:44 AM | #249 |
Rep 8,972
I first thought cleaning / greasing contacts made it ok for a while (as there was often water in/around the connector body). But now I reliase it was the physical action of removing the light that "fixes" the problem temporarily.
Giving the still-fitted faulty tail light a "whack" with the palm of my hand sorts it in the same way, could be for weeks or just a day. Being parked up outside in cold / damp weather exacerbates it. So it is some electro/mechanical problem inside the light fitting. I'm out of warranty, I'll probaly upgrade to new facelift smoked rear lights (which I don't have) then I'll break open one of the old lights and have a look. Last edited by doughboy; 01-26-2022 at 02:50 AM.. |
01-27-2022, 06:05 PM | #250 |
Rep 212
My car’s out of warranty in March, so I mentioned this problem to the dealer last time I took it in. They replaced both tail lights under warranty but I suspect the problem will eventually return.
01-27-2022, 06:24 PM | #251 |
Rep 6,976
Drives: 2018 M2 AW DCT
Had my right taillight replaced on Monday. Second time I had the problem. First time they just played with the wiring. This time the wiring and connectors looked good.
Interesting that they were able to pull 106 errors. |
01-28-2022, 11:54 AM | #252 |
Rep 163
I ended up cancelling my dealer appointment as the issue stopped happening, and I didn't want to leave my car with them for an entire day as they try but fail to reproduce the problem. I've had the problem intermittently for over a year now, so I know it will come back eventually. I also have noticed that the problem seems to occur more often when the weather is very cold.
01-28-2022, 12:11 PM | #254 |
Rep 163
01-28-2022, 06:25 PM | #255 |
Rep 6,976
05-22-2022, 02:32 PM | #256 |
Rep 556
So what’s the bottom line with this?
I’ve had my tail light replaced and the problem immediately came right back. The dealership wants the car back to escalate. They said it could take weeks working through BMW to trace the problem since they may end up sending someone to inspect the problem. Wiring harness was discussed. They were receptive to the idea of me coding the error out (off the record) but the car is under warranty and ultimately recommended going through the process. Is this even a fixable problem otherwise? |
05-22-2022, 02:52 PM | #258 | |
Rep 556
I’d hate to leave my car (potentially) for weeks for no good reason - feeling a little pessimistic about that. |
05-22-2022, 03:16 PM | #259 | |
Rep 8,972
Try it and see. Next time the turn signal stops working give it a whack. |
05-23-2022, 06:32 AM | #260 | |
Rep 33
Disconnected.
05-23-2022, 06:39 AM | #261 |
Rep 8,972
I coded mine out too, but then you lose all failure indication (rapid flash / bong etc).
At first I thought great fixed it but then had drivers honking and giving me the finger when I changed lanes... turns out indicator not working but I didn't know. So I coded it back in... Now when it bongs I just get out and hit the light, works for a week or so. |
05-23-2022, 07:26 AM | #262 | |
Rep 556
05-23-2022, 10:20 AM | #263 |
Rep 8,972
I think there's likely more that one failure mode at play here.
Some have a physical lamp fault, maybe internal. Some have connector / damp issues. Some seem to have only "fake" faults due to REM config for light controller. Some maybe wiring / ground issues... Some maybe combinations of all! |
08-03-2023, 09:36 AM | #264 |
Rep 1
Wow...this took me quite a while to read through.
First of all - thank you to Poochie, for even trying to help. It's really appreciated. Secondly - I have a 2018 F87C, This issue occurred 3/4 weeks ago for the first time. Took it straight to the dealer, they only replaced one side (the driver side rear light cluster). The following day I went out for a drive, the other side failed. It only flickered rapidly / appeared on the iDrive once. Since then, I drove the car perhaps 5/6 times and it never came back. I am going to be visiting the dealership again next week on Friday as they have agreed (reluctantly) to replace the other side FOC. What a nightmare 😅 To anyone who is truly interested in learning about this issue I (politely) advise you to In its entirety... so many people have asked the same question over and over and it has been (patiently) explained. Also - glad that guy has since been banned. Some of the comments had me chuckling but nonetheless, it was completely deplorable behaviour. Last edited by RyGuyM2C; 08-03-2023 at 09:41 AM.. Reason: Misspelled word |
