06-17-2023, 09:26 AM | #1 |
Rep 79
Doors/Trunk Wont Open/Close With Confort Access
2019 M2C—Both doors and trunk no longer open/closewith comfort access. The push to start still works, but besides that I can’t seem to get it to work anymore. I first thought the battery in the fob might be dead, so I used my spare fob that had the problem as well.
I’m not sure if this is related in anyway, but a day before the confort access stoped working, I used this quick detailed spray on the car and wiped some down on the door handles. I did clean those handles and back trunk down with Goo Gone Automotive as well as WD-40 but still no luck. Has anyone else had this problem? What’s the fix here? Did the quick detailed block a sensor for the comfort access or did the sensors just die? |
06-17-2023, 06:25 PM | #2 |
Rep 75
My CA has been out for a few months now. If your lucky you might get a code with ista. Mines not throwing a code so I'm SOL. Other than that it might be a door handle. A bad antenna, I think there's six or seven. Hell, it might just start working again, never know.
06-18-2023, 01:14 AM | #3 | |
Rep 7,429
Because what I found is that the wireless signals on these things will typically jam the comfort access systems as the batteries get lower - so you should also measure the voltage on your batteries in the key fob. Other than that you should scan for codes - because it could be the comfort access module or antennas.x
06-18-2023, 02:28 AM | #4 | |
Rep 79
06-18-2023, 03:34 AM | #5 |
Rep 7,429
The phone alone wouldn't do it unless the battery was incredibly low. You can use the veepeak in conjunction with something like protool or bimmerlink to scan the codes - given that these 2 apps support the veepeak adapter. But I would go with protool because it is alot more capable if you also buy the coding license.
06-18-2023, 03:36 AM | #6 | |
Rep 79
06-18-2023, 07:26 AM | #7 | |
Rep 75
Delete users in idrive Reset idrive Remote Battery Reset CA through ista Got a bad antenna Door handle sensor went bad, probably the most common Fuse Wiring damaged CA Control box Then some say it just starts working again |
06-18-2023, 09:07 AM | #8 | |
Rep 79
Idk if it’s the door handles, because the trunk doesn’t open either. I have to literally unlock the car to open the trunk as well. |
06-28-2023, 01:51 PM | #12 |
Rep 79
I have a Veepeak OBD Bluetooth adapter I used to code the car with Bimmercode. Is there any way I can read error codes from this adapter?
Also, If I go ahead and reset the items you mentioned before, will this affect my car because of the codes? Or will I have to re-code the car again? I'm totally new to this, and not really knowledgeable about anything. Thank you for your patience and I appreciate the help! |
07-04-2023, 01:07 PM | #13 |
Rep 79
07-07-2023, 05:14 PM | #15 |
Rep 75
I've been talking to a guy in Philadelphia. He fixed a car with similar issues the other day and he said he had to reprogram it.
"I am not a fortune teller, there is no crystal ball skill. I wrote that a couple of days ago I made a car after the theft, the keys did not open the car, but it was possible to start it. I solved the issue by reprogramming." Last edited by TheSandman_M2; 07-07-2023 at 05:19 PM.. |
07-07-2023, 05:15 PM | #16 |
Rep 79
Yeah, the fob still unlocks and starts the car just fine. I just can’t lock/unlock the car when I either put my hand over the door handle or touch the ribs
07-07-2023, 05:48 PM | #18 | |
Rep 79
07-07-2023, 05:53 PM | #19 | |
Rep 79
I know this is a “small” issue, but it’s become quite cumbersome to lock and unlock my car. Especially when I need to grab something quickly. |
