07-24-2020, 08:24 PM | #45 | |
Rep 857
07-24-2020, 09:20 PM | #46 |
Rep 3,660
Drives: 981 Cayman GTS
What kind of tolerance level am I supposed to have to tolerate being literally launched out of my seat as a 200lbs person on the highway or backroad bumps? I put aftermarket springs on my M4 Comp and they didn't work well at all with the adaptive suspension. I thought the ride quality was pretty bad and crashy but was never this extreme. Even that experience was acceptable for me and I lived with it 2+ years without any issues. Ohlins on my M2C was not crashy at all despite the high spring rates but it sucked at handling the bumps/dips on public roads. I still think R/T is great for track duty and it let me set personal bests at Laguna (consistently ran 1:40-1:41 and even dipped into high 1:30s). It just doesn't do well at all on the street in my opinion.
07-24-2020, 10:05 PM | #47 | |
Rep 857
07-24-2020, 10:15 PM | #48 |
Rep 88
07-25-2020, 01:48 PM | #49 |
Rep 199
Ohlins R &T spring rates
I am running 80Fr 160Rr N/mm which at 20 clicks is a little bit stiffer than stock, but close...even closer now that I installed the aluminum carbon fiber strut tower bracing. Going too far in either direction (ie more than 25% stiffer or softer) would likely be out of range for the valving of these Ohlins, at least that is what Jake (the Ohlins tech rep) said when I reached out to them prior to selecting my spring rates.
07-26-2020, 05:48 PM | #50 |
Rep 2,926
Drives: Cayman GT4, 135i
As an update i spent some time this weekend diagnosing what was causing my suspension issues. For reference, I am running 80F / 160R springs.
Issue 1: front preload wasn't set. I measured the top and bottom of the spring and it was about 200mm. Per Ohlins 5mm of preload should be set with the spring measuring 195mm once slightly compressed. Issue 2: rear ride height too low. Per Ohlins the rear pre load should be 40mm. On measuring my car it was close to 20mm. After adjusting the car rides super smooth at 16 clicks all around. Surprised my installers didn't set this correctly from the get-go but I'm very pleased with the results.
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
bentom2335.50 |
07-27-2020, 04:45 AM | #51 |
Rep 1,337
I assume close enough is good enough
moveswiftly381.50 |
07-27-2020, 08:36 AM | #52 | |
Rep 2,926
Current: M2CS
08-11-2020, 10:24 PM | #55 |
Rep 857
Here's a few. Keep in mind ride height is adjustable and wheels in the pics are 19" front and 20" rear.
08-14-2020, 10:29 PM | #56 |
Rep 309
Drives: 2018 M2 LBB - 6MT
Mine corner balanced on Ohlins with -2.8 degrees of camber up front.
10-03-2022, 01:57 PM | #57 |
Rep 303
Im considering ohlins for a strictly street driven car. Are there any updated opinions of these regarding comfort? I知 not sure if everyone at the time had their latest kit (-41)
10-03-2022, 02:06 PM | #58 | |
3886
Rep 54,500
Drives: F80 M3
PM us if you have further questions. We can set you up with Swift springs at rates of your choice. We just need to know how your like the OE ride right now and tailor the spring rates to improve it. |
10-30-2022, 06:23 PM | #59 |
Rep 79
Bumping this up as I知 looking to install my ohlins in the next few weeks.
Does anyone have pictures of ride height with recommended settings (118mm) on the strut? Seems like if you want to adjust the front, you have to take the whole strut out to change settings so I知 hoping to do it on the first try or as little tries as possible. For those who did not measure the strut length, could you please provide pictures of threads? Thanks! |
10-30-2022, 11:16 PM | #60 | |
Rep 3,540
10-31-2022, 05:09 PM | #61 |
Rep 79
Yup that痴 what I知 looking to avoid if possible. Obviously getting the perfect ride height is hard on the first try but wanted to get a good idea of starting point.
