11-15-2019, 05:29 PM | #23 | |
Rep 3,540
16mm of spring movement is like 27mm at the wheel.
11-15-2019, 07:20 PM | #24 |
3885
Rep 54,499
Drives: F80 M3
Just enough preload to keep the sprig in place with an unloaded suspension is all you really need.
We haven't run into these issues you are having at our shop. Our last customer running 90 and 190 rates at 20+ clicks actually thinks it's still on the soft side. Large bumps didn't upset the car or sent its passengers off of their seats. |
11-15-2019, 08:35 PM | #25 |
Rep 570
Something isn't right. I have the M2 Ohlin set up as you do, and at 15 clicks, the ride borders on plush. I've had my ride height set and professionally corner balanced.
RickyBobby107.50 |
11-15-2019, 09:12 PM | #26 | ||
Rep 3,660
Drives: 981 Cayman GTS
Also, just to clarify, it doesn't push me out of my seat in every bump or dip. For the most part, it's just stiff with 18clicks in the rear. However, when there is a bit serious bump or a dip, the rear is literally super jumpy. I can even feel the difference between my front and rear going over speed bumps at very low speeds. The front just beautifully handles it even at speed but for the rear I almost have to come a complete stop otherwise it just skips over the bumps as if there is no suspension in the rear. Here's another example... After my last track day, I changed my rear to 16clicks (normally run 18-20clicks for the street) just to see the difference. Didn't even say a word to my wife about this change, after a 2-minute ride in the car, her first reaction was "What did you do to your car? It's super bumpy". Just for reference, she never said a single word about the ride quality on my M4 which had MS lowering springs paired with its adaptive suspension (it was a bad choice). Anyways... Looks like I need to make an appointment and get it checked by someone who is more experienced. |
03-23-2020, 09:09 PM | #27 |
Rep 2,700
Did you manage to find what was wrong with your setup?Just curious as I'm installing mine right now.
07-20-2020, 09:00 PM | #28 |
Rep 2,926
Drives: Cayman GT4, 135i
Bumping this thread - I am having the same problem. Had a reputable shop put the suspension in and even with 12 clicks all around the suspension is super bouncy all around. My wife gets thrown out of her seat on freeway joints and it is becoming a pain. On track the car is a dream. I have experimented with full soft / full stiff / in between to no avail. I even used softer springs than what Ohlins provided hoping there would be no harsh / bouncy ride.
I am thinking the preload is not correct but wanted to see if anyone else had gotten a resolution to this problem. Thanks!
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
07-21-2020, 01:28 AM | #29 | |
Rep 857
07-21-2020, 08:09 AM | #30 |
Rep 2,700
The problem is Ohlins have the dampers valves way too stiff in the rear. They probably did not revalve them from the first F80 kit that came with 230nm springs.
Unless you run on really smooth roads or are very tolerent to stiff riding cars there are good chances you won't like the ride. It's shame because for the price these are probably the best dampers out there, the way you can hit the curbs at the track is unreal. I just got my rears revalved by 3dm Motorsports and I'm running 70nm front/140nm rear springs and the ride is still not as smooth as I would like to. You have to consider we have some of the worst roads around here, on track it's perfect tough. Next step is replacing my front spherical bearing camber plates with a poly ''street'' model to reduce the harshness on cracks/joints etc. One important thing is your tires, I can confirm they will make almost a bigger difference than even a revalve, I ran Cup2, R888R and dws06 with this kit and the difference between the 3 tires is immense.
07-21-2020, 10:09 AM | #31 |
3885
Rep 54,499
Drives: F80 M3
A lot of our customers are okay with 90/190 for both street and track duty.
Everyone is different though. |
07-21-2020, 01:37 PM | #32 |
Rep 857
Well, it turns out the rear springs are the recommended 230nm for M3/4 and not the 190nm for M2 which we all seem to find too stiff anyway. I reduced preload a couple millimeters from max and will road test. I doubt it will make any difference so will likely be selling this and moving to M Performance unless replacement springs are reasonable. Can't seem to find them online... Any ideas what an acceptable spring rate would be? Also need to verify Vorshlag plates will work with M Perf.
07-21-2020, 02:46 PM | #33 | |
Rep 2,700
Like HP Auto said, we can't tell you if swapping to 190nm springs will be ok with you since it's such a personal and subjective thing. It can only ride better that's for sure. Part number is 48010-67 any dealer can probably order them or ask Ohlins usa directly Your Vorshlag plates will not work since the M perf suspension uses OEM style springs. The only plate Ive seen that seem to work with both OEM and 60mm springs is the Millway street. I plan on replacing my Vorshlag with these during off season to remove some nvh/harshness.
07-21-2020, 03:06 PM | #34 | |
3885
Rep 54,499
Drives: F80 M3
chris7197363.50 |
07-21-2020, 04:24 PM | #35 | ||
Rep 857
I totally understand how the higher rates would make it great on track when that track is smooth. However, when on roads, the rear has very little give. I'll report back after picking it up and driving a bit. What I don't understand is that the M3/M4 is not that much different in weight from M2C, so why the substantial difference in rates? Also, Ohlins recommendations for springs is the same for M2's from 2016-2020. 2019 and 2020 have same rear suspension but not from and some added engine weight. Suspension setup is some kind of black magic apparently. |
07-21-2020, 05:47 PM | #36 |
Rep 2,926
It's funny because I am running the 80/160 spring setup already (rather than the 90/180 spring setup).... I run RE71R or Cup2 on the track. Love the suspension on the track but on the street it is just jarring.
Current: M2CS
07-21-2020, 06:49 PM | #37 |
Rep 3,660
Exactly my experience (I was running 90/190). As an update to the thread that I started, I sold my car back in February but if I were to buy another F8X in the future, I will definitely stay away from Ohlins regardless of how amazing they are on the track. I'm still open to try their products on other brand/model of the cars but I learned my lesson on the F8x platform.
07-21-2020, 09:12 PM | #38 | |
3885
Rep 54,499
Drives: F80 M3
If you were ever on the E8x E9x forums, 80-90% people complain that the R&T rates were way too soft and upgraded to higher rate springs right away. Hard to make everyone happy. |
07-21-2020, 09:21 PM | #39 | |
3885
Rep 54,499
Drives: F80 M3
With that drastic difference in rates, you should consider revalving the dampers. |
07-21-2020, 09:58 PM | #40 | |
Rep 857
I only track once or twice a year. I am not especially good at it nor will I likely be going that infrequently. For me, especially during this COVID $hit, I just want to really enjoy each drive, hit the on/off ramps, and have better general control. Of course the occasional back road ride too. |
MR RIZK757.50 |
07-22-2020, 02:12 PM | #41 | |
3885
Rep 54,499
Drives: F80 M3
Got f1?682.50 |
07-24-2020, 05:16 PM | #42 |
Rep 857
Also posted this on the other Ohlins problem thread:
As an update, I picked my car up from TC Kline today. My only regret is that I didn't just buy his suspension setup from the beginning. He installed 400lb/in (70NM/mm) front and 700lb/in (123NM/MM) rear. Fronts are 7" (about 178mm) and rear are 10" (254mm). All 2.5" ID. They are customer made for TC Kline by Hyper Coils (www.hyperco.com). Original plan was 600LB rear and 300 front, but the ID wouldn't work on the Ohlins for the front. This set up is pretty close to his M4GTS. He resprung that lower than OEM. Interestingly, he did not have to reset ride height. This tells me the new springs are holding the car up and at least not too soft to cause it to sit lower. I have only driven about 20 miles since but it is significantly better. Straight-line stability is as good as OEM or better and overall ride is a bit more firm but not uncomfortably so. No more constant steering corrections due to rough pavement or bumps and rear is a bit more planted. Really nice guy and it is really valuable that when I call, he almost always answers. Especially since he is local to me. For reference, the Ohlins springs I had were 230NM/mm rear (1,311LB/in) and 200mm and front was 90NM/mm (513LB/in). This was the rear spring recommended for M3/4 vs 190 for M2. Not sure why this was on an M2 Kit... |
M2 GT67.00 |
07-24-2020, 07:21 PM | #43 |
Rep 88
I ran the original springs (90/190) for over a year and felt it was perfect for the street... not exactly compliant but never felt unsettled either. I upgraded to a stiffer setup and it feels perfect on the track, and still drivable on the street but quite a bit firmer than before. All subjective and everyone has different tolerance levels.
07-24-2020, 07:59 PM | #44 | |
Rep 7,318
