12-14-2022, 02:06 AM | #1 |
Rep 303
Battery drain 2018 OG
Anyone had problems with a Battery drain fault and had the battery checked and replaced 12-18m ago. Its now showing battery drain on the dash, I was just going to pop into the dealer but they want £150 just to look at it.... any ideas to check before blowing £150 in cash ? any views on battery life ?
12-14-2022, 05:54 AM | #3 | |
Rep 7,470
1) When you replaced the battery, did you have it recoded? Because as the battery gets older the car progressively charges it less and less in accordance to the progressively declining capacity of the battery. This is how the smart charging system works, however when you replace the battery you must recode the car otherwise the car will think that the battery is old and will not charge it to its peak capacity. Thus you will under charge the new battery and cause issues. 2) Do you have any accessories like dash cameras or anything like that plugged into the car? That could cause battery drain over time. Especially things plugged into the obd2 port or into the fuse box or battery directly, because these things may not turn off when the car is off. 3) Do you have any abilities to scan the car? There are cheap apps out there like bimmer link that allow you to have a very good diagnostic scanning, and the app is cheap so it really is a nice little tool to have for any bmw owner.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 12-14-2022 at 06:10 AM.. |
12-17-2022, 02:24 AM | #4 |
Rep 303
F87source, hi
Thanks, in answer : 1. A dealer fit so I will have a record somewhere, I think about 18m ago. Understand the battery point, sat next to the M2 is a GT3 that is used much less and has a smaller battery. 2. Nothing added like dash cam etc 3. Not heard of any scan accessories, any links would be great |
12-17-2022, 02:31 AM | #5 | |
Rep 7,470
1. If the dealer installed the battery it should have been coded correctly, so no worries there. 2. Interesting so there is nothing to potentially cause drain there. I don't have anything off the top of my head that would explain your situation, so you'll likely need to scan the car for codes. 3. https://www.bimmerlink.app/ This is the link, you will need a wireless obd2 adapter though (you can get something cheap like the vgate icar bluetooth adapters), but this will let you scan the car for any error codes. It is also useful for resetting service intervals and can add gauges to the car if you desire.
Carrera2RS204.00 |
12-18-2022, 06:27 AM | #6 |
Rep 1,591
How often are you seeing this and what is the exact message that comes up? I have seen it probably 3 times in the past few years and my battery is fine, noticed it when things got cold and car was only driven on short trips. For peace of mind I'd get a cord and app just to check. I'll admit the first time I saw it I was a little concerned but seemed to be situational fluke.
12-19-2022, 01:14 AM | #7 | |
Rep 303
Thanks, I drove it on another longer journey over the weekend (40 miles or so each way) and it didnt do it for the first time, so perhaps it is intermittent. I'll take a picture when it does it again. It spoke about discharge and restart and drive, but I did do another 70mile trip before and no change with these messages |
12-20-2022, 05:41 PM | #8 | |
Rep 15
12-20-2022, 08:11 PM | #9 | |
a coffee drinker
96
Rep 162
Carrera2RS204.00 |
