01-31-2018, 12:31 PM | #397 | |
Rep 133
01-31-2018, 01:45 PM | #398 | ||
Rep 1,608
http://www.2addicts.com/forums/showp...6&postcount=21
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 01-31-2018 at 02:13 PM.. |
02-01-2018, 12:21 AM | #399 | |
Rep 191
Someone previously mentioned wiggling the back panel free if you didn’t take the rubber seal off. This is what I did but unfortunately realized too late that all you had to do was pull up, in turn my two pins are a little bent out of shape but luckily still intact. The very last thing you want to do is pull the panel forward towards the front which would probably break the pins. Last edited by importriders; 02-01-2018 at 12:29 AM.. |
02-03-2018, 01:34 PM | #400 |
Rep 137
Does ASD operate even in comfort mode?
Hi all
I disabled ASD just now with bimmercode and only drove about half a mile. In sport, it seems quieter than the car used to be even in comfort mode... Does the ASD do something even in comfort mode? I think I'll probably be changing it back on as with stock exhaust its pretty quiet / boring now lol Hopefully someone can confirm if on a stock car, ASD does something or not in comfort mode? Or only sport and sport+? Hopefully the backup / restore in bimmercode works correctly as it should as I really don't think I'll like this mod lol Thanks! |
02-03-2018, 07:12 PM | #401 |
Rep 229
Installed the harness to remove asd, super easy. Makes car sound better imo with my fabspeed dp too. Can now hear the burbles and crackles
18 M2 lbb manual exec (Euro Delivery) and PDC
11 e92 335i xdrive BSM/PE (Sold) 09 335i xdrive Monaco Blue (Traded) 02 330xi (Sold) |
02-03-2018, 07:45 PM | #402 |
Rep 399
Drives: 2017 BMW M2 6MT
ASD is present in comfort mode as well, just not as loud as the sport or sport+ setting. I coded ASD off with bimmercode and never looked back, I do have the MPE though, love the natural sound. Should be able to restore it back with no problems, think all of the bugs people were reporting have been fixed a while back.
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold |
azibux142.00 |
02-04-2018, 02:10 AM | #403 | |
Rep 137
I had a longer drive today and I guess it isn't too bad with it turned off - shame you can't have a simple switch to turn it on and off lol I imagine it would be quite nice off with the MPE! |
02-11-2018, 08:43 AM | #404 |
Rep 2,856
Removed the ASD harness now that my car goes sale and the fake noise is back... It is horrendous. How could you live with this... I will remove it immediately on the M2 Competition.
MR |
02-21-2018, 03:04 PM | #406 |
Rep 1,608
I received the Technic ASD harness in November, and on this 70 degree Feb. day, I figured it was time to install it.. Finally.. What a PLUS! Easy install. Dissembling the trunk took about 12 minutes. Once I figured which was the correct harness orientation, installation was a snap, and with a test drive of about 15 minutes, total time was under 45 minutes from beginning to end.. Didnt have much trouble with the rear plastic panel as its pretty easy to slip it out from its rubber gasket surround, and putting it back was no more difficult than gently lifting the gasket lip, an inch at a time, and letting it slip back over the panel. I found some Windex helped slip it along. One tip Id concur with Importriders on that I found real helpful is that, when removing the plastic panel, youve got to lift it vertically up rather than trying to pull it away from the rear; there are two plastic pins oriented in a vertically down direction on the panel back and you dont want to bend or break those if you can help it. I cant think of any gotchas.... Great Harness, and definitely worth doing.. The car STILL sounded loud to me when accelerating and decelerating. What was quieter was idle and cruising and I found I could listen to the radio at about half the volume I had been listening at. Perfect!!
Thanks to all that chimed in!
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 02-21-2018 at 08:47 PM.. |
McGary911476.50 |
02-28-2018, 10:33 AM | #408 |
Rep 1,608
I specifically checked for that as I know early users of the harness experienced it. However I forget the exact date, but while the early harnesses went by BMW's incorrect wiring diagrams , the error was subsequently fixed and ones received after that were perfect. My bass is as strong as it was prior to installation. I believe they were changed in early '17 or just before.
Boostm3
03-01-2018, 06:04 AM | #409 |
Rep 426
Can somebody would be so kind to help me buy this ASD bypass harness?
Unfortunately Technic Pnp doesn't ship to my country (Hungary, EU) so i couldn't make a checkout with Paypal on their site. If there is somebody who would buy the harness for me and resend it to me i would be very grateful. Of course i will pay the additional costs. I used the recoding method former, but in that case there is an error message present in the system because of the incorrect coding configuration, so i would prefer the harness method. Please send me a PM if you volunteer. Thanks! |
03-04-2018, 01:27 PM | #410 | |
Rep 1,083
03-05-2018, 03:11 AM | #413 |
Public Last Class
97
Rep 244
Drives: 2018 M2 DCT LBB
On the website it now says this:
New harness design -no longer requires disassembly for installation. Full 100% PnP. Anyone know what they mean? You still have to tear apart your trunk, right? |
03-05-2018, 04:48 AM | #414 | |
Rep 923
03-05-2018, 04:54 AM | #415 |
Rep 923
So with the ASD deleted I noticed some small "bump" suspension noise coming from the back of my M2 when going slowly over small bumps in the road. You can only hear it when going over small bumps at a slow speed and it's really not that loud (but annoys me when my radio is off). The sound comes from the back of the car. My dealer could hear the noise (we test-drove together in my car), but could not find anything wrong at first sight and they are trying to arrange another M2 to test against...to see if it is normal. But this test M2 will have ASD enabled of course and will also be MY18 instead of MY17 (me car). My M2 is full OEM suspension and OEM PSS tyres.
03-07-2018, 07:54 PM | #416 |
Rep 7
03-07-2018, 11:27 PM | #417 |
Public Last Class
97
Rep 244
03-08-2018, 11:55 AM | #418 | |
Rep 4,551
Drives: 2015 328d xDrive
http://www.bimmerfest.com/forums/sho...d.php?t=884959 |
