09-29-2023, 08:39 AM | #1 |
Rep 27
Suspension or HP/Torque upgrade?
Now that I've driven my recently acquired OG M2 for over 500 miles I have come to the conclusion (subject to change ) that my money may be better spent on getting a suspension coilovers rather than on modifying to get more HP and Torque. I think the N55 produces enough HP and Torque as is. I bring this up since I don't want to put too much $$$ into this already awesome car. Thoughts please including recommendations on which brand. My use will be 90% street and 10% track. Thanks!
09-29-2023, 08:58 AM | #2 |
The Seeker
13863
Rep 3,325
M Performance Suspension, without question. Vastly better damping, and it makes the car feel much more planted in corners. Increased spring rate, of course, so there will be more up and down movement, but you won't mind much because it feels much better overall, and ALL the crash is gone. Buy a used, low-mileage street-only suspension and you'll be super happy. Absolutely the best bang for the buck.
Honorable mention goes to the Fabspeed Sport Cat. No tune needed, a bit more power, a bit more sound, more exhaust artifacts, and no CEL: complete win. |
09-29-2023, 09:27 AM | #3 | |
Rep 27
09-29-2023, 10:49 AM | #4 |
The Seeker
13863
Rep 3,325
Brilliant, but too much for a 90% street car. It's your money though .
I'd save that coin and put it towards throttle response, ie MST inlet and Turbosmart DV (and an aftermarket charge pipe if you don't have it). The stock pads suck as street pads, and suck as track pads, so that'd be another thing I'd consider changing (if you don't mind the extra work). You can pick up a set of Akebono pads for the street. These will give you 90% less dust, no noise, and offset the 10% extra wear you'll have on the track with track pads. Doing it this way will make your rotors nearly last forever. |
SDKIMLAW4.50 |
09-29-2023, 12:46 PM | #5 | |
Rep 27
///MPhatic13862.50 |
10-12-2023, 08:14 AM | #8 |
Rep 1,590
Suspension is one of the best upgrades on this car as is, let alone a used one that has a suspension that is likely already worn. Coilovers (M Performance, KW, Bilstein, Ohlins, etc) are all excellent options, but do a little research based on your goals for the car to find what matches your needs best.
10-12-2023, 11:02 AM | #9 |
4693
Rep 2,542
I feel like the best money on the F87 goes towards suspension and that really plays into the strength of the OG (weight & balance). Power though is always fun too - so really just depends on what puts the bigger smile on your face. Will say that adding power with the OG can be detrimental unless you start getting into upgraded cooling along with it. The OG suffers from heat management and increasing power can really amplify this - just something to consider. Light bump in power can be ok but will depend on the track characteristics, driver, pace, etc and just something to watch for if you do bump the power. There are "power" upgrades that will be helpful too on the track but those have already been mentioned so won't get into that also.
Suspension - I will throw our custom Nitron kits out there as well. Excellent performance and ride quality with a lot of happy dual usage customers on them. Pricing is very competitive and will put them up against any of those in both performance & ride - even at the same time (no tradeoff needed here). |
10-12-2023, 08:19 PM | #10 | |
The Seeker
13863
Rep 3,325
10-12-2023, 08:52 PM | #11 |
4693
Rep 2,542
Yeah if BMW hadn't gotten wonky on the rates and valving it would be a whole different discussion. I was pleasantly surprised today putting a G87 a bit through its paces on a fairly curvy and rough road and it felt improved over the F87 so hopefully BMW is getting back on the right track there. Still room for improvement but better.
10-12-2023, 09:35 PM | #12 |
Rep 6,939
Drives: 2018 M2 AW DCT
I may be in the minority but I have zero problems with the stock suspension and stock power. Been great on both the street and track.
10-15-2023, 07:17 PM | #13 | |
The Seeker
13863
Rep 3,325
10-21-2023, 09:22 PM | #14 |
Rep 1,389
Is add breathing mods to the stock tune, downpipe, intercooler, turbo inlet, charge pipe makes a fairly substantial difference to response and even sound with the stock tune.
I'd do suspension last tbh |
10-22-2023, 02:18 AM | #15 | |
16570
Rep 8,427
I’m on a stock tune and the car has been absolutely transformed with everything you listed above My brother Nick has a tuned F82 and he cannot walk me until after 70 mph…
