08-04-2019, 01:35 PM | #1 |
Rep 17
Hi all,does anyone know the location for the horns on an 2018 LCI M2 ? One of the dual tone horns has stopped working and it's quite embarrassing now sounding the horn as it sounds like a clowns horn and "camp" ! It is still under warranty but thought I'd take a look first to see if it's a quick fix - thanks in advance.
A.T.B - Leo |
08-04-2019, 03:53 PM | #2 |
Rep 867
Drives: OG M2
I had the same issue! Dealer replaced both horns for me in a day!
08-05-2019, 02:21 PM | #3 |
Rep 426
It's behind the bumper. Remove the front wheel arch cover then you will see.
https://www.newtis.info/tisv2/a/en/f...-horn/H3mrvBpn
08-05-2019, 04:34 PM | #4 | |
Rep 339
04-21-2021, 02:47 PM | #5 | |
16570
Rep 8,427
What fender liner is the two horns behind, left or right?
Tano374.50 |
04-21-2021, 03:21 PM | #7 |
16570
Rep 8,427
Okay thanks I will be doing reflector deletes so I will take a look while in there
04-21-2021, 05:37 PM | #10 | |
16570
Rep 8,427
I honked at them and I'm not sure who laughed first might've been them but I think it was me
04-25-2021, 10:58 AM | #11 |
Rep 426
Ok, here is a picture if anyone needs.
There is one on each side.
04-25-2021, 11:24 AM | #12 |
16570
Rep 8,427
Thanks brother ‼️
04-26-2021, 02:36 PM | #14 |
16570
Rep 8,427
Electronic is the kind used on the Alarm 💥
08-15-2021, 08:49 PM | #15 |
Rep 7
Glad I found this thread! I just bought a 2017 M2 and was wondering what the hell cartoon horn this car has. Apparently my low-pitch horn is out. I had no idea!
?I don?t know how many tenths that was. Too many.?
09-08-2021, 06:05 PM | #17 |
Rep 309
Drives: 2018 M2 LBB - 6MT
My 2018 is suffering from 1 intermittently (but more often than not) failing horn as well. For those who looked at their horns themselves, what was the actual issue? Did you replace your horn with a new one? Was it loose wiring? Mostly curious because mine seems to work sometimes, but more often than not it sounds like a clown car.
I could get the dealership to look at it, but rather not have them touch my car if it's not really needed. Thanks! |
09-08-2021, 06:07 PM | #18 | |
16570
Rep 8,427
I am like you its like going to the dentist Mine are both dead and I need to grit my teeth and go see them
gphung193.50 |
10-22-2023, 01:15 AM | #20 | |
16570
Rep 8,427
Go to your dealership and ask them if they will replace them as a known issue under Goodwill !? It’s reasonable to ask for Goodwill on something that breaks that normally should not break at all… Show them this thread, if need be If I had to do it myself, it wouldn’t be that bad just have to go in through the left wheel well liner to gain access
10-22-2023, 09:38 AM | #21 |
New BMW owner
325
Rep 843
Can we buy a hella and just replace it with those? I’ve never had a horn fail on me, this is kinda insane. If I replace it with another, may just repeat the issue again.
10-22-2023, 07:41 PM | #22 |
Rep 97
If it sounds like a clown car, what most likely happened is that your low-pitched horn died (the one on the driver side). The high-pitched one is probably fine, it just sounds funky because usually, you hear both at the same time.
