M2 Technical Topics > Suspension | Brakes | Chassis > Brake Fluid Flush
      06-01-2017, 12:15 AM   #1
MR_M2
Drives: 2017 M2 6MT, 2022 X7 M50i
BMW M2  [0.00]
BMW X7 M50i  [0.00]
Brake Fluid Flush
Hello!
---DIY alert ---
In the process of prepping my car for some track duty, I wanted to flush the stock brake fluid and replace it with Motul RBF 600. A couple of noob questions:
- How much brake fluid do I need to a do a full flush? I was planning to get 2 liters. Would that be an overkill?
- What's the color of stock brake fluid? This is to check if I have emptied the master cylinder and the new fluid is coming through.
      06-01-2017, 03:54 AM   #2
pmilani
pmilani's Avatar
Italy
44
Drives: M3 CS (LRG)
2018 BMW M3 CS  [10.00]
+1 on the question, I was just about to post asking how much as well, lol
      06-01-2017, 10:39 AM   #3
CosmosMpower
CosmosMpower's Avatar
2049
Drives: F87c, GT3, MK7 GTI
Two small bottles of RBF600 will do it. 1 liter total, get 3 if you want extras. Stock fluid should be clearish/amber same as Motul.
      06-01-2017, 02:27 PM   #4
MR_M2
BMW M2  [0.00]
BMW X7 M50i  [0.00]
Ah, not sure how to replace the fluid if they are the same color
      06-01-2017, 02:38 PM   #5
CommitConfirm
475
Drives: The Bus
Take a turkey baster and remove all the old fluid from the master cylinder. Fill master cylinder with new fluid.
Go to, typically, the brake furthest from the master cylinder and start pumping. I use an air powered one man bleed or you can get an assistant to help.
Keep going until the master cylinder is about half empty. It's not an exact science but will be a good start. Do the same for the others and see how you get on.
Drive it for like a 1000 miles or one track day and then flush it through again. Same process and you'll good after that.
As long as both fluids are the same viscosity i.e. DOT4 then is it does not matter if they mix. The race fluid has a higher boiling point so worst case you might find a little fad on your track day but it will be better than stock.i
      06-01-2017, 02:43 PM   #6
CommitConfirm
475
Drives: The Bus
If you really want to get all mathematical and 'do science' then you measure each of the brake line lengths and using the pipes internal diameter calculate the amount of fluid each line holds. Then pump that much through + 10%
      06-01-2017, 11:08 PM   #7
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Stock fluid is amber, Motul has an identical color. SRF is slightly more clear than stock
      06-04-2017, 01:16 PM   #8
HP Autosport
Drives: F80 M3
2 will usually do it, but get 3 so you have a buffer.
