11-27-2016, 02:32 AM | #45 |
Rep 150
12-08-2016, 07:20 AM | #47 | |
Rep 4,511
Is there a good "OEM 6 pots install onto F8x" DIY and if so please share it. Thanks BP
Current '22 X3M LCI.. |
12-15-2016, 02:06 PM | #48 |
BMW M2
497
Rep 322
12-16-2016, 01:59 PM | #50 |
Rep 756
Whatever about the CCB which are pretty OTT, I get that the OEM M4 brakes are a direct bolt on but if going to this amount of effort and expense, would it not be better to go with an aftermarket specialist such as Brembo? Whatever compromises BMW made with designing the M4 system are potentially compounded by putting that application on a different car.
I would think that a purpose-built system from the aftermarket would be better? |
12-28-2016, 08:51 AM | #51 |
Rep 476
06-08-2017, 06:28 AM | #52 |
Rep 44
Hey Imran@Evolve,
your conversion to CBB is very interesting. A friend of mine would like to do the same - but we are wondering how the brakes have to be coded in the car. Which coding did you do to the car? Did you change the brake booster / brake servo? Could you provide any further information despite the "hardware install" (Coding, changing values, etc.)? Would be great & very helpful! Cheers! |
06-16-2017, 10:09 AM | #53 | |
5365
Rep 3,789
I've been running the kit for 5k miles now with no issues and amazing braking performance. |
08-08-2017, 01:13 AM | #55 | |
Rep 44
So you just changed the brakes and the brake booster/servo and thats all? Any Problems with anti-lock braking System? |
08-08-2017, 04:29 AM | #56 |
5365
Rep 3,789
I have not yet.
Yes thats correct. 5k miles on this set up now. No issues. |
09-11-2017, 04:21 PM | #58 |
ALLDAY
55
Rep 220
was the swap from the steels to the CCB straightforward? Does it involve additional parts than just the M3/M4 CCB kit?
I'm looking to do this to my M2 so any info would be greatly appreciated
2017 X5M
07-16-2018, 09:35 AM | #59 |
Rep 4,511
Did you re-use existing M2 back plates to fit 6pot calipers and 400mm discs ?
09-17-2018, 08:51 AM | #60 |
Rep 478
I'm bumping this back up - Are there any other BMW models (aside from now the M2C) that use the same calipers? I.e. M5, M6, etc? It appears that the older M5, M6 and M3/4 all use the same 6 piston calipers. Am I wrong?
09-11-2020, 03:10 PM | #61 | |
Rep 526
CCB
Joe
Build by (PSI) 2019 M2C , BC suspension , BC wheels , DP , Vorsteiner trunk lip , Diffuser , Side Skirts , IND reflector kit , Rw carbón hood , DME Tuned !
E90 M3 Supercharged |
09-11-2020, 04:48 PM | #62 | |
844
Rep 1,962
Someone probably makes them though. |
11-17-2021, 12:53 PM | #63 |
Rep 3
I have changed mine with ceramics too
but i didn't buy the retrofit kit; i only change the calipers,pads,rotors and brakelines. i didn't buy the brake booster. is brake booster for ceramic brakes neccessary ? i use the stock one Last edited by firadiko; 11-17-2021 at 12:59 PM.. |
