10-09-2018, 07:36 AM | #1 |
Rep 1,466
Just ordered a Quickjack... from Costco
I've been tempted to get one of these for a while, and was hoping to find either an eBay sale code or some other sale to pick one up.
Costco Canada has had the BL-5000SLX for quite a while, and I'd heard that some warehouses in the US were carrying them for a while. Costco's US website didn't have any Quickjack models listed when I looked previously, but this morning I checked and it was there, for $1,099.99, which is a pretty hefty saving over list price. Link here: Do I need it, no. Is a nice to have for working on the car, and for detailing, YES!
2018 ///M2 LCI, LBB, 6MT...
10-09-2018, 08:18 AM | #2 |
Rep 1,017
I have one, and it's totally worth it. You got a great deal.
M3 Adjuster7909.00 |
10-09-2018, 01:29 PM | #4 |
Rep 3,540
Wow, that is a great price. Good find!
I recently had my hydraulic unit replaced under warranty. The relay in mine went bad (was tripping the breaker when I tried to lower the lift, going up was fine). The newer hydraulic units are a bit lighter since they changed the reservoir from metal to plastic. They still need to figure out how to not overtighten the plugs they put where you're supposed to install the QDs though. These things are always covered in ATF when you pull them out of the bag... |
10-09-2018, 05:26 PM | #5 |
Rep 1,608
LOVE your M3!!
Boostm3
10-09-2018, 07:32 PM | #6 |
24350
Rep 191,156
Congrats
10-09-2018, 10:24 PM | #8 |
Rep 1,466
Two orders in 12 hours... I should get commission!
10-09-2018, 10:26 PM | #9 |
Rep 1,466
Oh, and by the way... Those of you in CA, the delivery is super fast. The Costco website says that it's going to take 3 ~ 5 business days, but mine is coming tomorrow.
This is actually a problem for me, because I'm currently in Korea (for work and visiting wife's family), and won't be back until Sunday. I've been rushing around this morning contacting neighbours to see if they can move it into my house!
10-10-2018, 11:28 AM | #10 | |
Rep 423
10-16-2018, 09:43 PM | #11 |
Rep 1,466
So I returned home from my two week trip to Korea on Sunday afternoon, and assembled my QuickJacks in the middle of the night not being able to sleep because of jet lag!
Inspired by an image I'd seen on the QuickJack website, I mounted the frames to my garage wall last night; still battling jet-lag! I mounted the frames using 2 x 3 3/4" and 2 x 5" 3/8" wedge anchors. These are designed to bolt something to a wall, but can be used to just mount a stud to the wall, which is what I did. I mounted the studs about 1.5 inches into the wall, leaving 3.5 inches sticking out for the longer bolt, and 2.25 inches sticking out for the shorter one. I also used two slim 3/8" nuts and a washer on the end of each stud to stop the frames from potentially sliding off, and wrapped insulating tape around the threads to make a smooth surface for the frames to hang from. I'm pretty happy with the results:
10-23-2018, 12:33 AM | #12 |
Rep 1,466
A couple of updates:
10-23-2018, 10:02 AM | #13 |
Rep 2,505
Awesome! I wanted one to but I have a lifted Tacoma with 34" tires so I think the quick jack would barely start touching the frame at full extension.
I cant justify buying the quick jack just for my M2c. Next house I buy definitely getting a garage with 14' ceiling so I can have a proper two post lift.
10-23-2018, 01:52 PM | #14 | |
The deuce gets loose
290
Rep 499
12-05-2018, 08:59 PM | #17 |
Rep 3,402
12-05-2018, 09:47 PM | #18 |
Rep 1,430
12-05-2018, 09:56 PM | #19 |
Rep 2,560
Drives: Rapidly from A to B
It's on the lower of the two heights. Plus you can stack the rubber blocks to give yet another approximately 3 inches. I was putting my track pads on so didn't need extra height.
12-06-2018, 10:52 AM | #20 |
Rep 3,540
Are you able to stack both blocks and slide the lift under the car? I can't fit that with my 3-series. Then again, my hockey puck pad adapters might be why.
12-06-2018, 04:35 PM | #21 | |
Rep 3,402
I am sure the hockey puck adapters are not helping, having said that your probably getting 18" or so of clearance already so not likely a problem. |
CrashFL137.50 |
12-07-2018, 11:19 AM | #22 | |
Rep 3,540
