09-19-2023, 06:41 PM | #1 |
Rep 23
Air conditioner freeze up
All
My 2021 m2 has had the AC freeze up a couple of times. I brought it to the dealer. They told me they will only fix it if it freezes while at the dealer. That is obviously tough to do. Any ideas how to get the dealer to fix it? https://static.nhtsa.gov/odi/tsbs/20...47832-9999.pdf 353000 EQUIPMENT: ELECTRICAL RECORD_ID: 3318124 Bulletin Number: B640613 Replacement Service Bulletin Number: N/A NHTSA Item Number: 10205068 Date Posted: 11-01-2021 Component Name: 353000 EQUIPMENT: ELECTRICAL Make: BMW Model: M2 Year: 2021 Date Added: 12-20-2021 Summary: Customer may complain of reduced air flow when the air conditioning system is operated for an extended time, usually longer than 30 minutes. Last edited by ///mChris; 09-19-2023 at 10:28 PM.. |
09-20-2023, 11:40 AM | #3 |
Rep 23
The problem is more like the AC is working too well. The fact that it's able to freeze the condensation to the point that no air is able to pass through indicates the gas is likely fine. The fix that BMW published with the link above show they relocate the temperature sensor so that it can detect freezing.
My problem is that you need specific circumstances to reproduce. For me blasting through canyons in 105 degree weather seems to be the best way to experience the problem. Exactly what I bought the car for. |
09-20-2023, 01:01 PM | #4 |
Rep 23
From the f30 forums and the TSB linked in my first post, I see they fit a temperature sensor spacer and flash a lower temp to the AC. It's a $1.50 part and 15 minutes of work. Does anyone know if the same part will work on a f87 that works on f30 and f80?
09-20-2023, 04:14 PM | #5 |
Rep 1,356
The problem is the gas, but if you have a lot of free time and you like to waste it, go ahead and mount sensors, spacers and more things.
I dealt with this problem for almost 3 years, the problem was 250g. of gas, when it should have 560g. |
