04-25-2018, 08:03 PM | #1 |
Rep 8
Loss of power into 4th gear
Looking for advice. Ran my M2 at Laguna Seca yesterday and noticed coming down start finish straight going from 3rd to 4th gear, there seemed to be a significant power loss. I was running it very hard.
Perhaps a heat soak issue? time for an FMIC? Anyone else experience this, thoughts, solutions. Last edited by tjmark; 04-25-2018 at 08:22 PM.. |
04-25-2018, 08:18 PM | #2 |
Rep 3,659
Drives: 981 Cayman GTS
Were you running low on the gas? It happened to me at Laguna as well in my M4 and I was running very low on the gas. Another friend of mine had the same isssue when his tank was almost empty. Since then I always make sure I have at least half a tank before a session.
04-25-2018, 08:20 PM | #3 | |
Rep 8
zenohua112.00 |
04-25-2018, 08:28 PM | #4 | |
Rep 4,551
Drives: 2015 328d xDrive
It makes me think it was either traction control interference (if it was on) or a delay between shifts which can sometimes occur if you have a 6MT and upshift aggressively. |
NYC Bimmer259.50 |
04-25-2018, 08:48 PM | #5 | |
Rep 8
Any way to get rid of the delay with quick upshifts? |
04-25-2018, 09:07 PM | #6 | |
Rep 4,551
As for the shift delay there is no known solution to that as far as I know. I've read conflicting accounts that say If you're WOT and shift over 5k it shouldn't happen but some people say it still does. I personally think it occurs when you let the clutch out too quickly but I can't prove that, it's just a hunch. Code in Euro MDM and try to shift closer to redline and see if that helps. |
NYC Bimmer259.50 |
04-26-2018, 12:32 PM | #7 | |
Rep 8
Awesome info. Glad to know at least its normal. I'm not experienced a coding. I do have Bimmercode and have coded a few of their standard codings. Is there a way to do this though bimmercode not in advanced mode? |
04-26-2018, 01:20 PM | #8 | ||
Rep 4,551
If you're unfamiliar with ESYS you can have a coder do it for you for a nominal fee. It makes a huge difference and I think it's a must have for anyone who tracks their M.
NYC Bimmer259.50 M3 Adjuster7909.00 |
04-26-2018, 05:07 PM | #9 | |
Rep 8
Thanks so much. |
04-26-2018, 06:01 PM | #10 |
Rep 1,459
Even in Sport Plus, don't you have to hold down the traction control button to fully disable? If this didn't happen, that's likely your culprit.
04-26-2018, 06:28 PM | #11 |
Rep 8
04-26-2018, 07:26 PM | #12 |
Rep 1,459
Not the sport plus button - the traction control button. Good luck.
04-26-2018, 07:42 PM | #13 | |
Rep 4,551
https://f87.bimmerpost.com/forums/sh....php?t=1385679 This is why I suggested coding in EuroMDM. It will lessen TC interference while still keeping you in Sport+. Best of both worlds. |
NYC Bimmer259.50 |
04-27-2018, 03:52 AM | #14 | |
Rep 124
04-27-2018, 07:24 PM | #15 |
Rep 207
Mine does the same thing when I tried to induce a bigger power slide than the traction control permits. It basically ignored my throttle input and did its own thing to get the car going straight. Slightly annoying but sounds like Euro MDM is the proper solution.
Btw, my car has DCT and I kept the car in same gear as I exited a turn. I mention that just to rule out tranny/shifting has anything to do with it.
Gone but not forgotten:
'14 Corvette Stingray (2014-2017) '05 Boxster S (2005 - 2014) '00 S2000 (2000-2005) |
04-27-2018, 10:28 PM | #16 |
Rep 753
Sounds like DSC cutting throttle; if the shift was right under the bridge or a touch after, you likely just shifted weight to front, lightened rear that likely picked up some slip angle and then when you went WOT you had a mild traction loss so DSC cut throttle. It’s so mild and quick that it feels like throttle lag. Because it’s kinda sorta is.
04-28-2018, 10:33 AM | #17 | |||
7909
Rep 11,785
AndrewC198910932.50 |
04-29-2018, 05:31 PM | #18 | ||||
Rep 599
Drives: M2, C63s, 718 Cayman GT4
2018 MG M2 - Ohlins R
05-08-2018, 12:50 AM | #19 | |||||
7909
Rep 11,785
On the street, that reduction in additional margin of error for a driver that has lost control, means hitting a median or a curb, or worse. If you want to Hoon around on the street then the stock MDM will save you in that environment. Or just BE A MAN and go full DSC OFF. The primary reason that Euro MDM helps for a track driven car is that it allows for the additional G forces and yaw created by R tires and track pads. Before even going on track with R tires one can activate DSC making a turn in the paddock. Seriously. Regular MDM is better but not by much. Imagine E36 M3 DSC.. If one is on track and in a high speed corner, Euro MDM allows the car to slide , and also, if one needs to add power in the case or realizing that one has turned in too early in order to not end up going off track.. adding power is needed instead of lifting off the throttle. With regular MDM, the DSC light will be blinking and you will not be able to add power and the rear brakes will likely be working to keep the car from spinning as it cuts power. It's certainly disconcerting and also frustrating to not be able to add power when you know you have the skill to make an adjustment that will get you through the corner faster as well as help to avoid going off track at the track out. |
09-18-2020, 02:09 PM | #20 |
Rep 212
Drives: BMW F87 M2C
Reviving an older thread here...but I had something similar on my car the other day.
Sport plus....full throttle shift from 2nd-3rd....and boom completely killed the power, made me shoot forward in the seat as I was obviously not expecting it. Let off the gas, then re-applied and it was fine. No lights on the dash etc. This is a UK DCT car also. Any idea what would cause this? It's happened a couple of times now but only ever in sport plus never in sport or comfort. |
09-25-2020, 06:51 PM | #21 |
Rep 110
Just test drove a used M2 to make sure I really like it before putting deposit down later and on the highway, I think this happened at around 5k rpm twice. The car has 24k miles and crap Advanta all season tires🙃 I don't know if the cars f"""" ed up or if the tires couldn't handle the juice & the car cut power.
