M2 Technical Topics > Track / Autocross / Dragstrip > BMW M2 sets Laguna Seca lap time of 1:40.88 at hands of BMW DTM driver Martin Tomczyk
      03-22-2016, 10:39 AM   #67
Laertes
Drives: Gray
For what it's worth, I have a full data acquisition system in my track car (Racekeeper) w/ 10hz GPS. Before I had this, I used the Harry's Lap Timer app on my iPhone, using the built in GPS. Just for the heck of it, I tried them both at the same time last year, and it was pretty amazing how accurate the iPhone based lap timer was. It was within 0.1 sec (and sometimes less) on ALL laps. I have to assume from this that the app, though only sampling position at 1 hz, extrapolates from that what point in time you crossed the start/finish line. It doesn't just wait until the first position fix after you cross the line and call it good, it figures out how far past the start finish you are at that fix and then uses your velocity to figure out what the time was when you went past the line. Clever.
I'm less skeptical about the lap time based on the timing device than I am about the fact that there was a passenger. At a short track like Laguna Seca the effect is less than at someplace like VIR, but I'd still bet it's a second/lap difference or so. Laguna Seca is a HP/Braking track, and both are very affected by weight in the car.
Originally Posted by Robin_NL View Post
Then 1:38.88 sounds fine with me.
About the laptimer: Why should BMW and Porsche use that stuff then if it's far off? Please explain...
Cheers
Robin
      03-22-2016, 10:52 AM   #68
dmboone25
dmboone25's Avatar
4972
2007 E92 328i  [10.00]
2007 328i  [10.00]
Originally Posted by M3 Adjuster View Post
That was always expected.
m2 will be likely match to the Cayman S or GTS
981 CS = 981 Cayman S.
The GTS is going to give it a good battle - the S might be a little down on power - it will be interesting to see.
      03-22-2016, 11:37 AM   #69
bradleyland
TIM YOYO
Drives: 2013 M3
Originally Posted by oj34 View Post
I wouldn’t expect Randy Probst going faster than Marting Tomczyk (of course same conditions and correct timing assumed).
Tomczyk is an great driver, to be sure, but Randy Pobst (there's no "r" in his last name) has a huge number of production, street-car laps under his belt at Laguna Seca. Race car drivers rarely get the kind of practice that Randy has had at a single track. MT has published some statistics on Randy's speed and consistency at that track, and it's just off the charts. He also holds more records than anyone at Laguna Seca. Much of this can be attributed to the fact that he gets so much seat time there. If anyone can beat Tomczyk's time, it's Pobst.
So, I'll take that wager. I think Pobst will put up a time that beats Tomczyk's. It may only be by a tenth, but I think he'll beat it.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      03-22-2016, 12:21 PM   #70
NISFAN
NISFAN's Avatar
3492
Cheers
Robin
Agreed, I've done track days using the tracks own lap timer modules together with using the M Laptimer app and the results are way less than a tenth out. For example my fastest lap on my local circuit was a 1:30.999 according to the circuits timer and 1:30.97 according to MLaptimer. In fact my AIM data logger using a higher GPS sampling rate was less accurate against the two above. I wouldn't doubt M lap figures.
      03-22-2016, 02:06 PM   #71
oj34
Drives: E82 135i
Sorry for the "r". Probst is a common name in Germany and so I typed it almost automatically.
Wager taken I'm drinking beer
However, comparing times will be difficult (passanger yes/no, conditions, timing equipment, ...)
      03-22-2016, 04:55 PM   #72
bradleyland
TIM YOYO
Drives: 2013 M3
I thought it was Probst for the longest time
Good point on the passenger. I keep forgetting that. I'll give you a two beer handicap haha
      03-23-2016, 02:24 AM   #73
oj34
Drives: E82 135i
I'm fine with that
