05-21-2019, 08:06 AM | #46 |
Rep 82
DS2500 on M2 rear
Is it normal that the DS2500 pads are couple of mm smaller in size than the OEM and cause the pad to jiggle in the caliper? I think it is missing the metal plate that covers the OEM ones.
Did I get the wrong ones? |
05-21-2019, 10:59 AM | #47 |
3888
Rep 54,572
Drives: F80 M3
Yes, it is completely normal. Each manufacturer has their own tolerances and some could be an mm or so off. Sometimes if you transfer the sound deadening plates over from your OEM pads the rattle can be reduced.
01-19-2022, 11:20 AM | #49 |
3888
Rep 54,572
Drives: F80 M3
R4S is a performance street pad. DS2500 is a hybrid street/track pad. You will have a lot more bite with the DS2500 on and off of the track. Just keep in mind that DS2500 is not a full track pad so you still can't push it too hard on the track.
01-19-2022, 11:25 AM | #50 | |
Rep 3,729
R4S simply didn't hold up for aggressive street use.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
01-25-2022, 11:16 PM | #51 |
3888
Rep 54,572
Drives: F80 M3
hellokitty2899.50 |
