06-04-2023, 02:38 PM | #1 |
The Seeker
14201
Rep 3,427
Carbon Ceramic Brake CCB package retrofit.
Hey guys, just wanted to add a few notes about this process. There is a big thread about it over on the M3/M4 forum, but I felt like it was missing quite a bit of install info, so this thread is just some notes for those that might do this retrofit in the future.
Link to the M3/M4 forum thread: https://f80.bimmerpost.com/forums/sh....php?t=1135210 I read several comments that this wasn't such a hard swap, but I found it pretty rough. It seemed that there was just difficulty at every turn, and a friend and I did it in my air-conditioned basement, so pretty great conditions. Not sure what it'd cost to have a proper shop do it, but it's to be considered for sure. This was my order of operations: - unhook the battery - remove ABS module - remove the bolts and pin from the brake booster (under the dash) - remove the master cylinder - remove the brake booster Some notes: 1. The little clip that holds the brake pedal pin in is a bit weird, so I've shown it here with how your screwdriver needs to go in and push up, then the clip just slides off easily once that part is lifted. 2. The little rubber caps I used for the brake lines. You'll need 6 of them, then a larger one for the side of the reservoir. I'll add the sizes I used later. 3. The wiring harness on the side of the ABS unit isn't intuitive at all. The top portion slides up pretty far (but doesn't come out), then the harness can be removed. 4. The ABS unit itself sits on 2 metal prongs at the bottom, so it feels like it's attached, but it's actually just the rubber grommets on the bottom of the unit holding onto those prongs. You just have to wiggle it up until it comes off. 5. The hose on the brake booster comes off best with a metal fork (trim) tool. After doing a traditional bleed the pedal was super soft at the top, but got firmer as I drove the car. After a few miles I had a soft pedal at the top, but the brakes felt fine otherwise. I did get 3 errors, but I believe all 3 are because the car requires coding for the retrofit. We will see on Wednesday when I get the coding. I plan to do a DSC/ABS bleed next, then a traditional bleed afterwards to finish the job. I'm sure I've forgotten something, but this thread is really just for future reference anyway. Shout out to the super cool guy that sold me the kit and helped me figure a lot of this stuff out. sleeper1g, bro, you're a legend. |
06-04-2023, 02:39 PM | #2 |
The Seeker
14201
Rep 3,427
A few more pix.
4
06-04-2023, 02:51 PM | #3 |
Rep 1,405
No coding is needed for the upgrade, no error should appear, you must have some error of the abs module.
To purge you need an automatic purger, with the traditional method you will never bleed. |
///MPhatic14200.50 |
06-04-2023, 03:35 PM | #4 | |
The Seeker
14201
Rep 3,427
Also, I plant to do the ABS/DSC ISTA-guided procedure. |
06-04-2023, 04:49 PM | #5 |
Rep 1,405
I mean you don't need coding to make the dashboard errors disappear.
06-04-2023, 04:58 PM | #6 |
The Seeker
14201
Rep 3,427
06-04-2023, 05:16 PM | #7 |
Rep 1,405
06-04-2023, 05:42 PM | #8 |
The Seeker
14201
Rep 3,427
06-04-2023, 07:57 PM | #10 |
The Seeker
14201
Rep 3,427
06-06-2023, 08:50 AM | #11 |
The Seeker
14201
Rep 3,427
I have a friend with ISTA coming over soon to read/close the codes, but I'm wondering if this can be done with Bimmercode, since I have that.
I'm also wondering if they might be related to the fact that I accidentally closed the trunk after I disconnected the battery and had to hook a different battery up to the car for a second in order to get the trunk open, but I'm doubting it. I've read that the pedestrian and frontal collision codes come from a myriad of areas, including dirty windshields, rain, speed sensors etc, but since they happened at the same time I did the booster swap I'm thinking they are related. And I have the brake service requested code as well. |
06-06-2023, 01:42 PM | #12 | |
Rep 1,405
If so, could the errors come from there. I don't know how bimmercode works, if it has the function to read errors you can try. |
06-06-2023, 02:15 PM | #13 | |
The Seeker
14201
Rep 3,427
I'll have a poke around Bimmercode. Apparently these codes can be seen and cleared by many programs/devices, even ProTool. |
06-06-2023, 05:32 PM | #14 |
Rep 350
BimmerLink can usually read the codes, it's from the same people as BimmerCode. I think BimmerCode is somewhat equivalent to E-Sys while BimmerLink is more ISTA-like (although neither are as powerful).
06-06-2023, 05:43 PM | #15 | |
The Seeker
14201
Rep 3,427
I'll get this lined out this week and hopefully be able to tell what I did wrong to cause these error codes and keep other people from making the same mistake. I thought I had all the bases covered, but stuff happens. |
M3SQRD2484.50 |
06-06-2023, 11:03 PM | #16 | |
The Seeker
14201
Rep 3,427
Unfortunately, after 4 miles the 3 errors came back. I'll have the cleared tomorrow, hopefully never to return. I've also developed a high pitched intermittent squeal only when turning left. Good lord these brakes. |
06-07-2023, 01:48 AM | #17 | |
Rep 1,405
When you bleed, did you open the 2 bleeders on each caliper from the inside out? Last edited by Track/S; 06-07-2023 at 02:09 AM.. |
06-07-2023, 02:01 AM | #18 |
Rep 1,078
I hope to do this conversion one day too, but sounds like quite the hassle!
06-07-2023, 06:26 AM | #19 | |
The Seeker
14201
Rep 3,427
Some have had less issues, not sure why I’ve had more, we were super detailed with the work. |
06-07-2023, 08:33 AM | #20 |
Rep 1,405
06-07-2023, 09:47 AM | #22 | ||
The Seeker
14201
Rep 3,427
I plan to do the ista ABS/DSC soon, so I'm sure that'll fix it. Quote:
The booster is required. The coding is required. The ista ABS/DSC bleed is required (even if you have a firm pedal). Doing it any other way will cause some sort of compromise/issue. The reason for the weaker booster is because the carbon core of the CCB rotor is much weaker than the iron rotor and use of the standard booster and emergency stop code will damage the rotor over time, especially if it's being used on track because the carbon core will degrade over time with heat. Last edited by ///MPhatic; 06-07-2023 at 10:34 AM.. |
