03-06-2020, 09:53 PM | #45 | |
Rep 309
Drives: 2018 M2 LBB - 6MT
But yeah the AD08R have a wider contact patch than most tires rated at the same width, plus their sidewalls are stiff/blocky. With a 40 series tire and a similar overall diameter as the OEM 19s, I'm not surprised about the weight difference (or lack thereof). |
03-07-2020, 03:40 AM | #46 |
Rep 89
[QUOTE=gphung;25895403]Sorry for going off topic. Would you mind posting some photos of your setup once the tires/wheels are mounted? I was seriously considering this exact same setup.
sure I will! I hope I will be able to mount them next week Last edited by H20neun; 03-09-2020 at 03:44 AM.. |
03-13-2020, 03:16 PM | #47 | |
Rep 89
in my opinion the fitment with the fender is almost perfect now it only needs some proper suspension to get a little lower but the tires came out quite nice! I really like the higher sidewalls |
03-13-2020, 03:25 PM | #48 |
Rep 89
maybe it is also worth to mention that the tires are the ad08rs which is the successor of the ad08r but I think there is not a big difference between them ;D
and I also got the total weight of the wheels: F: 21,6kg (47,6lbs) R: 23,2kg (51,1lbs) after weighing the stocks I can compare the weigh but I guess the 18" with the yokohamas are a little bit more heavy! Last edited by H20neun; 03-13-2020 at 03:35 PM.. |
03-13-2020, 05:35 PM | #49 | |
Rep 744
I still need to drive them in anger on a dry track though. I weighed a set of OEM spec 513M and 437M (19") and with OEM tires the weight was within 200 grams or so.
03-13-2020, 08:29 PM | #50 | ||
Rep 309
Here in Canada, apparently it's getting more and more difficult to source a set of AD08R. I feel they may getting discontinued soon due to their age, and Advan also showcases a new concept tire at Toyko Auto Salon on the Yokohama Supra. If so, I really hope they retain a lot of their current daily-able traits; it's why I feel this is such a great tire. A great one for the track, and still controllable on the street in wet conditions. Thanks again for the photos! |
03-14-2020, 02:44 AM | #51 | ||
Rep 4,521
What profile are the front tyres ?
Current '22 X3M LCI.. |
03-14-2020, 12:49 PM | #52 | |
Rep 744
265/35/18 and 285/35/18, the dia is 1 cm less than stock but reduced by the same amount front to rear (ie it does not muck up the rake). Fronts are close to the strut but I can still get my fingers inbetween. The NS2R is much squarer than the stock star PSS (even the wider M3/4 one) Off the top of my head the star spec PSSs are 20mm narrower at the tread than the indicated value, ie a 255 is acctually 235mm wide at the tread. The NS2R is 10mm less at the tread but very square (its like the tread has just been given a 5mm radius). They sit pretty much flush with the plane of the arches. If you want pics I might take some tomorrow when it light out again.
03-14-2020, 01:19 PM | #53 |
Rep 4,521
Yes please - thank you for offering to post some photos.
03-16-2020, 04:49 AM | #54 |
Rep 744
More here https://drive.google.com/open?id=1gp...Xl2WFUM_sy9Z6u EDIT: not sure why the pics are not poping up, dont have the time at the mo to sort it out. So pls check the google drive
03-16-2020, 02:35 PM | #55 |
Rep 89
update on weights:
today I put the m437 19" with oem tires on the scale: on the front I went up from 21,2 kg to 21,6kg (+0,4kg) with the m513 and ad08rs in 245/40R18 per wheel on the rear I went up from 22,6 kg to 23,2kg (+0,6kg) with the m513 and ad08rs in 265/40R18 per wheel tbh when I decided to go for the m513 I expected to save a little bit of weight not only because the rims are lighter but there are a lot of threads which are about light 18" wheels.. but nevertheless the ride quality (bumps feel more soft) with the m513 got better and they actually feel more precise in turn in but probably because of the tire having more grip |
gphung193.50 Robimplicit15.00 |
03-16-2020, 10:28 PM | #56 | |
Rep 753
03-17-2020, 04:05 AM | #57 |
Rep 1,093
Good option for Canadians - https://odparts.ca/720-form-gtf2-18x...-p-105671.html
Very light, durable, and in my opinion better looking than Apex (and half price). 18x9 ET30 is pretty much factory fit but you can push them out 10 more millimeters with spacers. The downside is the 9 inch width so they are better suited for narrower winter tires. |
04-01-2020, 08:40 AM | #58 | ||
Rep 309
I'm thinking of going Hankook RS4 in either the same 265/285 on a 9/10 wheel, but Tire Rack is showing that they have an even wider contact patch than your NS-2Rs. Backup would be 245/40 and 265/40 RS4s. |
04-01-2020, 10:29 AM | #59 |
Rep 1,263
2 months ago I was going to mount BFG R1's in either 275/35 or 285/30 on my square setup.
That all changed... My thought process is to have one tire I can Solo 2 on and use at the track. I got a set of the APEX EC-7's 18x10 33 offset thru the group buy with 12mm spacers and lugs. The hottest 200 wear street tire is now the new Yoko A052. I mounted 265/35 on the front and 295/35 on the rears. Fit perfect. Now have to wait till this damn Virus runs it course before any events here in the Northeast get green lighted.
PLF693767.50 |
04-01-2020, 11:10 AM | #60 | |
Rep 744
Check what Hankook says about the RS4 and wheel width. They are not available in the EU so I have not researched them. I only got to do one very wet track day on a brand new track on these tires before the COVID shutdowns so not really able to push them. They felt great in the rain and when new carried away a lot of water. I drove hard on some country roads last weekend and the steering felt the same as always but they were not up to temp or anything. I got one floaty moment from the front but that was more trailbraking into a corner at way too high a speed. So far they feel as sharp as stock and give great grip without sacrificing too much wear or road noise. I also ran the same tires on my previous car, also a bit too wide, and I did not notice anything vis a vis the steering. I think the much harder sidewalls compensate for the slight pinch.
gphung193.50 |
05-02-2020, 06:35 AM | #61 |
Rep 85
Had a trail fit of some 18s I've still got in the garage with some racing wets on - 18x10 et25
Untitled by M2 ClubSport, on Flickr Had to remove the caliper as these 18s no way near clear the caliper Untitled by M2 ClubSport, on Flickr Obviously this is a no go. Wanted to run 10s & 11s but think I will have to settle for 9.5 & 10.5, which is still half inch wider than stock. Will be able tell more once I get a geo to my desired spec then ill have another trail fit. Untitled by M2 ClubSport, on Flickr |
05-02-2020, 11:16 AM | #62 | |
Rep 309
Thanks for the photo of a stock 19 in rear and 18 in front from a straight on side view. It really gives the correct perspective and visual comparison between 18s and 19s on this car. The 18s IMO look really good. What size are these R compounds you have installed? I guess I'd also need to figure out how to read those numbers too. |
05-06-2020, 09:20 PM | #63 |
Dom
1080
Rep 1,718
I will be running 18" BBS E88 on my 2020 M2C once the shipment arrives from overseas. Taking the proper steps by removing the massive brakes in favor of AP Essex to accommodate my favorite wheel. I'll start a thread at some point to help document it. If interested, follow my IG or click the icon. I'll be posting pics and updates until the thread is created.
mcvaughan704.00 |
05-10-2020, 12:03 PM | #64 | |
Rep 650
05-10-2020, 12:08 PM | #65 | |
Rep 650
05-10-2020, 11:30 PM | #66 | |
Rep 1,263
