BMW M2 Forum > BMW M2 Discussions > 😡 I lost against a ‘16 Camaro SS 1LE
      04-13-2020, 04:37 PM   #23
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.00]
Originally Posted by Moflow View Post
OH OH I KNOW THIS ONE!!!
You change lanes without the crippling fear that something marginally smaller than a six story building is hiding in your blind spot!
Since this is a BMW, you don't touch your turn signal, don't ever forget.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed
5.M0NSTER3353.50
      04-13-2020, 07:16 PM   #24
GiacomoH
Originally Posted by 5.M0NSTER View Post
Lots of good point, but I have to correct the last statement.
Camaro is 5s faster around VIR than M2C, and 7s faster than OG M2. Not sure why people think it's the other way around.
Have to give respect where it is due.
Tires
      04-13-2020, 09:02 PM   #25
TemjinX2
Drives: 2008 335xi e92
Originally Posted by Mkinzie View Post
I didn't buy it for that. Just fun car. I've put less that 5k miles on it in 15 months of owning.
Idk hp. Only guessing with mods & tune.
Going by what bm3 claims. I think is what. 450 ish
He has no tune.
Like said. First time I've ever raced my car & did. Just cause roads are dead right now
Correction. His is a 2015. So little less hp.
chevy underrates there ls engines to keep insurance rates down....most ls motors dyno to the whp what chevy states as crank...
also the bm3 numbers are crank numbers
Current Ride=2008 BMW 335xi
2017 BMW M240 Xdrive
2017 BMW M2 N55 6spd
2018 Infiniti Q60 Redsport AWD
2008 BMW 335ix
      04-13-2020, 10:17 PM   #26
Detroit M
Drives: bmw m2
Originally Posted by GiacomoH View Post
Tires
The M2 driver went into quite a few turns badly and didn’t seem to be pushing the car to the limit... I heard tires squealing in many of the 1le turns, where as I heard almost none in the M2 turns and on skinnier tires! M2 driver could probably spend a weekend at the track and get 10,000 miles out of some PSS driving like that. 1-day at the Concourse and I nuked an almost new set of PSS by comparison squealing on many turns.
I’ve driven both and the M2 feels like a go-cart by comparison.
Just my $0.02
      04-13-2020, 11:04 PM   #27
Mkinzie
Drives: 2016 M2, 18 wrangler 7 seater
Well I been looking at turbos all day. Lol
& now In damn emergency vet clinic.
So turbos have to wait. Lol.
Guess it’s a sign. I don’t need
      04-14-2020, 04:25 AM   #28
nearwater4me
Drives: '22 G82 Base
My previous car was a Camaro SS.
From the driver’s seat, the Camaro feels faster than my M2C.
The instant torque down low is quite addicting with the pushrod V8. The sound is a huge plus also.
But the difference in feel of the rest of the car is night and day.
I’m very happy with the switch.
MikeD943.00
      04-14-2020, 06:06 AM   #29
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
The M2 takes off the line immediately and aggressively, with a lot of audible and tactile fanfare but it blows its load quickly and loses all of it's steam, at higher speeds and RPMs.
Blame this on the limitations of the N55, which it's single turbo setup and insufficient HPFP potential. The N55 initially was never really designed for brunt, continuous powered applications. This is why the S55 in the M2C is so appealing; same great package, with a engine that has more potential headroom.
Remember, the M2's N55 shares the same motor as your hypothetical aunt or uncle's '35i, that they uses to go to work and pick up the kids from school with. It was never an engine that was constructed in mind, for straitline, heavy-duty street racing but more so, a powerplant with a thicker torque curve, for those that wanted something above the typical 4 cylinder offerings, with a smoother operation, since 6 cylinders need not work as hard as is boosted as heavily as a 4, to produce the same output.
A typical stock N55 in a '35i, the boost pressure is at 7 PSI, its practically running at naturally-aspirated power, with the turbo charge as supplement, when needed.
The N55 in M2 on the other hand, stock, is already pushing 15 PSI, double that of a standard N55 application, as it's heavily dependent on its single turbo, the same way BMW's 4 cylinder offering is juiced up (22 PSI), to achieve its lofty power goal.
The only thing that really mechanically separates the M2 from a run-of-the-mill '35i vehicle is it's slick electronic M LSD, pistons from the S55 and oil distribution system, with better oil pan baffles, so it doesn't starve for oil, at high G maneuvers.
The M2 being blessed with a proper limited slip differential, which puts down power so well, allows BMW to crank up the power, all the way up to the limitations of the N55. It's a car that some might say has more handling than power.
BMW tried to make up for the N55's lack of top-end potential, by heavily juicing the motor, even adding a temporary "overboost" function, which spiked the boost pressure, for a brief period, which added some pep, without overwhelming the limitations of the motor.
However, there is only so much that they could of accomplished, when the overall hardware remains the same, which is the root of the motor's inherent shortcomings.
TL : DR: You got yourself the wrong car if your goal is to race big block motors, from light to light..
Dinan's take on N55's motor in the M2:
      04-14-2020, 10:33 AM   #30
TemjinX2
if you want big power just get a bigboost turbo kit and a upgraded hpfp...there lot of n55 guys doing 600whp+ with it
2008 BMW 335ix
      04-14-2020, 11:17 AM   #31
akkando
akkando's Avatar
5865
Camaro SS 1le is the best performance bargain you can buy.
https://www.caranddriver.com/reviews...e-test-review/
      04-14-2020, 11:44 AM   #32
Kemps2Fast
Kemps2Fast's Avatar
Drives: M240i 18 - M240ix 20 - M3C 22
jessetaylor1 You're a damn clown... Go back to the Honda Forum. #vroomvroom #brokenjerseyroads
      04-15-2020, 08:18 AM   #33
LuvMyE92
Occasionally frequent poster
LuvMyE92's Avatar
3000
Drives: CT5V-Blackwing
I've decided in the interest of not degrading the thread any further, I will limit my comment to the following:
I would expect that a stock Camaro V8 would beat a stock M2 in a drag race. No surprise to me.
Current inventory:
F22 & G05
Cadillac CT5-V Blackwing w/3 pedals
Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2)
      04-15-2020, 08:58 AM   #34
Mkinzie
Originally Posted by jessetaylor1 View Post
I guess I'll be the one to say it. You're an asshole for endangering others lives by racing on the street. Near empty or not.
Oh I missed the asshole. Comment. It’s ok. Tough behind a computer.
      04-15-2020, 09:00 AM   #35
Mkinzie
M2 is not stock. But. Yeah. I guess I underestimated the camaro. I fig would be close. But just thought. I would be slightly faster. O well.
I got a good idea of where car sits.
      04-15-2020, 10:17 AM   #36
LuvMyE92
LuvMyE92's Avatar
3000
M2 is not stock.
Your original post was incredibly difficult to read. All I saw was this:
I’m fbo. Dct.
and I don't know what it means. So I assumed stock. Stockish.
FWIW I saw some Camaro ZL1s run at VIR and they were stupid fast. OMG.
Current inventory:
F22 & G05
qnet681.50
      04-15-2020, 10:19 AM   #37
Conissah
Conissah's Avatar
1576
Drives: 2018 M3
FBO means full bolt on. But one mans FBO is different from a different mans FBO. It's like when people refer to their cars "upgrades" in Stages, I can't help but laugh.
"Uh yeah, I'm stage 4 with a stage 3 clutch." Lol, what...?
Moflow2484.50
JTO245276.00
      04-15-2020, 11:24 AM   #38
Mkinzie
Lol Yea. I got the fbo. From this forum.
So I’m guessing what it means too lol.
I’m. Dinan exhaust. Dinan res delete. Cat less down pipe. Injen intake. Dv + , Wagner evo intercooler, charge pipes. Boost pipes. Bm3 tune. ( 93 octane agg)
My buddy just got a zl1. I can’t wait to ride in that beast
      04-15-2020, 11:29 AM   #39
Mkinzie
When cybertruck comes in. I’ll race him again. Lol
TemjinX2520.50
      04-15-2020, 11:29 AM   #40
Picoschu
Drives: 03 E39 M5, 01 325iT, 17 328dxT
Good ol' Tyler, TX.
Yeah Chevy V8s are no joke.
      04-15-2020, 11:31 AM   #41
Mkinzie
Originally Posted by Picoschu View Post
Good ol' Tyler, TX.
You know lil ol tyler ?
      04-15-2020, 11:36 AM   #42
Picoschu
I've been once and never went back, but I hear a lot of things about Tyler.
BTW is it really possible to gain close to a 100hp from basic bolt-ons and tune? I'm having doubts. I know the N55 responds well to particular modifications but didnt know they responded that well..
      04-15-2020, 11:40 AM   #43
Mkinzie
I’m not sure. No Dyno close by. Only going by what bm3 claimed it would be with all that & tune.
      04-15-2020, 02:41 PM   #44
Moflow
Moflow's Avatar
Drives: 2020 M2C 6MT
I'll admit, if anyone mentions anything about "Stages" I take it as code for "i don't know very much about cars, but i'm trying to sound like i do"
Conissah1576.00
