02-01-2021, 04:27 PM | #1 |
Rep 21
2018 m2 mpe f87
Hey guys,
Need some advice. I recently acquired an MPE, from a local pick up, for my 2018 F87. What I picked up was the full exhaust system and the actuators. The guy I picked it up from did not have the Wire harness/power block. I was trying to do some research to find out if the wire harness/powerblock was necessary to have for the MPE to be installed or if I could go with a replacement part. From my understanding, the wiring is just to control the valve flaps with the Bluetooth module. If I am wrong please correct me. I have found a possible alternative to having the wire harnesses. The alternative the a CG Precision VSC-2. I will attach a link below for reference. https://www.cgprecision.com/#!/VSC-2...egory=19266005 Can anyone advice if this can replace the original wire harness hardware that should have came with the MPE? Also, if I decide not to go with replacing the wiring and still have the MPE installed, the only way to control the valves would be to manually open and close them correct? Thanks for any advice! |
02-03-2021, 11:23 AM | #2 | |
Rep 126
So short answer to your question about needing the harness to install MPE, is no, the stock connector will connect to your driver's side actuator only and will control that actuator pretty much how it is stock, while the passenger side is unconnected and will stay in one position. I think most have it closed when there is no second harness, but I have it always open, which makes it sexy loud. I love the sound, but I do have instances where I would want it quieter, hence the hopeful fix above. A side benefit of the VSC-2 is that apparently you can program one of the garage door opener buttons to perform the task, which makes it less cluttered (imo) and cleaner compared to the drink holder button. We'll see. As far as your question about manually opening/closing the valves, someone may know better, but I'm pretty sure they're "stuck" in the position that the actuator is currently set at. You can probably remove the unplugged actuator to let it free, but then you'll probably get rattles and such from the loose valve. Anyway, good luck and hopefully this was helpful. |
02-03-2021, 06:47 PM | #3 |
Rep 896
Drives: OG M2
I actually recently removed my MPE controller and wiring from my car so if anyone is interested in an OEM controller, make me an offer!
BMWF87Melb202.00 |
02-04-2021, 02:18 AM | #4 |
Rep 801
Not sure for the MPE, but I have the Remus exhaust and the VSC2.
On the Remus a second actuator is required (one more than stock). There is a spot on both sides of the exhaust to install one actuator each. The VSC2 takes the single feed line for the exhaust which, in stock form attaches on the drivers rear side, and splits it to connect to both the passenger actuator and the drivers. You then tuck the cables away under heat shielding. Then you can control the flaps with the remote, or better yet, with your home link mirror buttons if you have 2 free. |
02-05-2021, 01:48 PM | #5 |
Rep 357
Drives: 2018 M2 Road & Track Build
Hi
I have ran into this problem selling my MPE to another M2 owner last year. Fortunately my local mechanic shop was able to order the wires independently. It was $260 shipped with taxes too. My shop told me they had to go through like 10 guys at the local BMW dealership parts department to get it ordered. The parts number is shown in this pic |
02-23-2021, 07:37 AM | #6 | |
Rep 48
03-03-2021, 04:08 PM | #9 |
Rep 4
Drives: '18 m2 w ZMZ
If anyone's selling MPE with carbon tips in toronto or anywhere close in Ontario, message me!
03-03-2021, 05:36 PM | #10 | |
22184
Rep 8,723
Try the members classified section
03-04-2021, 07:24 AM | #11 |
Rep 21
03-05-2021, 12:26 PM | #12 | |
Rep 7
Thanks |
03-17-2021, 10:55 AM | #13 | |
Rep 21
Also was the additional harness needed? I thought the MPE would be compatible without an additional harness given that is has 2 actuators already and the wiring connects to both with the CG VSC-2 Finally, you mentioned wanting the ability to open and close all the valves, if you ordered the controller default closed and activated open, how does this work with comfort, sport, and sport+ driving modes? What I mean is if you change to sport with the default settings will the valves still be closed because you haven't activated your controller or will they open because of the car being in sport? |
