M2 Technical Topics > Suspension | Brakes | Chassis > KW V3 Ride Height
      06-11-2021, 09:15 PM   #1
jproject
jproject's Avatar
40
Drives: 18 M2 LCI
KW V3 Ride Height
Hi, I just installed a set of KW V3 on my 18 LCI and on the fence whether I should keep the current ride height or raise it by 5mm or so. I know ride height is pretty subjective but thought I'll see what others think (and share a few pics), and do feel free to share pics of your car's ride height as well.
      06-12-2021, 01:17 AM   #2
hlm2c
Drives: M2C
Looks really good to me. If you don't scrape or rub at that height and you're happy with the performance, I would keep it as is.
      06-12-2021, 09:32 PM   #3
Sundinisagod
Drives: 2018 BMW M2
Is that the lowest setting I assume? Looks perfect to me. I’ve got a AW lci too and am investigating my lowering options still, but leaning kw v3 as well.
Agree with above poster, if you like the ride and no rub I’d leave it.
      06-13-2021, 07:41 AM   #4
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
To me it's a very fine line, and the front always needs to be at least 5mm lower to my eye or the rear looks like it's squatting. Your front looks like it could come down a bit.
I set my MPS to 595/600, and now I'm wishing I would have gotten the KWV3 because it needs just a bit more. But there are always tricks of light and tire shadow as well, so the same car can look very different depending on the lighting. Personally, with stock tires (not just stock size, real PSS), I like 590/595 the best.
All the pix below are 595/600 with OEM Conti tires.
x233284.00
      06-13-2021, 08:30 AM   #5
jproject
jproject's Avatar
40
Drives: 18 M2 LCI
I was looking at various options like MPS and Ohlins, but decided on KW for being in the middle om price and performance. My dealership tried to charge me crazy labor to install MPS. All the best with your search. So far been happy with the KW.
      06-13-2021, 08:47 AM   #6
jproject
jproject's Avatar
40
Drives: 18 M2 LCI
Thanks for sharing your photos, looks fantastic! I think that’s what I’m debating in terms of ride height. Mine does look just a touch lower than yours, and I’m trying to decide if I prefer your 595/600 set up vs my current set up on the KWs.
It’s also interesting that my installer mentioned that he usually sets up the front ride height to be a bit higher than the rear (half finger higher), whereas you have the height lower on the front vs. the rear.
VisualEcho6636.50
      06-13-2021, 08:58 AM   #7
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
I've never heard of anyone setting the front higher (visually) than the rear. BMW themselves recommends rake, and quite a bit of it, like 10mm IIRC. 595/600 is where you should be for the best performance, but visually I suppose you can do whatever you like.
As I said, with mine, in certain lighting it looks like the rear needs to go down a bit, and in other lighting it looks like it's good. It really depends on the light, and the tires make a huge difference as well. I positively hate the sidewall of my new PS4S rears. They're the same size as stock, but they look so much more bulbous, and don't match the fronts at all. It's very hard to tell in pix, but in real life it's glaring.
You might be able to see the difference in in these two pix, but trust me, in real life it's huge. I'm now on the hunt for a nice set of PSS to replace my PS4S with. I don't drive the car much, or in rain, so it won't make much difference to me either way.
x233284.00
      06-13-2021, 09:00 AM   #8
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
And I forgot to ask, what does your rear measure? It does look low to me, but I'd really like to know. You could raise the rear, or lower the front, but with how low the rear is, I wouldn't lower the front anymore. I'd honestly raise the rear a bit.
Waiting on that measurement!
x233284.00
      06-13-2021, 11:53 AM   #9
jproject
jproject's Avatar
40
Drives: 18 M2 LCI
Stupid question here as first time I installed coilovers. What's the right way to measure the height?
      06-13-2021, 12:47 PM   #10
x233
Ukraine
284
Drives: M2C, M235xi
VisualEcho6636.50
      06-13-2021, 01:14 PM   #11
jproject
jproject's Avatar
40
Drives: 18 M2 LCI
Thanks for the diagram on measuring the height!!
Measured the height and it's 595mm in front and 590mm in the rear, so that is probably what my installer did and why the car does have that little bit of "squatted rear" look.
So I think I will have my installer raise the rear 5mm or 10mm so the rear is not lower than the front. Here are a few other photos that is a bit clearer of the wheel gap.
VisualEcho6636.50
      06-13-2021, 01:23 PM   #12
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Yeah, that rear needs to come up 10mm, but something inside me is begging to see the front lowered 5mm instead, first.
I think you'll end up at 595/600, it's honestly perfect. The car is lower, but not too low, if you know what I mean, it doesn't look aftermarketized, it just looks right.
      06-13-2021, 02:10 PM   #13
x233
Ukraine
284
Drives: M2C, M235xi
I'd raise the rear 1.5 turns on the spring perch. That'll get it about 5 mm higher. Also, that will load the front a bit more so you may end up slightly lower in the front without ever touching the said front. Let it settle for a few days, test drive it in the meantime, and see if that's what you like.
Of course, you'll need to re-align the car once you're happy with the ride height. I'd set the rear toe-in at 0.09 (0.18 total) and rear camber at -1.50/-1.55 and the front toe-in at 0.03 (0.06 total).
      06-13-2021, 03:54 PM   #14
jproject
jproject's Avatar
40
Drives: 18 M2 LCI
I’ll post some photos after I get a chance to get the height tweaked
      06-13-2021, 07:35 PM   #15
Caduceus
342
Drives: 2008 135 (sold), 2017 M2
VisualEcho Outstanding photos. Better than any press or advertising photos I've seen of this car. As an OG LBB owner, I approve!!!!
      06-13-2021, 07:42 PM   #16
Caduceus
342
Like many, I used 595/600 on my KW V3s. However, running slightly oversized tyres - M3/4 spec 255/275 I am getting frustrated by rubbing the tyre liners on high speed dips which are frequently found on Australian back country roads where a concrete causeway is set into the road to allow water to drain across during heavy rain. I get absolutely no rubbing on the track under heavy braking or maximum G-cornering but the tyres will kiss the liners in the scenario above.
I think rather than mess with the aesthetics of the suspension and the otherwise excellent handling, I will go back to OEM 245/265s next tyre change. That will give 4mm additional clearance to the liner under maximum compression...which is probably all it needs to avoid zingers.
      06-13-2021, 08:15 PM   #17
Sundinisagod
Drives: 2018 BMW M2
Do you mind sharing that dealer quote for MPS ?
Also what the independent shop charged for the KW ?
I’m just outside Toronto myself.
PM if you prefer. Thanks.
Best of luck with the adjustments.
      06-20-2021, 09:02 AM   #18
jproject
jproject's Avatar
40
Drives: 18 M2 LCI
Tweaked ride height
Got the suspension height tweaked after letting it settle for a bit. Really happy with the outcome! I could go a bit lower but decided to stay at right around 600mm front and back. Probably could have gone 595/600 but like the balanced stance.
As promised here are a few updated photos after the adjustment.
x233284.00
      06-20-2021, 11:43 AM   #19
Carrera2RS
203
Anyone know what stock is ?
      06-21-2021, 06:20 AM   #20
jproject
jproject's Avatar
40
Drives: 18 M2 LCI
I didn’t measure mine unfortunately before I got the KWs on
      06-21-2021, 06:26 AM   #21
x233
Ukraine
284
Drives: M2C, M235xi
620 mm on all 4 corners.
      03-04-2024, 02:19 AM   #22
ericlr1225
ericlr1225's Avatar
Drives: 2018 M2 LCI 6MT
What's the minimum drop for M2s on KWv3?
