06-11-2022, 07:09 AM | #1 |
Rep 39
MST V2 inlet not fitting
Has anyone had any trouble fitting the metal adapter to the turbo?
Currently having a shop install the mst/turbosmart combo. Surprisingly they had no difficulty installing the DV valve but said they are having trouble installing the inlet. Stated it is hard to fit in and wondering if the oring gaskets are the wrong size, being to large. They emailed MST and waiting for a response. They don't want to force it in either in fear of damaging anything. TIA |
06-12-2022, 11:48 AM | #2 |
Rep 753
We installed a MST v2 on bentom2's M2 yesterday. It's definitely tight and takes patience. We installed the metal turbo piece first and started the nut to secure it to the turbo. This was easy and everything slipped in. We used a little Napa SilGlyde on the o-rings to ensure they don't get snagged up or scratched while sliding into the turbo.
To get the intake pipe itself in, we removed the metal adapter piece that the PCV bolts to as the pipe needs to be squished to get it through all the hard lines at the top. Then it takes a little careful finagling to get to to slide over the metal receiver that is on the turbo. We also installed the PCV adapter to the PCV pipe first and then slid that into the silicone intake pipe. LMK if you have questions. |
Mosfry48.00 |
06-13-2022, 01:54 PM | #5 |
18310
Rep 8,500
If they are trying to attach it to the turbo with the silicone attached to the actual aluminum fitting they're doing it wrong
That needs to be attached to the turbo first
06-14-2022, 12:25 PM | #6 |
Rep 660
Yep, that's how I installed mine - flange on turbo first then sliding the inlet (with the clamp semi-loosely on the inlet) onto the flange.
I did have some fitment issues though - the inlet is basically resting on the radiator fan shroud... but that isn't too big of a deal I guess. |
06-14-2022, 03:35 PM | #7 | |
18310
Rep 8,500
You just have to hold it away from the radiator pushing it towards the turbo tightly as the person below tightens the hose clamp holding it to the flange
06-14-2022, 04:36 PM | #9 |
Rep 39
Not installed yet. They are waiting for a reply back from MST. One thing they noticed is the rings are black and the rings in a diy video I found online are brown. MST originally replied asking for vid or pic and that is what they sent them. Now waiting for a response after sending MST the pic.
I think they sent the pic like that to show how much play is in the rings. Making it difficult to install. |
06-14-2022, 04:40 PM | #10 | |
18310
Rep 8,500
Yeah they should be snug tight Trust me it will definitely be worth the wait
06-15-2022, 04:55 AM | #12 | |
18310
Rep 8,500
Shitty QC on MST's part That is supposed to attach to the turbo
06-15-2022, 09:06 AM | #13 |
Rep 753
[IMG]https://media.fotki.com/2v2ayhCJzxu6LVA.jpg[/IMG]
Like others have said, this coupler goes to the turbo first and by itself and you start and snug the nut to secure it to the turbo. Then the inlet pipe is finagled and fitted onto this. |
///M TOWN18309.50 |
06-15-2022, 11:43 AM | #14 |
18310
Rep 8,500
And also the flange that holds the PCV to this inlet is orientated incorrectly when assembled by MST The screw is in the wrong position and if not fixed the inlet will have to removed to fix that so it bolt into place correctly Note it's easier to attach that PCV hose when the inlet is half way installed, Otherwise the setscrew is nearly impossible to get to without it falling on the ground More shitty QC on MST's part
06-16-2022, 09:41 AM | #15 | |
Rep 753
