03-23-2017, 07:38 AM | #24 |
salty cowboys fan
6158
Rep 3,406
You should also tell him he might have been able to catch it before kaboom with frequent oil changes and a $30 oil analysis
she’s home! '22 M4 Comp xDrive
03-23-2017, 11:48 AM | #26 | |
#buildnotbought
10844
Rep 4,892
Everyone that really understands the basics of the mechanics of say an s54 or s65 knows that for example rodbearings should be treated as a maintenance item. If you look at what the common conception to this is at large german sites and german specialists, its that they should be changed every 50k miles. If you say on an american site, its all shock and awe. So its a matter of knowledge. The writer leaves that out. Maybe because he misses that. Its just like I said. What other oversquare engine revs to 8krpm. Who is setting the bar. That sets the balance on wheter its a good engine or not. That journalist completely ignores that. That's why its bad. If he was a better engineer he would have pointed that out is my opinion. As he didnt do that, he was writing that piece not to put things into retrospective but to set a certain mood. Makes good reading for the ones that want to be entertained. Not so good for the ones that want to be informed.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
03-23-2017, 11:57 AM | #27 |
dances with roads
4722
Rep 4,096
If rod bearings are a maintenance item:
03-23-2017, 12:13 PM | #28 |
Rep 5,506
For the average consumer, it makes no sense that these cars are so delicate.
For the enthusiast, they do research and figure out what to do and the associated costs. It's a completely different market and customer base - these are not the bread and butter for BMW. I would say that BMW doesn't make good engines that the majority of people would like. The German reputation for making cars that fall apart is so pervasive that many people refuse to buy German cars because they have a reputation for being unreliable.
Auto Detailing Enthusiast!
RichZ49.50 |
03-23-2017, 12:20 PM | #29 | |||
#buildnotbought
10844
Rep 4,892
Not everything is in the service schedule. I consider a waterpump also as a maintenace item Quote:
But regarding to one of the factual misinterpretations he makes in his column, just to prove my point or at least show what I mean, he says: Quote:
This is written in regard of the s54 engine (specificly in an e46 m3). He bases this upon a thread that shows how to overhaul the cooling system in the e46 m3. Because over time things can start to leak (like a leaking waterpump or thermostat gasket). Fine. That is pretty much something that can happen on all cars. But then he says that it ensures catastropic failure because coolant would shoot out and the engine would therefore overheat (headgasket failure etc bla bla bla). Ok then, lets assume there is a coolant leak and deduct what will happen. Coolant is leaking out of the system. What happens is that the coolant level in the coolant reservoir will drop. The first result of this is that the coolant level sensor will cause a warning light on the dashboard. The engine then can only overheat if that warninglight is ignored. This means that if that scenarion would take place with the engine overheating and headgasket blown etc. that would be a drivers error. He doesnt say anything about that. Why? Lack of knowledge, doesnt he know about that sensor/warninglight? (what that light means is explained in the owners manual) or did he just want to attract readers by setting a specific mood? This makes it a badly written piece.
insanecoder1410.00 WreckerX5d374.50 |
03-23-2017, 02:17 PM | #30 | |
17474
Rep 10,662
Drives: M4 CS. Former G82, x2 F82, F80
Also, I'm not now nor ever buying the line about the rod bearings on the S54 being "maintenance" items. It was shitty design plain and simple, and nowhere in the owner's manual or anything else with "BMW" on it does it say to change the damned things every 50k miles. I love my Z4M to death, but nearly every time I drive it I still have that thought in the back of my head "Was that a knock?". Mine has 75k miles on it now, and I'm rolling the dice. There are tons of examples of S54s with well over 120k miles on the stock bearings. I also don't pound the crap out of my car, don't track it, and always allow the oil to heat up before I go over 3k RPMs. A nice Z4M owner here on the forums last year changed his bearings out of preventative maintenance, the shop screwed it up, and his motor blew. It's been a nightmare for him ever since, and has reinforced the idea to me that if ain't broke, don't fix it. Last edited by NickyC; 03-23-2017 at 02:24 PM.. |
Viffermike1753.00 |
03-23-2017, 02:36 PM | #31 | |
Rep 476
03-23-2017, 03:59 PM | #32 | |
#buildnotbought
10844
Rep 4,892
Changing out the rodbearings is about $300-400 in parts and about a day's labor, so say $1200 in total (dont know what's an acceptable rate for an indie us mechanic but I think $100/hour is fair). So doing that every 50k miles, that totals the service costs for that at less than 2,5ct/mile. I think thats an acceptable amount for an 100hp/liter NA engine (and a healty 114Nm/liter at under 5k revs) that came to market in '99 (or if looked at the s50 in '95). unless you're very cheap ofcourse but then a BMW M is never a good choice because BMW M parts are expensive in general. If you wanted something to rival that kind of NA specific output at the time from another brand, you'd have to settle with ferrari to put it into perspective. You think those engines are more reliable and cheaper to maintain at those mileages? Last edited by GuidoK; 03-23-2017 at 04:15 PM.. |
03-24-2017, 09:51 AM | #33 |
Rep 2,873
Should have labeled it "BMWs are not good cars if you are stupid, negligent, or broke" This article is an extended version of 'sour grapes' turned into click bait - i.e. "those cool looking BMW's are really pieces of crap, you aren't missing out". I agree with those who find many examples of his inexperience, or just a willingness to say stupid shit to make a point (the 'sealed cooling system' caught my eye too - made me imagine it had no way to add coolant, or inaccessible like a rear diff for oil). And also lacking any valid comparison to other brands - MANY other manufacturers with more blatant and inexcusable failures and recalls (especially for pedestrian transport vehicles - I think you should expect some finicky high maintenance on a 100+hp/liter sports car, but not on a grocery-getter).
oolas3388.00 Viffermike1753.00 |
03-24-2017, 02:12 PM | #34 |
Rep 3,256
It's click bait. Most of Tavarish's columns are. Especially the whole don't buy that bland camry, instead get this exotic car that for some reason depreciated to 10% of it's original value. What can go wrong? While I disagree with virtually everything he writes, I find the articles entertaining.
It's all about perspective. For example, my S2000 has had more engine related issues than any of my BMWs. I wouldn't go around saying "Honda engines are gigantic pieces of shit", but from my perspective BMW has been more reliable than Honda. |
03-26-2017, 12:32 PM | #35 |
195
Rep 557
He is right. My 2005 745 pretty much fell apart with about 60k, my 2012 x5 with 27k miles already had about $30k worth of repair (all under warranty).
I love bimmers but I'll never own one again, only lease. |
03-27-2017, 12:40 AM | #37 |
11586
Rep 12,725
they also post about the "s65 masterpiece." some confused fools on there. just click bait.
http://jalopnik.com/this-is-how-bmw-...-m3-1791112839
Instagram; @roastbeefmike
03-28-2017, 03:03 PM | #38 | |
Rep 1,189
And Jalopnik is not anti-BMW, they are very much BMW enthusiasts...one of contributors is the Bill Caswell, the guy who had the $500 e30 and entered a rally, and now has built a rally based E30 monster. The thing is, they don't drink the BMW fanboi Kool-Aid. |
Viffermike1753.00 |
03-28-2017, 07:05 PM | #39 |
Rep 4,163
This guy hates BMW so much, he went out and bought a low miles 2013 E92 M3 in 2016 and did a glowing 40 minutes YouTube review on it.
Now, less than a year later, he wants to sell it cos he just hates BMW that much. |
Viffermike1753.00 |
03-28-2017, 07:20 PM | #40 |
Rep 1,932
Drives: 2013 E92 M3
And now it is for sale!
03-28-2017, 08:13 PM | #41 |
Rep 175
Meanwhile, my wife's 14 year old E46 (which we have owned since 3 miles on the odometer) has had a total of zero engine issues. The only thing touched on the engine is the oil inside it.
If you buy an M car and drive it like an M car you are going to have issues to deal with (or any other car you drive hard). You should expect that. As my co-worker says, if you can't afford the jet fuel, don't buy the jet. Last edited by e36power; 03-28-2017 at 08:32 PM.. |
03-28-2017, 11:45 PM | #42 | |
Rep 5,993
03-28-2017, 11:49 PM | #43 | |
Rep 5,993
03-29-2017, 01:44 AM | #44 | |
Rep 1,189
Now, it seems that the Domestics have caught up, and it seems that at the same time, many of BMW enthusiasts are bemoaning that BMW has lost it's shine and that "M" stands for marketing. Coincidence? Is there some homegrown bias at play, yes. Just like with the Germans, but you can't deny that the domestics have stepped it up. And let's not forget that Randy Pobst drove for Porsche and also raced BMWs and one of the reviers has an e30 wagon. And that Camaro that you mentioned? It was no ordinary Camaro, it was a Z/28 (you failed to mention that). And on another track, the GT-R probably would have won. The Camaro was never a Muscle car to begin with, it was pony "sporty" car to go up against the Mustang...and now, both have been more focused on sport, and aimed at the (Germans) M4. |
