03-11-2017, 05:36 AM | #1 |
Rep 246
2017 Model M2 - Looking to disconnect Center Speaker
Morning All,
I've read in many posts the M2 sound system benefits from the centre speaker being disconnected but I can't seem to locate it. I don't have the Harman Kardon upgrade just the Hi-Fi option, when I look at the dashboard the only plastic trim I can see is the 10 - 12 inch by 2 inch air vent very close the windscreen. I can't imagine the speaker being under it as its very narrow. I may be missing something, but it looks like the hi-fi option does not have a center speaker - Can anyone confirm / deny. thanks in advance.... MJ |
03-11-2017, 09:22 AM | #2 | |
Rep 1,418
Here is a link to disconnecting it, but in short, here is what to do - "It's quite simple, you would use a plastic trim tool to pry up the grill that covers the speakers. You will then see the speaker screws and simply unscrew them on the larger 4 inch speaker and you will see the wiring harness. Simply disconnect that harness from the larger speaker coming from the amp and that's it. The tweeter runs from the 4 inch speaker, so no power to 4 inch, no need to disconnect tweeter. 5 minute job at most." http://www.2addicts.com/forums/showthread.php?t=1287550 Also see this on real oem- centre speaker is there. http://www.realoem.com/bmw/enUS/show...diagId=65_2311 |
03-11-2017, 09:07 PM | #4 |
Rep 1,514
I've disconnected mine, i have the HK system though, you can't miss the speaker grille if your car has a centre speaker, it is directly behind the idrive screen.
03-11-2017, 09:45 PM | #5 | |
BMW Newb
582
Rep 903
03-11-2017, 10:10 PM | #6 | |
Rep 1,514
For a free and relatively quick mod I'd definitely recommend you give it a go though, the only thing i found difficult was removing the blue plug from the speaker, took me a while. Lol |
Ex-MINI582.00 |
03-12-2017, 12:44 PM | #7 | |
Rep 246
So, I guess this is an advantage as now I don't need to worry about disconnecting the center speaker. MJ |
03-13-2017, 12:11 PM | #8 |
Rep 19
I've disconnected mine, and to my ears there is definitely an improvement. I am going to upgrade the front and rear speakers to Focal, and change out the amp. After evaluating those upgrades, I will see if indeed a subwoofer will be needed.
03-14-2017, 04:04 PM | #9 |
Rep 844
I haven't heard the sound system in the M2 yet but I was planning on getting a good 12in sub if the bass doesn't hit hard enough. People say the sound system is pretty good but I need to hear it on my own to judge.
03-15-2017, 02:01 PM | #10 |
Rep 616
Drives: M2, X2 M35i, X6,328i,230i
Garage List 2017 BMW 230i [0.00]
2022 BMW X2 M35i [0.00] 2015 BMW 328i [0.00] 2008 Jeep Commander ... [0.00] 2017 BMW M2 [0.00] 1997 BMW Z3 1.9 Roa ... [0.00] 2014 BMW X6 xDrive35i [0.00] |
I was pleasantly surprised. Doesn't sound too bad, at least compared to my other BMWs (X6 with upgraded sound system and 328i with standard sound system) which leave a lot to be desired.
D CHOI581.00 |
03-21-2017, 07:02 PM | #11 | |
Rep 246
Thanks MJ |
03-21-2017, 07:54 PM | #12 | ||
Rep 19
Maybe someone who has installed components in the rear deck can recommend a specific model. |
03-24-2017, 09:56 AM | #13 |
BMW DRIVER ///M
106
Rep 317
BMW has pushed out a couple Software updates I have a 2017 M2 and the HK sounds system sounds great but. Im on the latest Ilevel. 3.61.1
3.61 update there was a amp update which fixed a bunch of audio issues
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey 2004 E46 M3 White END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci |
03-27-2017, 07:08 AM | #14 |
Rep 1,514
Do you know if this update is applicable for a 2016 model with idrive 4 and also if it is possible to see what software version you are running via the idrive?
03-27-2017, 07:10 AM | #15 | |
BMW DRIVER ///M
106
Rep 317
Current
Prodigy.697.50 |
03-27-2017, 02:31 PM | #16 | |
Rep 68
Thanks for the info! |
03-27-2017, 03:01 PM | #17 |
Rep 715
My 1/17 build also sounds pretty good too. Much, much improved over the '16 I test drive where the audio quality was lacking.
03-31-2017, 02:48 PM | #18 | ||
BMW DRIVER ///M
106
Rep 317
Current
japanaltaf25.00 |
