03-14-2017, 07:48 PM | #23 | |
Rep 796
Boost Safety:21 Auto shift Boost:0(6mt) PiD gain:12 FOL:55 (looks like I could run E30)hovers at 15-18 Future User A = 40 So this is largely a firmware and FUA effect. |
FSociety3812.50 |
03-15-2017, 05:16 AM | #24 |
Rep 931
Best is subjective but Bootmod3 is taking the BMW F series by storm if you look around here, f30 and f80post. If you're considering a flash tune that's what I'd recommend as it gives you versatility and customization like no other so you don't feel stuck. The guys are awesome to work with and have the most experience flash tuning DI BMW engines than any flash tuner on here. They took the N55 1/4 mile record just recently as well if you check n54tech.com and if you want to add a JB to your setup they will work with you to configure it for meth or additional fueling. My 2c.
FSociety3812.50 |
03-15-2017, 07:57 AM | #25 | |
IG @bmwF9xG80
3813
Rep 7,593
Why Beta test 3? Looks like Terry released the Official EWG11 on the thread.
60-130mph 6.5s X4M #HCP
03-15-2017, 10:26 AM | #27 | |
IG @bmwF9xG80
3813
Rep 7,593
Do you have any map4 of the current fw ?
03-15-2017, 06:52 PM | #29 |
IG @bmwF9xG80
3813
Rep 7,593
Awesome man thx, you're like the only guy with a single clue on M2 & JB4 across the forums lol. A friend of mine is not too happy of the lack of support he's gotten so I'm trying to help as much as possible.
03-15-2017, 08:38 PM | #30 | |
Rep 796
03-15-2017, 09:35 PM | #31 | |
IG @bmwF9xG80
3813
Rep 7,593
Do you have this menu?
03-15-2017, 09:37 PM | #32 |
Rep 2,577
Will BMS release m2 maps or even a specific box?
Lemania 2320
03-15-2017, 09:41 PM | #33 |
Rep 796
I'm on JB4 mobile for iOS so I don't :/
03-15-2017, 09:43 PM | #34 |
Rep 796
Maybe specific firmware or settings. New Hardware isn't needed as far I know. The f series JB4 board is powerful and can deal with fairly large changes.
03-16-2017, 10:18 PM | #35 |
IG @bmwF9xG80
3813
Rep 7,593
Almost a year since people have been asking for a M2 specific firmware; a lot of them moved on to other tunes such BM3 for the most part others are scared and awaiting for more results and unfortunately doesn't seem to be enough ppl in the F87 platform wanting to be a guinea pig.
So yes the same F-series EWG N55 jb4 works on M2 as well, but until now there was not a firmware that actually reads stock map4 correctly where Boost was over target and they were saying M2/X4 had a factory flaw My last email with BMS was in Oct with them saying "IT's going to do what it does, don't have any addl advice for you on it." And that was it for me, 7 months of pure waste. Now ashburyn54 has been slowly progressing with BMS it seems and we can see a little time and dedication after months and months of losing M2 customers will do? Not to bash anything, Jb4 seems to do a great job in other cars when it wants to work. While looking at my 93 dyno graph (dynojet) my jb4 adds power until 5200-5500rpm and falls harder than where stock has better power/torque after 5500rpm curve. Not to mention AFR are 13.0 at 6k rpm and stock is 12.1 go figure.
03-16-2017, 10:43 PM | #36 | |
Rep 2,577
I have a couple of m2 friends having bad experience with flash here (none of them are BM3). The rest is using N55 generic JB4 and JB+. Below is a log of a stock m2 with IC using a JB4 custom map, boost holds well and ignition is fine with good IAT, though AFR reads lean. What's the negative effect from that in your opinion?
Lemania 2320
FSociety3812.50 |
03-16-2017, 10:49 PM | #37 | ||
Rep 796
JB4 pretty much targets your stock AFR's and has some fuel enrichment abilities if it needs to add fuel but it will pretty much stay around stock. If that middle curve is third that log looks really solid. Almost 100% throttle the whole time. The boost curve in 4th looking a little aggressive and you have some timing correction there. What fuel? |
03-16-2017, 11:08 PM | #38 | |
Rep 2,577
Edit: fuel is 98RON
Lemania 2320
03-17-2017, 10:30 AM | #39 | ||
Rep 796
I had a small boost leak this week that I fixed. The car was running around 10-12 psi but the timing was so beautiful I almost didn't mind. Everything was smooth and flat as possible. That let me know that with the right targets we can get this within range of BM3 smoothness. There's no substitute for a flash but I think if we keep hammering we can get close while having on the fly maps and all the fun benefits of JB4 |
03-19-2017, 12:17 PM | #40 | |
IG @bmwF9xG80
3813
Rep 7,593
I noticed if i have jb4 mobile connected i won't see the FUD options, but when I got back home I saw them here. I just selected bit0, bit1, nd bit7
03-19-2017, 07:15 PM | #41 | ||
Rep 796
03-20-2017, 06:02 PM | #42 |
Rep 3,077
Subscribed.. I have been reading for a while and have yet tuned because nothing out there has convinced me of working 100% with no quirks or issues.
Follow me on IG
Dav3948.50 |
03-22-2017, 05:13 PM | #43 | |
IG @bmwF9xG80
3813
Rep 7,593
my Map4 boost is still under DME_BT and Terry does not care so I will be forever done with this unless Steve helps. There's plenty of results of Bootmod3 on M2 already; the jb4 is the one lacking any real consistency. Its on here if you search you can find it.
Liquidgold0.00 |
03-23-2017, 12:40 AM | #44 |
Reverse Homer
151
Rep 1,064
I'm actually surprised at the lack of piggy's, tmap and ecu tunes for the m2. There are tons for the new b58 engine and my old 335 had tons of options.
I guess like everyone said- they maxed out the N55. I love my b58 engine - you think BMW will put the b58 into the m2 anytime in the future? |
