Classifieds Section > Sponsors Classifieds > ▀▄ eas | Dinan performance Complete Line Up - Authorized Dealer
      08-17-2016, 02:50 PM   #1
kevin @ eas
kevin @ eas's Avatar
Drives: 2015 BMW M4
Now available from EAS is Dinan's complete line up for the M2. As an authorized dealer we are ready to handle all your Dinan needs whether it be install or shipping.
PM today for expert advice and info
Dinan - Carbon Fiber Cold Air Intake - BMW F87 M2
Efficiency and maximizing the potential of the stock intake design were the keys to development for this N55 intake. Our sealed system delivers as much cold outside air as possible to the engine via an optimized carbon fiber tube that mimics the stock pipe but with less resistance with a straighter freer flowing design. The increased amount of air feeds into a larger volume airbox complete with a larger filter that elicits a sporty tone that makes the intake sound as good as it performs. This optimized design yields an incredible 10HP and 15 lb-ft of torque even without any additional modifications. Simply perform the short bolt-on installation in under an hour and enjoy a more powerful and audibly satisfying driving experience.
Features:
- More Power: +10 HP & +15 lb-ft of torque without additional modifications
- Even more power can be achieved when combined with the DINANTRONICS™ Performance Tuner and exhaust.
- Sportier Sound
- Larger volume air box that completely seals
- Optimized carbon fiber intake tube
- Larger cylindrical air filter
- Larger MAF
- Quick and easy installation
Models Supported:
2016+ F87 BMW M2
Dinan - Lightweight Adjustable Anti-Roll Bar Set - 2016+ F87 BMW M2
[/URL]
Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan® tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner.
Front Anti-Roll Bar
Add a 32mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. This anti-roll bar is adjustable from 57% to 103% stiffer than the stock bar. This 4 hole bar can be mounted in 7 different positions with supplied adjustable end links.
Features
- Less Body Roll
- More Mechanical Grip
- More Stable At Limit
- Large 32mm size (stock bar is 24.7mm)
- 4 hole bar with 7 possible positions on the bar w/ supplied adjustable end links.
- Tubular (Hollow) Construction
Models Supported
2016+ F87 BMW M2
Dinan - Rear Suspension Link Kit - F87 BMW M2
Dinan’s High Performance Rear Suspension Link Kit adds precision and predictability at the limit. The stock rear toe link is built with rubber bushings and a curved forged alloy rod which can easily flex. During hard acceleration this flex allows the rear wheels to have excessive toe change under hard acceleration and braking. All of this flex in the stock toe link causes the car to be unstable.
Dinan® stops the flex by replacing the rubber bushings with Teflon coated machined steel rod ends and the OEM curved bar with a straight billet aluminum rod, thus adding stability. The Dinan rod-ends incorporate left and right hand thread, which allows quick and accurate toe adjustment that is tough to achieve using the stock system. Like the rear toe links, the stock front trailing links also incorporate rubber bushings. Flex in these bushings allow the rear wheels to behave sloppily under heavy loads. Dinan adds precision by replacing these links with billet aluminum rods and Teflon coated machined steel rod ends. These front links are not adjustable, because there is no need to doing so.
Features
- Replaces the stock rear toe link & rubber bushings with a precision machine black-anodized aluminum tube and racing-quality rod ends.
- Replaces the stock forward lower trailing link & rubber bushings with a precision machine black-anodized aluminum tube and racing-quality rod ends..
- Dramatically improves vehicle stability during hard cornering.
- Improves response by eliminating the deflection of the rubber bushings.
- Rod-ends are Teflon-lines for quiet operation.
- Rod-ends incorporate left and right hand thread, which allows quick and accurate toe adjustment by simply turning the aluminum tube. This eliminates the need to struggle with the factory eccentric adjustment.
- Only rear toe links are adjustable. Trailing links are not adjustable.
- Rubber boots protect rod ends from environmental damage for long lasting performance and removes the need for constant cleaning.
Models Supported
2016+ F87 BMW M2
Dinan - Stage 1 Performance Tuner - BMW F87 M2
Stage 1 (DINANTRONICS™ Performance Tuner ONLY) Maximum Power: 383 HP, 411 lb-ft torque. (BMW Stock Power: 365 HP, 343 lb-ft torque [360 HP, 404 lb-ft Measured])
The DINANTRONICS™ Performance Tuner is a highly engineered and sophisticated piece of computer hardware and software that enhances engine performance, without negating or voiding your new car warranty coverage and without affecting long term reliability or the functionality of on-board diagnostic systems. It is also the only tuning device emissions legal in all 50 states. The ultimate objective of developing this piece of technology was to provide the ability to control every signal entering and exiting the BMW factory Engine Control Unit. These items are unique to Dinan and together they embody the apex of performance engineering in a powerful, reliable, and warrantied package.
In its stage 1 form, peak number increases were limited but max gains were recorded as high as 31 HP and 31 lb-ft of torque in some cases. Gains average 12-15 HP/lb-ft increases across the power band however. While by the numbers it may not look like much, it feels more fluid and eager. Power simply comes on more noticeably at 3500 RPM and the tuner continues to hold the increases all the way to red-line for a more enjoyable experience.
Drivability
There is more to a tune than just cranking up the boost. Power needs to come on smoothly and in a predictable way to make the car as fun to drive at wide open throttle as cruising around town. It is your BMW, but reborn with new found acceleration and speed.
Installation
We install everything we sell (and more) at our 8,000 sq/ft, three lift facility in Anaheim, CA. Our experienced technicians are armed with an arsenal of specialty tools to get the job done right. Contact us for an estimate or to schedule your installation!
Easy To Use
Dinan's ECU is Bluetooth® Smart meaning that you can change maps simply via a Bluetooth connection. Just install and you are done!
Designed for the Future
The DINANTRONICS™ Performance Tuner was engineered with future expansion of functionality in mind. Boasting the most powerful processing power on the market the DINANTRONICS™ Performance Tuner can handle more functions and processes than any of its contemporaries. To that end the Dinan performance tuner is capable of interfacing with the CAN and FlexRay communication systems which allow for controlling powertrain functions, among others. This means that when new functions are developed there will be no need for a new box, just a short software update at your local Dinan dealer.
Models Supported
2016+ BMW F87 M2
Phone:
You can reach us directly by calling 866.669.0705 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone)
*Prices and availability subject to change*
Other Payments:
Money Order/Cashier's Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Shipping:
All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees.
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM-2PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x31
Email: Kevin@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact us via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      08-22-2016, 06:12 PM   #2
kevin @ eas
Drives: 2015 BMW M4
Dinan adjustable coil over suspension kit now available for your M2
PM today for details
      08-22-2016, 06:50 PM   #3
quikM2
370
Drives: 2017 Jahre M3
Stage 2?
      08-23-2016, 02:11 PM   #4
kevin @ eas
Drives: 2015 BMW M4
Originally Posted by quikM2 View Post
Stage 2?
That was a typo, no stage 2 currently. Right now only stage I is out.
      11-02-2016, 05:43 PM   #5
kevin @ eas
Drives: 2015 BMW M4
Dinan Free Flow exhaust just released
PM today to get yours
      11-09-2016, 04:29 PM   #6
kevin @ eas
Drives: 2015 BMW M4
Thanks for the inquiries
Dinantronics units in stock and ready to ship
PM today for details and pricing
      12-12-2016, 05:25 PM   #7
kevin @ eas
Drives: 2015 BMW M4
All Dinantronic orders have shipped
Ready to ship same day
      12-14-2016, 03:00 PM   #8
kevin @ eas
Drives: 2015 BMW M4
All orders have shipped
Dinantronics in stock - ships same day
PM for details and pricing
      01-02-2017, 05:01 PM   #9
kevin @ eas
Drives: 2015 BMW M4
Just restocked and ready to ship
PM today to get your Dinantronic tuners!
      01-30-2017, 06:32 PM   #10
kevin @ eas
Drives: 2015 BMW M4
Just restocked on Dinantronic tuners
In stock and ready to ship same day
PM for details and tune info
      02-10-2017, 05:15 PM   #11
kevin @ eas
Drives: 2015 BMW M4
Dinantronics units ready to ship out same day
      02-27-2017, 06:50 PM   #12
kevin @ eas
Drives: 2015 BMW M4
More in stock and ready to go
      03-09-2017, 01:28 PM   #13
kevin @ eas
Drives: 2015 BMW M4
Dinan Free Flow exhausts in stock and ready to ship
      03-23-2017, 06:05 PM   #14
kevin @ eas
Drives: 2015 BMW M4
Dinantronic tunes in stock and ready to ship
      03-31-2017, 06:45 PM   #15
kevin @ eas
Drives: 2015 BMW M4
Dinantronic's in stock and ready to ship
      04-14-2017, 06:02 PM   #16
kevin @ eas
Drives: 2015 BMW M4
Dinantronics in stock and ready to ship
PM today for stage options and to get yours
      04-24-2017, 04:43 PM   #17
kevin @ eas
Drives: 2015 BMW M4
Dinan coil over sets ready to ship
      05-15-2017, 05:14 PM   #18
kevin @ eas
Drives: 2015 BMW M4
EAS your #1 source for Dinantronics tunes
PM today for options and details
      05-23-2017, 06:33 PM   #19
kevin @ eas
Drives: 2015 BMW M4
EAS your #1 source for Dinan performance
      06-01-2017, 02:48 PM   #20
kevin @ eas
Drives: 2015 BMW M4
Another Dinan exhaust being installed @ EAS
      06-02-2017, 04:56 PM   #21
kevin @ eas
Drives: 2015 BMW M4
      06-08-2017, 06:01 PM   #22
kevin @ eas
Drives: 2015 BMW M4
Dinan Big turbo kits in stock and ready to ship
No wait
